Wrench stuck!
1hope1hope Member Posts: 3
edited January 2015 in Dodge
I have my socket wrench stuck in between my tensioner pulley and my wheel well. I have no idea how I got it on in the first place there is no room to get it off now! I dont even think there is roon for a grinder down there any suggestions?
    Can you post a pic?
  • stickguystickguy Member Posts: 53,526
    did you loosen it some already? If so, tighten it back up to get more clearance.
    otherwise, pull hard enough and eventually the socket will break!
    if really desperate, loosen up the engine mounts and raise it slightly until you can get it off.
    You must have backed the bolt up too far, because you did get the socket on in the first place, so yeah, tighten it back up and buy yourself an off-set box wrench.
