Buick Enclave Oil and Transmission Leaks
2008enclave
Member Posts: 4
in Buick
We love our new Enclave. Looked at everything and always came back to it. Thinking about changing oil at 3,000 miles so looked underneath and see red tranny fluid along lower seam and oil drop heads on the vertical bolts above the gasket. Then I saw oil marks on drain plug and forward. I looked further to find oil above. Granted this is not alot of engine oil, but for $32k these two leaks were a real dissapointment. We purposely bought a US car and would again. Anyone know of problems with tranny or oil leaks on the 3.5L?
GM is well aware of the tranny leak and it sounds like they are trying to figure out the extent, so keep an eye on yours. The main verticle gasket connecting the two tranny halves had red oil in the crack and oil bubbles on the heads of two bolts higher on the tranny. Never anything on the garage floor. I was told it is a leak in the torque converter seal. So, with 3,000 miles they are taking the tranny out of the vehicle with GM's guidance to make the repair. Dealer has been great giving me updates and loaner car.
They also said the engine oil leak was known and the part was also coming in. Not sure what that issue is, so I am anxious to see if the oil leak really does get fixed. I'll let you know Tuesday when I get it back. did your dealer mention any of the fluid leak service bulletins?
I'll take better notice of the odor.
Just had me bring it in for a checkup to their work and everything is fine. I guess I am dissapointed it happened, but very satisfied with the dealer and Buick's support.
Still drives great. Never noticed the difference in the feel on the road.
As you're working with your service center already, if you had wanted for Customer Service to check into anything we're available to you. I see that you're using kilometers and am guessing that you're writing from Canada - GM of Canada can be reached at 800-263-3777 (Hours: M-F 7:30am - 11:30pm, Sat 7:30am - 6:00 EST).
Sarah, GM Customer Service
Derek
No coverage, out of warranty.
To fix my steering pump noise they are charging $1300, way too much!!
I should say that I feel like the dumbest person in the world for having purchased this car. I have a Hyundai with more than 1700000 miles and none os f this issues.
What is your advise? What should I do?
