That's an opinion that Toyota doesn't share - at least for warranty claim consideration. Toyota has not released the T-IV formulation specifics, therefore so-called "universal" ATFs (which are NOT universal at all) are only their blenders' Kentucky-windage guess at compatibility. If the car is still under powertrain warranty, stick with Toyota T-IV ATF. It's a synthetic blend with friction modifier characteristics specifically tailored to Toyota's choice of friction facing materials. The rest of your advice was spot-on, though.
Steve
are you a mechanic? curious.
i'm mechanically challenged, not a motor-head, just interested...initially i was thinking maybe just a bad temp sender or connection to same (if there was no actual overheating), but since the vehicle is overheating (how do we know that?) with it set to heat, i like your explaination. could it also be the bypass valve itself, as opposed to the heater core?
additionally, don't you think the person should check the level of the antifreeze in the radiator (cold), and in the resevoir?
if the system has never been serviced, a flush and fill with the new stuff in proper proportions seems in order.
I own a Toyota Camry LE V6 2004 model with the dealer installed security system, and since last night the alarm is going off every 60-90 mins.
Wondering if your issue got resolved by keeping the remote transmitter away from the car.
Edge
Nope - just another gearhead who's serviced his own rides for over 44 years. (and who was obviously humbled in this case as the result of a car owner who hadn't bothered checking his radiator coolant level for way too long...)
you think this owner should perform a flush and refill with new toyota brand coolant and water in the appropriate ratio?
a coolant looses it's heat transmissivity and protective attributes over time right?
I drive rental cars every other week and found this problem to be very unusual amongst cars in general. Even generic American cars such as the older version malibu with rental miles did not have the issue.
The evap emission errors are likely due to the gas cap not being on tight enough. I got this error on my Durango. Once I tightened the gas cap the error immediately went away. Of course it could be a bad gas cap or a hole in the hose to the tank.
With the P0303 error, I would start with a tune-up. With this cylinder misfiring it could be source of your problem for the P0171, P1130, P1150 and possibly other errors. If the spark plugs and wires (it may not have wires if it has a coil on each cylinder)have already been changed then I would do a compression test on the third cylinder. I don't know if the 2000 Camary has individual coils for each cylinder, but if it does, I would look at that as the next candidate. If it still has a distributor cap then I would check to see if there is a bad contact and change it. After, that I would say that its probably a bad fuel injector.
If the tune-up fixes your misfire, but not your O2 Sensor problem then I would locate and replace it. You may need a manual Haynes or Chilton or whatever your preference to locate the O2 sensor. Kragen.com and/or Autozone.com have location descriptions and/or pictures for some components.
Of course if you have an OBD II code reader, clear the codes and see if any come back after you repair or replace something. Some of the codes may not come off until the car has been successfully started a dozen times or so and it won't do much good to have fixed the problem and not clear the code. The problem could remain in the car for several days without you knowing that you fixed the problem.
Good Luck,
SD-out
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
To my surprise, I can increase my car’s speed to 65 miles/hr. (due to traffic, I can’t increase more).
It is unlikely caused by timing belt (have not changed yet), overdrive (never use), cruise speed (without this feature).
I think the cause of problem might be from battery (change 1.5 years ago at Wal-Mart), spark plug (replaced by platinum one year ago) or fuel injection (never change), etc. Any good suggestions since it is quite unsafe to happen again on freeway?
seems to me maybe your transmission (assuming A/T) has lost it's top gear.
assuming you have a CEL (Check Engine Light) illuminated, I'd bring it to an autozone or other parts chain, and have the codes read so you know in general terms, what the problem *might* be. then, i'd probably have an well known independant repair place look at it and give you an estimate.
hopefully it is something simple.
I went to Walmart today on freeway (60-70 mph) for battery checkup, which seems battery is fine.
Wondering whether there is any easy procedure for me to check up?
you must be hearing very loud engine noise when this happens. you shouldn't be pushing the accelerator to the floor.
there is something wrong with your transmission or speed sensing; you may actually be in 1st or 2nd gear.
what indication do you have on the dashboard, or next to the shifter when you place it in "D" (Drive)?
i am confused. before you indicated RPM was 6/7 and speed "capped" at 40MPH.
now you are saying on your way to Walmart, you were able to go 60/70mph.
is it possible your problem before was you didn't have the shifter in "D" drive but "1" or "2"?
if this is an intermittent problem, and you're quite sure of putting the transmission in "D", i believe your vehicle may be sensing a transmission or speed measuring problem and putting itself into something called "limp mode", which is a fixed / set gearing ratio (that involves no shifting) to get you to a repair center.
it's possible you have a bad solenoid, clogged transmission passages (has your vehicle's transmission ever had servicing or it's fluid replaced?), a bad transmission control module, a bad speed sensor... there could be any number of causes - i'm not an expert just another driver trying to be helpful.
i think if this happens again or if it is a recurrent problem, when it is in this mode, you should drive (slowly) to a service center to have it diagnosed. and if it were me, i might even consider having it towed to avoid additional damage.
does anyone else have additional advice for babycrane? i do not believe this is something that can be diagnosed by the vehicle owner, and i think continued driving when the transmission isn't using all of its gears is not good for the vehicle's transmission or engine.
I'm wondering if the exhaust system (especially the catalytic converter) may be obstructed, which would prevent the car from reaching higher speeds. Although, if this were the case, would it be possible to go 60-70 mph later?
She showed them the receipt for the VSV valve, and they said that is different than the EGR valve. I just want to make sure she's not being taken advantage of. Thanks for your feedback!
Your problem is one associated to the hydrolic system for the brake operation. The first thing to do is check the resovior for the brakes and see how much fluid your vehicle is using? Once you have carried out that inspection have a look underneath the car and inspect the inner tyre wall to see which tyre is damp or wet. Once you have done that you can determine where the leakage is. The most likely is one of the rear wheel cylinders.... the rubber seals are available in kit form and should be replaced.... When you drive with only half of your brake system functioning you are a danger on the road. If the front only are working You only have about 60% of your braking efficiency, if you have the rear only, you have about 40%.... Have them fixed or do them your self before driving the car again!
Be safe and happy fixing
Best regards
http://www.autoshop101.com/forms/h61.pdf
This incident happened on freeway. After resting for 15 mintuest and drived at "capped" speed at 40 mph for another 10 minutes, everything returns the normal status (speed can increase to traffic flow speed, 65 mph). During the whole process, transmittion gear is always put on "D" mode and no any abnormal/emergency light,including ECL (Engine Check Light), is on.
This is well maintained car, with transmission oil replaced just last week.
The only abnormal is I seldom drive more than 75 mph for more than 2 hours one way. But this time, I maintained speed at least 80 mph for more than 3 hours at inter-state freeway. And this incident happened.
Any more suggestions to narrow down the cause of problem? I truly appreciate it.
Scott
question: did this problem just begin to occur AFTER the service to the transmission?
if answer is yes - why haven't you brought it back to the place that serviced the transmission?
question: do you have a transmission fluid dip stick? (consult your owner's manual). if yes, drive your car till it is warmed up. stop the vehicle, turn off the engine, and see if the oil is up to the proper full level mark (consult your manual).
What you have said about your Camry is correct, the rear suspension has no adjustment for camber( but 0.3 does not sound bad to me.)it does have rear alignment in the way of a toe in /out adjustment though. Take the vehicle to a tyre and alignment centre and have them work first on the rear wheels and then on the front.... Have you checked your tyre pressure? One other thing you should be aware of and that is that if the shocks have been replaced with sub standard parts you may have problems with the camber adjustment, both front and rear, depending on where they're fitted. Different tread paterns on the tyre can also result in the same problem that you're having.
All the best
anyways, thanks for ANY help.
btw: when the car is driving at highway speeds i dont really notice major abnormalities in the way the vehicle drives. However, when i am idling or driving under 30mph, the car rumbles; sometimes shaking. In addition to that, when i push the accelerator, trying to accelerate, the engine revs normally and the rpm's go up, but there is a sense of hesitation and the car doesnt accelerate nearly as fast as it should. This is the only possible evidence that some of my cylinders are misfiring.
One last thing. If you step outside the car (while it's idle) the exhaust note isnt consistent and significantly louder than it should be. It is extremely hard to explain,but if you have ever heard a diesel's exhaust, there is a definite rhythm to the sound of the exhaust. Although not as loud and noticable as a diesel, the exhaust note on my camry almost resembles that of a diesel.
any help is appreciated! thanks in advace!
I just bought a 2001 Camry that has a security system. The car didn't come with an owner's manual and this is the first Toyota I've owned.
The problem is that sometimes this thing arms and I don't know how to disarm it. Disarming it usually means waking up the neighbors with the thing before I stumble into getting it done. Any help as to exactly how to arm/disarm this thing would be greatly appreciated...Kevin
Having the proper oil return opening is a part of engineering the engine. I would expect more from a company that people feel has great engineering...
Getting close to trade in time I guess!
Furthermore, the car doesnt pick immediately I accelerate.
The engine goes of while on motion or whenever i slow down.
Secondly, the car consumes more gas than before, the injector valve was changed but there is no significant difference.
Kindly forward your suggestions to me. I will appreciate them.
Toyin
