Suzuki XL-7
From the handbook looks if you can get a 6 CD changer as it has the capability to hook up to one. Need to check some of the car audio sites to see compatible models.
If you are looking for an aftermarket go to www.crutchfield.com who is a big seller of auto radios and custom fits.
The reception was excellent and worked best on the lower FM such as 88.3. He had to change it once as we had interference this was on a 250 mile trip from NJ to Boston. I assume you want to play from the Ipod through the radio. I think that the electronics are very much improved. I find the Clarion radio in the XL7 quite good.
If you pull out the ashtray on the XL7 there are two screws which are part of radio plastic surround. You would have to take the radio out to see what is on the back as it would appear impossible to see from underneath. Either you go aftermarket with someone like Crutchfield to see what system meets your needs or compromise
Good luck
Drain engine oil by removing drain plug. Before re-installing the drain plug or removing the filter, remove the oil filler cap. Cup your hands around the opening where you put fresh oil and blow into it creating some air pressure. I didn't do it for very long, and made sure no one could see me giving mouth to mouth to the car, but when I removed the oil filter, there was barely any oil in it.
The other thing that I do when I remove the oil filter is take a couple of plastic grocery bags with a rag in it and put the bag as best I can around the oil filter. Then when I remove the oil filter, a good amount of the excess oil makes it way into the plastic bag and is absorbed by the rag.
from www.suzukipitstop.com
From the home page of the web site, look for the box in the lower right hand corner that is labeled 'featured links' Then select the SERVICE / MAINTENANCE SCHEDULES link. Mozilla Firefox didn't work when I tried it and I had to use internet explorer. ymmv
If it was not for the steering rod it would be dead easy.
Steve
Steve
Keep us posted on how it all went down. But definitely let Terry give you a valuation. He's usually dead on. He was on the new Mazda 3 S we bought this weekend. He valued our '01 Altima dead on, he said $4k. and they offered $4k. He's truly awesome on his prices for trade in's.
The Sandman :sick:
Steve
Can't help you with the loss of power problem.
Likes: great supsension, reasonable reliability, roomy but not too big.
Dislikes: lousy retained value. These things drop value faster than Chrysler products. Dealer isn't exactly my favorite for service. And the tires/wheel package. I HATE the H rated 16 inch tires. Run factory pressure settings and yiu are guaranteed center wear on the tire. These things are over-tired. I'd be a lot happier with a 15in wheel and a 70 series tire. Won't fit because the front rotor/caliper is too big. It's probably over sized too. The a/c condensor fan problem warrents a recall (see other forum posts regarding it chewing through the condensor - ouch).
The resale value being what it is, I don't thing I'll buy another one, at least not new. Maybe used. Maybe.
lSuzuki Plans Entry-Level SUV in U.S. for 2007 (Inside Line)
Now I'm suspicious. First they say title, then they say Cert. of Origin. Back when I was selling cars, if you lost the Cert. of Origin, there was unbelievable red tape to get another one.
This is supposed to be a program car that was never "registered" so it should have the original cert. of origin. Not a title. If it was registered, then there should be ONE title. Does anyone know under what circumstances a vehicle may have two titles or two certificates of origin. Hopefully legit reasons. Is there any way I can investigate this myself. I'm planning on calling the registry but don't know how much they could help. Any ideas at all ????
Steve
Any thoughts regarding this situation are appreciated.
Steve
Try the Any Questions for a Car Dealer? discussion. It's probably happened to one of the pros over there.
Steve
Steve
The Sandman
Steve
Anyone know what key blank works for the XL 7 locks ???
Steve
I have a 2004 XL-7, and sometimes when i accelerate, it will make a sparking kinda sound. I think it's the ignition. I could hear it off and on at random. Any ideas what is it or what is causing it? Has anyone else had this issue?
While driving my 2004 XL-7 a few days ago I tried to change the CD that was in the factory AM/FM/CD unit. After pressing the eject button the unit made a whirring and clicking noise like it was trying to eject the disc but no disc came out. I've tried several times since then with the same result. In addition to not ejecting the disc the CD player now won't play it either. All the radio functions still work. Has anyone else had this problem and if so how was it dealt with? The car's under warranty but I expect the dealer will try to get off the hook by simply removing the disc and pronouncing the problem solved. Personally I think the unit should be replaced as it will probably happen again otherwise.
Sam
I also read that putting in the over the counter fuel injector cleaner can damage them, so I am not going to do that anymore.
It was after the diagnostic check we found that the O2 had gone and my mechanic said I should not use cleaners. I will speak to him again on Monday to re confirm the reason and post.
Seems to be a concencus we stick with a decent brand of gas and should be OK.
If that is true, then what about the cleaning additives in a good brand of gas like Chevron with techron? Wouldn't that hurt the O2 sensor???
I wished more companys did business like Suzuki cause I will buy another product based on the attention to service.
I love my 2004 Suzuki XL-7 and it runs like a champ. But I only bought the 2WD version because you can only use the 4WD off road only. This is my only complaint about it. Does anyone know why they couldn't make it driveable on pavement also? Is there an advantage to having a 4WD that only works off road?
please help, i want to add one to it without buying a new radio
Does anyone know if we can upgrade the stock subwoofer under the seat? If so, how much amps do it put out or do I have to upgrade it with an amplifier also?
Also, are there any good Suzuki sites for accessories, performance parts, off-road parts, etc?
Ivan :shades:
