Volvo S80 Starting Issues
I recently changed the transmission in my 1999 S-80 and since, the car is hard to start when it is hot. The only thing that was removed during the work was the electrical conector to the top of the transmission and the starter. Does anyone have an idea what would make the car do this?
Meanwhile, we'll wait to see if anyone here can help.
For lack of a better question, what the heck just happened?
Let me know, don't know if this helps or not.
any input would be appriciated, I'm going to take it to the dealer however I dont want to underplay the issue and wait on something that may be more serious then I think. I do have a soundbit of the noise however can't seem to add it to my posting.
The past 4 times I’ve gotten out, locked the doors and walked away, then I get in around 10-15 minutes later it starts up as if nothing has happened
The dealer had the car for 6 days and because it was starting with him, he couldn’t figure out the problem, I was told to bring it in when it doesn’t start (no kidding Sherlock)
Am I nuts or has anyone else had this issue?
i'm also thinking it's something to do with the key cylinder, tumbler might be wearing down
I appreciate any suggestions.
Jhets80
Has anyone ever experienced anything like this?
I own Volvo 2001s80. My car cranks a few times before starting. Once it starts, it runs perfectly well. Different mechanics provided different answers to the problem. I changed the fuel pump,Mass airflow sensor, spark plugs, one coil,
One fuel injector, crankshaft positioning sensor.
I am still experiencing the late start. One mechanic said the code he's getting is the throttle body. Can anyone help please?
Stop replacing things.
Check fuel pressure, hook up a scanner to it and see what it is telling you.
You cannot diagnose it the way you are going and all that will do is cost you money.
Without knowing the fuel pressure and seeing what the symptoms are doing, you have no idea.
As for the throttle body code, what EXACTLY is the code.
Did he mean throttle position sensor or MAP/MAF sensor?
Codes don't mean replace things. They mean check that system and see what the problem is.
Many things, besides the sensor can be a problem.
