I have a 2001 Taurus SES w/Vulcan engine and 99,000 miles. It's been a great car, but I have a question:
Two months ago I was on the interstate and the car made a jolting feel three times (about 10 seconds apart) and I stopped at a service shop. They said it was likely a miss. So I replaced all the spark plugs and wires (only cost $60 and had a friend do it). Car ran great and was even smoother operating than before (which before was fine).
Yesterday, that jolt feel came back and it did it once. It felt the same as my buddy's 1996 Toyota Tercel who's does the same thing and he said he probably just needed a MAP sensor.
So, what is a MAP sensor and could that be my problem? I know it's not my plugs or wires. My throttle body was completely cleaned out by my friend who replaced the plugs, and my car's transmission has been flushed twice since purchase and is smooth. Auto Zone said it could be water in the tank, put ISODRY in it.
Another note: My check engine light sometimes comes on/off for a EVAP leak, and I replaced my fuel cap.
The dealer says wait until it is more recurrent.
What do you think? Other than this very remote and non-consistent problem, the car runs absolutely wonderful!
THANKS!
- Alex
P.S. This car has never broke down and is 100% reliable.
I have a 2000 Ford Taurus, no manual, and I am having trouble finding the fuse box. My cigarette lighter stopped working, and so did the extra 12v located underneath it. Does anyone have any idea where I can find the fuse box, and which fuse it would be. I'm a Sirius radio addict in dire need of 12v power!
There is also another fuse box for in the engine compartment called the power distribution box. The power distribution box contains high current fuses that protect your vehicle's main electrical systems from overloads.
For what it's worth, I was able to download an electronic copy (PDF file) of the owners manual for my Mercury Sable at the Mercury owners website.
Thanks though. at least I think I know where it is now.
The cigarette lighter fuse is in spot #13.
Gbuckyhockey:
If you put your E-mail address in your profile I'll E-mail you a PDF manual for a 2003 Sable.
Ford_Taurus_Owners_Manuals
Adding confusion, about three months ago she was complaining that she was seeing an intermittant where the speedometer would suddenly fall to zero and act like the car was slipping, changing gears, something like that. Immediately I suspected the Vehicle Speed Sensor on the tranny. But the cheap manual I have says that should have set a code. No Code! Can anyone verify if a defective sensor sets a code?
The vehicle also seemed to do TCC lock at speeds way to low. I told her it needed dealer check to get total readout. She ignored and took to the one place I told her to stay away from. (Definite woman)They gave me some bull about the signal going places other than the computer and then to the speedometer, I knew better. More questioning gave the warranty as, they were pretty certain that was the problem and they would apply the price against the fix. I could just hear a $3000 transmission coming. Just as bad, I know where they get there parts and it is highly likely they use Wells brand. My luck with all there parts has been they last just past any warranty.
But back to the code.
I've researched it as far as I'm able to. What I've found is this is a performance code and is set when the TCC doesn't properly engage determined by engine sensors, VSS(the one they changed), TSS(turbine shaft sensor), etc. I guess it compares the engine speed with vehicle speed more or less. If the TCC is supposed to be locked and the engine rpm doesn't match what the vehicle speed is for the gear it is supposed to be in, you get the failure. That is, the clutch might not be engaging or it is slipping.
But I need an answer to if the code sets, does it stop trying to engage the TCC?
I hooked up some test circuitry and monitored for the low from the computer to the TCC solenoid yesterday and the line stayed high. That is it made no effort to engage the clutch.
Any knowledge of this circuit and how it functions will be greatly appreciated.
If I was supposed to get a light with the VSS failure, then it starts to look very much like a malfunctioning computer.
Also parameters telling the computer to engage the TCC would be helpful since it had prior been engaging too soon. (no codes).
Not sure if you'll see this since no one has responded yet, but have you checked your alternator diodes? When they go, they can "leak" current, killing the battery when the car is shut off. The current leak will get worse over time. This can be checked by removing the alternator and taking it to a parts store for testing (such as Auto Zone).
My priorities for these tires are long tread life, reasonable traction, and above all, the quietest possible tire in terms of rolling noise.
They ride quietly, somewhat better wet traction than the OEM Continentals, and have quite good snow traction as well, and they are fairly moderately priced.
I don't bother with snow tires as my front wheel drive Taurus performs quite well in the snow I need to get around in, as long as a decent amount of rubber remains on all season tires.
And... umm..... I don't bother with snow tires cuz I live in Texas.
:P
Note, the higher the speed rating, the softer the sidewall typically. Make sure you use at least what the OE was. Less will certainly ruin ride, harsh. Going higher may not be a problem as the above mentioned, without any suspension changes came with either S's or V's. Also the above mentioned site has a size search by vehicle. My search eliminated some tires available in that size because they didn't match weight requirements. (99H is weight/ speed rating for that particular tire)
The other day I looked into recovery bottle and saw this brownish with small specs in it. Did complete flush first.
Anyone else having problem with this stuff?
My 2000 SES has developed this. It only shows up in cool or cold weather and disappears after a mile or less of driving. Once the suspension has been exercised a bit or the exhaust system warms up the clunk disappears completely. It doesn't bother me much currently but if it turns into something that clunks all the time I might have do something about it. Anyone out there that have had this and have a solution?
Update. SES seems to go out after three cold cycles. Then returns after a few days. Anyone know of the intricate details of how this code/system works?
I then replaced disc pads and rotors a second time, and again the outside pad, drivers side rear is only hitting the rotor on the top. It too is beginning to wear on an angle.
This began when the brake cylinders were both replaced on the rear of the car. The mechanic says that the cylider is functioning correctly, and doesnt know why that one outside pad continues to wear on an angle.
Any suggestions or thoughts? Thanks in advance.
98-06-05, Transaxle - Ax4n - Torque Converter Clutch Not Engaging And/Or Diagnostic Trouble Code (Dtc) P0741 Or P1744 Stored In Memory
Some info:
CCM - TORQUE CONVERTER CLUTCH (TCC)
The Torque Converter Clutch locks the input to output together during low-torque periods of driving. This lowers RPM and saves fuel as well as engine wear and tear. The TCC is a duty-cycle between 0 and 100% and is controlled directly by the PCM.
There are both Electrical - P0743 Torque Converter Clutch Circuit Electrical
and Mechanical checks - P1744 Torque Converter Clutch System Performance
The following conditions have to be met before the CCM runs the TCC check:
Conditions: Transmission Fluid Temp between 70° and 225° F and positive driving torque. The Electric check needs a Commanded TCC duty cycle of 60 to 90% with 0 RPM slip, while the mechanical check requires 60 to 100% for 0 rpm slip. The TCC is not checked while the transaxle is shifting gears.
If the output Driver feedback circuit does not match the commanded driver state (> 1 volt if commanded on, ) the P0743 DTC is recorded. If the slip across the torque converter >100 rpm (or on some application the speed ratio <0.93%) then P1744 is recorded.
I ran across the beginnings of a class action against GM and Dexcool. Much of it sounded like BS to anyone knowledgeable but it might work for an average jury. One of the defenses GM was using, you let air get in system. OK, that might work with vehicles that had a recovery bottle so the coolant heated and under pressure wouldn't react with air. But I have an Aurora which has a pressurized reservoir much like on recent Taurus. Has to have air in bottle, says Dexcool only on the cap. And I haven't received any info such as recall or notice changing that. And you mention the green. As I recall, part of the reason for a move away from it was the composition which can clog a converter. Part of the reason for the GM change I'd bet since the allowable seepage for GM spec is so high. Yet a lot of the people in the class action were alleging plugged coolant systems, radiator, heater cores, resulting in blown head gaskets. GM certain seems to have a high rate of this in it's 3.1,3.4, & 3.8 engines. Ford also has it's problems mostly in the 3.8 and the newer Duratec. That seems odd to me since the Vulcan is the same engine with different heads which leads me to believe it is a design flaw.
I can not help but wonder if American Automotive would be best served with a watchdog/blabber mouth organization such as the crash test people but only for durability/reliability of vehicles. It might force Detroit to build better. Something is seriously wrong when you look at the reputation of AX, AXOD, AXOD-E, AX4n, & AX4s family of tranmissions. Over 20 years of this and they haven't fixed? Yes seriously wrong.
I replied yesterday but for some reason it didn't post.
Do you understand what they mean by duty cycle?
Quite informative is that they designed a way for the computer to ensure that the electrical circuit wasn't open.(no code p0743)
Wife took car to shop the other day. They said new tranny. Then I learned wife added fluid. It had never lost any in the two years since flush and fill. Claimed she dumped several quarts in. WHAT?? It was at proper level less than a week before. Also found bottle that said type F. OS! Went to shop yesterday morning, checked level, vehicle cold and it was a little low, but likely correct if warmed up. They swore they never dropped pan, so where did all the fluid go??????
Now suspect wife checked engine off. double OS! Added type F and of course way over full. Limped to shop, should have been suspicious something was going on she wasn't revealing. My stupidity for believing she was finally listening to me. And after looking under car, no major leaks present, I noticed that all the pan bolts looked very clean and dry. Some wetness around gasket, which makes me believe the pan was down and cleaned and for some reason they are lieing about dropping pan.
Further they claimed it needed new compressor, drier, and condenser. Ok, system leaks a little each year and was tracked to a factory crimp on low pressure hose returning to compressor. I managed to tighten that crimp with more clamps to the current leak rate. Never any sign of oil on condenser and none at crimp, anymore. No mention of replacing that expensive hose assembly with the visible clamps. More Hmm! Also claimed rear seal was leaking. Well it has been leaking small amounts of oil, visible in driveway. But I'd have bet it was the oil pan gasket with mileage/age of vehicle. Been there twice before and seems rear seal is rather rare on Vulcan.
Current plan, filter, flush and fill of tranny with correct fluid. Pray.
Look for more info and reason TCC has been engaging early. Hopefully you can give me a hint as to what parameters are needed before TCC engages. Then pray it hasn't ate TCC by over stressing.
The sensors in the tranny that feed the computer seem very limited and make me question why a tranny rebuild. I suspect the side pan can be gotten off without pulling.
I doing a follow on to last post as it was wandering and getting long.
Still puzzled what is meant by duty cycle.
Have to question what sensors are related to TCC lock. No other codes. Possible sensors in tranny would be fluid temp and turbine shaft speed. Range sensor would be external and suspect show other symptoms. VSS is external. Other electrical components are solenoids for shifting and pressure regulation. Since it seems to shift normally in every rate of acceleration except for early TCC under mild acceleration, I can't help but suspect something else is going on. To the best of my knowledge, there is no mechanical control over whether TCC is engaged or disengaged in the valve pack. Modulator valves and springs may affect the rate of engage or disengage when the TCC solenoid changes state thusly modifying how quickly the clutch itself engages or disengages. This has shown no harshness.
Possibilities that might be related to code:
TC clutch is slipping.
Internal leak not allowing full apply pressure.
Something electronic is out of range.
Turn a light on for 3 seconds, off for 7, on for 3, off for 7. One cycle is 10 seconds, and the "on" time is 3 seconds, or 30% of the length of one cycle. This is a 30% duty cycle. Now reduce the time frame of one on-off cycle from seconds to milliseconds (1/1,000 second) and you have typical automotive electronic circuitry performance. The "on" time is also referred to as the pulse width. Typical pulse width modulated devices include fuel injectors, trans pressure control solenoids and TCC control solenoids, linear EGR valves.
Parameters for TCC apply usually include:
- engine warmed up
- 3rd gear
- minimum road speed met
- throttle off idle
- less than wide open throttle
- manifold vacuum within specified parameters
- brake pedal released
If any of the above conditions are not met, the TCC will not apply.
Re the F fluid, the container probably reads M2C33F. It's the early Ford fluid spec. Major difference is that it does not contain any friction modifiers, which are used to control the lockup rate of clutches and bands for smooth shifts. A complete refill with F will probably cause more abrupt clutch apply and may cause TCC shudder on apply, a small amount will probably not cause any noticable difference. Fwiw, an old trick with GM transmissions for was to fill them with F for a "shift kit in a bottle".
I have since found Technical Service Bulletin #02236 dated 11/25/2002 the summary of which states:
CLIMATE CONTROL - ERRATIC OPERATION OF THE
COOL/WARM FUNCTION OF THE TEMPERATURE
CONTROL SYSTEM - REPAIR PROCEDURE FOR
STRATIFICATION (SECONDARY) TEMPERATURE
BLEND DOOR
The complete text to this TSB makes references to Workshop Manual sections 501-12 and 412-04. It lists the part number as 3F1Z-19D842-AA and states the repair should take about 3 hours which includes removing and reinstalling the instrument panel.
Please excuse my ignorance, but is this a repair that someone of modest mechanical abilities (me) could attempt to do? On another repair forum, I was told "yes it's a relatively simple repair". Yet, on another repair forum, I was told this is a very complex task involving recharging the a/c, removing the entire dash and heater core. Obviously I'm a tad confused and from what I gleaned about having a shop do the repair, I'm looking at over $600.
If this is indeed something I could attempt, where could I find the appropriate instructions or workshop manual(s), either printed or on CD?
Thanks for any help that you might be able to supply.
Gerry
<img src ="http://www.autozone.com/images/cds/gif/large/0900823d800bfe1a.gif"
I have a 2001 Taurus SEL with DHC. I travel all over the country and put over 50K a year on it. I blew the tranny this week at 180K and need to replace it quick. Mine is a floor shift and the tranny that I found is a column. The cars are exactly the same, with the exception of the shifter location. Are the tranny's the same other wise and can I use this tranny with my hardware?
I am also having this exact problem with my 98 Sable. Have you been able to find the cause of this yet? Thanks,
Rich
Hi iam new to site and looking for advice. About 3 weeks ago my wife took car to walmart for oil change.02' Ford Tauras..24 valve doh cam 54,000 miles. They double gasketed the filter(left old one on). Wife drove around town and car lost 5 of the 6 quarts of oil. Wal Mart knows they did this as they left message on machine saying we needed to contact them as soon as possible..oil trail out of their bay. Now I have low compression in a cylinder. They have set me up with rental car and and authorized dealer to find root of problem to see if the cause is due to the loss of oil. My question is, if the car ran perfect before the oil change fubar, and now I have a bad cylinder, can they deny their mess up dint cause the problem. Also, what else could be ready to explode inside the motor if all they do is fix this problem. Thanks for advice.
P.S. They are admitting they are at fault of double gasket, I have receipt documenting it with manager signature.
Seriously. I have a 1998 Taurus with with non-operating windows. This is a problem that manifested itself gradually. It started with one or two windows not functioning. It was intermittent. It gradually got worse. Eventually, I started hearing this rattling noise like a relay going bad, then the windows quite alltogether.
I changed the window fuse under the dash, but I am told there is an all-powerful window regulator that controls all the windows - oh and I'm told it's behind the glove compartment.
Can I get to this? Is it something I can get from Auto Zone and change myself?
Also - Is this linked somehow to the courtesy lights? I noticed that the courtesy lights would not go off right before this problem started.
Thanks :confuse:
Thanks :confuse:
My 2000 Taurus' DPFE sensor failed before 80K miles, and I would prefer not to pay the $197.40 the dealership wants to replace it.
Also, other parts have failed and I am wondering if there is any way to find out whether there are extended warranties covering them as well.
If your car is under the extended warranty, it should cost you nothing for the repair. Note, I do not know if the warranty applied to all 2000 Tauri with both engines, but it definitely did to mine, which is a 2000 SES with 3.0 Duratech, and the car was built toward the end of the 2000 model year.
I don't know of any other extended warranties except the front suspension springs. However there were several recalls that your car may have not been brought in for, such as the wiper motor and brake light switch replacement that I can remember I had replaced under recalls several years ago. With the VIN number, your dealer should be able to tell you whether your car had these recalls done.
First this must be S, not N by filter kit. 17 bolt pan, not 19.
Still confusion over the duty cycle thing, but not as to what a duty cycle is. In the area of no slippage requirement which would seem to make both checks fail or pass as written. I do wonder though if the wording should have read "TCC solenoid" for duty cycle.
Has the system progressed to the point that the apply rate of TCC is being controlled by PWM of the solenoid? It used to be fully on or off and TCC apply rate was controlled by a pressure and spring modulator valve circuit.
Wife took car to shop, they said new tranny, but think they were guessing and don't know what reader they used.
Change fluid using Lubeguard's flush. Much darker than I expected with 35K since last time. Probably a normal amount of material on magnet. Flushed via cooler line using 16 1/2 quarts. Test drove seemed OK. Wife driving and so far no code. Will redrive when time allows. Much confusion about why fluid was low, per wife, where excess may have gone to when she added. Just like a woman to confuse beyond any diagnostic measure that might point to the idiot behind the wheel.
Thanks again.
Second purpose could indicate problem in main brakes. Malfunctioning master cylinder, low fluid. Check fluid level immediately. Do not move until done and topped off! If low, likely you've got a leak. In either case, unless you fix, slowly go with caution to service station, if braking seems OK!!!
Could also be bulb check circuit, bad wiring, but don't bet someone's life on it.
