Paisan, thanks for sharing your $/value recommendations! I'll try the sway bar bushings next. Did you use the JC Whitney parts as described in the article on your web site?
Lastly, most of you are probably aware of this, but beware that installing stiffer springs and/or sway bars may reduce your independent wheel articulation off-road. Sway bars are designed to help keep both wheels on the same axle at the same level (i.e. reduced independence between the wheels). Many serious off-roaders disconnect or remove their sway bars. Stiffer springs definitely have benefits if you're driving hard/fast, but soft springs can actually be of benefit when crawling slowly over bumps. These factors could help explain why Isuzu made the stock springs/bars soft (in addition to the soft springs being more "comfortable" for the typical on-road driver).
In Rock crawling situations stiffer sways would hurt you, but in most other offroad scenarios it is a help.
-mike
Granted the mechanics reported quote, if true, is of great concern. However, the only proven trend I see is more and more people thinking there might be a problem based on other people thinking there might be a problem.
They used to advise checking at every gas fillup, but every second time is OK for most people whose vehicles don't have a pattern of using oil. And as a few have noted here, always check the level and look for leaks soon after an oil change, just for peace of mind.
I've never done much more than changing the oil and filters in all of my other cars.
How are you supposed to fill these various parts when some of the refill holes are parallel with floor pan or have an exhaust pipe in front of them? Gravity will not work here as you can't get a funnel in the holes without all the fluids pouring back in your face.
Is there some technique that others have used on this board? Thanks for any help
-Kevin
-mike
This isn't the fastest method, but it works. Once the quart container is about half empty, I can't get any more fluid to pump out, so I end up topping off the container from a different container, etc. This can take a while, but it does the job.
When I had my shocks done at 20K mine too were shot.
-mike
I am new to the message board. I am in the process of trading in my leased rodeo for a 2002 Trooper. Isuzu is running a factory rebate of $4500 and the dealer is matching - making the price $9000 off os MSRP. Is $24,600 a good deal for this car?
Check it out: http://www.4x4wire.com/isuzu/tech/maintenance/tranny/
-Kevin
-mike
-mike
It's hard to notice the gradual change over a few years, but it seems like driving over rough pavement and RR crossings, it feels like the passengers are absorbing the brunt of the impact now.
Thanks in advance.
BTW, where are you located and are all the Isuzu dealers doing $9K off? I am in Portland, OR and the dealers were doing $7500 to 8K off. I think there is limited supply here.
Personally I think they should - the car will depreciate $10K-12K the first year! And half the year is over...
-mike
http://www.reuters.com/news_article.jhtml?type=search&StoryID=1332463&fromEmail=true
Jim
-mike
Sounds like there are some good deals out there on NEW Troopers. That discount is nothing to sneeze at! Anyone in the SUV car market now should be grabbing the $8K discount. I don't think they are offering that in our area though. Happy Trooping!!
Other than causing damage to the springs, what are the other reasons why shot shocks should be replaced? I don't really notice any problems in everyday driving, but perhaps we are just accustomed to the feeling of the shot shocks.
-mike
When you remove the stock shocks, if they still provide reasonable resistance to both compression and extension when held in the upright position, then they are still basically functional. They may be worn, but it is more difficult to tell the difference between a worn shock and a good one by hand unless you compare side-by-side. A shock that is completely failed will be obvious though, as it will provide little or no resistance to compression and/or extension.
Determining the condition of your shocks while they are mounted on the vehicle may not be easy either. The most obvious thing you can do is what Paisan suggested. Push down hard on the front or rear bumper or drive over a speed bump and see how much the vehicle bounces.
I think it's pretty safe to say that if your Trooper has over 50k miles, you will see some improvement if you replace the factory shocks with anything of at least moderate quality. For those on a budget, gas shocks from Gabriel or Monroe will do fine. For those who want the best, there seems to be a lot of Trooper owners who like OME (i.e. Old Man Emu) or Rancho.
There is no real risk of damaging your springs due to worn shocks. They carry the weight of the vehicle regardless. I suppose that the springs might wear a little faster if your shocks are bad, since they will flex more as the vehicle bounces, but I would guess that this is not that significant.
Have to agree, the damage to the springs will be far less significant than the safety factor IMHO.
-mike
I also thought that the RS9000 is a gas shock. However, going back through the Rancho website I can only find mention of the RS5000 being a gas shock.
hmm I heard the RS9000s are just adjustable 5000s.
-mike
The RS5000 uses the same technology, i.e. it is not gas charged either. Some people have stated that the RS5000 is equivalent to the RS9000 set on 3. I don't think that is true. They are similar shocks in design, but the RS5000 is advertised as having 10-stage valving, and if I recall correctly, the RS9000 was advertised as having 15-stage. The new RS9000x (different from the original RS9000) has 17-stage.
2. Are the RS9000's gas-charged?
No, The RS9000 are not a gas pressurized shock. Gas charging is of several methods by the shock absorber industry to control the internal fluid.
3. If they're not gas, what does "Cellular Gas" mean?
Cellular gas technology is a high quality closed cell foam material. Cellular gas technology allows 100% oil fill of the shock absorber that increases heat dissipation, reduces heat fade and allows the shock to operate in either orientation.
But while I had it out, I took the opportunity to look over the TOD control module. I spotted one, solitary, empty connector on one of the plugs that connects to the module. The other plug was fully wired. I was tempted to put power to this empty connector and see what happens, but was running out of time. However, I will get back to it in the next couple of weeks and test it with a multimeter.
I recall Mike saying that there is a 4H input shown in the schematics and I'm guessing that this is it.
With my stock setup I got 20mpg once on the highway @ 60mph and 38psi in the tires.
Normally I get abour 17mpg with the lift + steps + loaded down with tools + 275 tires + 77mph
-mike
Most trips away that include four wheel driving usually return 14L/100km (approx 21mpg).
My conversions from metric to imperial are a bit rough, mind you. Also keep in mind that Australian standard unleaded ranges from 91 to 93 octane so we may get slightly better mileage than the USA where standard unleaded is 89 (is that correct?). The highway cruising figure is achieved with 98 octane fuel.
-mike
I tend to run the 98 simply because it is cleaner and keeps the motor cleaner. It's also 10% dearer, but it evens out as the car tends to use 10% less than 91 anyway.
Pity that we don't get Japan's 100 octane stuff. Mitsubishi and Isuzu both have normally aspirated versions of their V6s that can produce 220kw and 250kw respectively, running on 100 octane.
Mind you, the Isuzu motor gets 250kw at 7000rpm. This is the same motor used in competition by Bruce Garland in the Holden Rally Team.
Is the '99 heavier than the 2000 an up? I wouldn't think there would be much difference.
-mike
great deal about Trooper issues and recommendations. And now I'm jumping in to
share my experiences and to get feedback on a bunch of questions I have.
I have a 1996 Trooper S with a 5spd manual transmission. It currently has 128K
miles. I've had some issues with this Trooper over the years:
1) My manual transmission had to be replaced at about 90K. This was tough to
swallow since I thought I'd NOT have transmission troubles with the 5spd vs. an
automatic. Anyone have similar problems with their manual transmission? I'm not
too familiar with manual transmissions, but what basically happened was the main
gear was stripped down to the shaft ( I saw it). Supposed reason: The tranny guy said they put the Rodeo manual transmission in the Troopers and because the Trooper is larger it puts
more stress on the transmission. Who knows.
2) The 4WD solenoid went bad and I had to have that replaced at about 100K. I
was assured that it wasn't linked to the new trans and it made sense to me.
3) I've also been experiencing the ticking from the engine. I guess it's the lifters from
what I've been reading on this site.
Otherwise, I love the Trooper and the size and utility it offers.
OK, now I'm looking for some recommendations on a few things. Any advice
would be greatly appreciated:
1) Tires. I need to replace the Pirelli Scorpions that I have on it now. I do about
95% road riding (alot of it highway) and 5% snow. From research on tirerack.com,
it seems the Yokohame Geolander H/T Y816 tires seems like a good choice.
Anyone have an opinion on these tires for my driving or any other tire
recommendations?
2) Engine Oil. I've been reading about using Mobil 1. This is synthetic oil I'm
guessing. I've been using the cheapest oil I can find and change my oil about every
4000 miles or so. It does burn oil now and ticks as mentioned before. Is the Mobil
1 really worth using? What grade should be used (I live in NJ)?
3) Shocks. I've never replaced my shocks and I've been reading about them alot on
this site. I'm not sure that I need them since I haven't noticed a real change in driving
comfort, although I'm trying to be more attentive now. If I get them replaced, I've
seen a post about the Mornoe Reflex - is this a good choice or is there another you
recommend?
4) Are there other good Trooper forums?
5) Chance of my getting to 200K without serious engine repairs???
Thanks in advance for any advice.
Our 98 gets 18-19 on straight highway and about 16.5-16.7 overall, with 60-70% city, 30-40% highway. Straight city would probably be 14-15.
-mike
You guys getting 18-21mpg are really lucky!! I would make a few adjustments if I thought it would give me those mileage numbers. Happy Trooping???
the 00-02 have drive-by-wire which is probably a more precise fuel delivery? maybe? Just grasping at straws.
I've found driving style has a big effect. I can knock mine down to 10mpg easily if I drive balls to the wall in city traffic.
-mike
