Toyota Venza Electric Power Steering
I have driven my Venza V6 AWD for 1500 miles now. A lot of people commented the electric power steering feels numb. I just don't understand what that means.
But this is what I've found. When I am braking slowly (or lightly) to a stop because of a red light, I feel the steering wheel is kind of locked up and harder to steer compared to other Toyota I have driven (this is my fourth Toyota). When my steering wheel is not at exact 12:00 position (a few degrees off for example), I feel the tendency of the car move off from straight a head and I have to use a bit of force (more than the usual effortless power steering) to steer it straight. I am not sure if this is a normal behaviour or so called numbness of the Venza electric power steering or it is an alignment issue that needs to be corrected. I have not had the time to take it to the dealer yet and just want to see if anyone has similar experience.
EPS is also used to interact with VSC to help "guide" the driver into doing the proper actions if the VSC system detects even the slightest bit of vehicle yawing, not fully following the "line" of the front wheels.
I would like to hear similar experience, if any, from other owners. Or it is just me or my car.
TIA :confuse:
About the Venza electric power steering, I have just went to my local Toyota dealer to place a order of the whole EPS unit ($1500 and change). Bought the car in 2010 just about the time the Toyota break malfunction incident, drove about 6000+ miles! change all 4 tires at a Toyota dealership in central Long Beach, CA. Shortly after that I hear tapping noise whenever I have to slow down to a stop for light or stop sign or any time if it is not a hard break! Talk with different service shops (know these people over the years) some say it's the master cylinder of the break, some say it's the steering lower housing link to the transmission joint and some offer the EPS ELECTRIC/MECHANICAL turn "bad". But how bad is bad?
Is this EPS system have some kind of solenoid(s) that will release pulse signals that cause the "tapping" sound when I step on the break? Because if it is a mechanical sound then should be a non stop and rhythmatic and happen each time the break is pressed, and if it is the steering connections warn out, then the steering wheel should have vibration -I just did a break check and replacement and a alignment a week ago thought that will elemental the problem - still there!
Anyone can give a idea?
