( it usually happens after the car has been parked overnight or parked for awhile) I get this loud rumble grinding noise when the brakes are first applied. After the car is warmed up the sound goes away and the car brakes without any noise, etc. Has anyone had this problem?
Could this be your brake's vaccum yawning?
bjk
The noise went away for the most part (90% gone). But I still can hear the noise when I hit bigger bumps certain way. The good news is there is no noise when I drive on highway. I may take it in again before the warranty is up and see if they have a better fix. The padding looks too weak to last many years (I could be wrong).
My older 88 Civic has the backseat rattling. I took it in couple times when it was new. The dealer said the bushing shrunk in cold weather and caused it to rattle. There was no permanent fix. It still rattles. I hope they have changed the design by now.
Regarding the very warm key, my key is always very warm after driving. It is so warm that it is almost too warm to touch. I hope this is normal as it has never happened to any of my other cars.
By the way, I don't have any problem pumping gas. Usually I stop after the pump clicked for the first time.
However, the key will turn the other way, and I can start the vehicle right up. I am kind of thinking it has something to do with the shift-brake interlock because if I restart the car and drive it for a little more, the key will come out with no problems.
Any advice? I'm still under my NYS used car warranty..but the dealer I purchased from says they "cannot duplicate the problem."
I just repaired my civic. But after the reparations, I find more problems.
1. A/C clutch:
When the car stop and engine is idle, the A/C's clutch will stop engagement for several milliseconds and engage again. After a while, it stops engagement and re-engage again. When the engine is running at a little high speed, the A/C clutch will work fine. I think there may be two possible problems with it. One is the clutch is slipping. The other is the current for the coil becomes small. Does anyone have idea on how to diagnose it? If the parts fail, what is the cost to repair it?
2. Acceleration delay
When the car accelerates from stop, if I press the gas pedal a little bit hard, but hold the gas in the same position during the acceleration, I feel the engine accelerate slowly for 2-5 seconds. SUDDENLY, the engine generates much more power to accelerate the car quickly. It is an acceleration jump. This has no relation with the transmission (mine is automatic transmission) because I can feel the transmission shift. This sudden acceleration is different from transmission shift. Also, I can hear the great noise from the engine. I feel the noise is caused by increased turn speed of engine. But if press the gas pedal gently, the car can accelerate smoothly.
As I just mentioned, I repaired my car a few weeks ago. One repair was the pipe before the 3-way converter. The garage replaced it with a new one and the fee was $140. The other is because my car failed in the emission test; the garage replaced my oxygen sensor. The fee is $170.
I don't know if the above reparation has relation with the current problems in my car or not. But I feel there may have some relations between the oxygen sensor and the delayed acceleration. Because after the replacement of pipe and before the replacement of oxygen sensor, the acceleration is the same as before. But after the replacement of oxygen sensor, I feel something different in the acceleration. After several weeks, I feel more detailed difference.
Looking forward to the help of experts.
Thanks in advance.
Also how will I be able to contact some of the owners in this club that have posted similar issues?
Well if they have to replace Freon 12 with HCFC-134, then they have to vacuum out all the F12 and refill with HCFC-134, also fittings need to get changed too. Keep in mind HCFC-134 is not as efficient as F-12. Your A/C won't be as cold as before.
Have you taken your car to another mechanic to get second opinion?
Good luck,
bjk
I don't see anything here you couldn't do yourself - typical ignition system maintenance.
R-12 to R134a retro... There are DIY conversion kits for those too. As for the R-12 being more efficient in YOUR system, you have no choice on the matter anyway - you can no longer service R-12.
I would say no more than $200 tops for all the above.
As for the delay is it possible that the a/c clutch is kicking off as it should during a quick or hard accel? If a/c is not on then it could be a timing related issue but not totaly for sure on that. I will try and think of more as well as trying other like cars to see if it is possible to be normal proccessing delay..
If any tune up components are worn and or aftermarket it can also cause some of these problems as the car runs best with factory plug wires,cap and rotor and ngk or ND plugs.
Thanks for your reply. Here is some new information.
As to bjk2001’s question, I do have another mechanic evaluated it. He also told me the refrigerant need to be replaced.
As to gasguzz’s opinion, thanks for your suggestion to DIY the tune up. But I don’t know how to replace the PCV valve and fuel filter. Is there any good reference?
Actually, pep boy ask for $90 for the refrigerant replacement and $300 for the tune up. I do hesitate to let them do the tune up.
As to auburn63’s question, the clutch is abnormal. Because it disengages only for several millisecond and engages again immediately. Also, even if the temperature is high in the car, this problem happens too. The a/c do blow cold as usual. Also, this happens only when the engine is idle. When the engine turn quickly, there is no problem.
I have tested the acceleration delay without a/c. It happens too. When I hold the pedal in one special position, this problem almost always happens. In my last reparation, the mechanic told me the spark plug is not well replaced. Other parts are still Honda original parts without any replacement since the car was bought. (Current mileage is 107k)
As to the shaking problem, it is fixed now. This afternoon, I have another mechanic checked my car. He re-plugged the plug socket and the shaking disappeared. But the acceleration delay still exists. The second mechanic think it is caused by misfiring.
Thanks for all of you.
Fanglu
turns out there were two separate problems, the key he had made was just slightly short than the original, a mistake made in the grinding. because of that, the key could not press the the mechanism to release the key. he waited several hours until a locksmith came, and even then took nearly 40 minutes to get it released.
the second problem was that there is a chip in the key which is required, so he would need to get a duplicate from Honda, special order, not just getting one made at Walmart (which is where he got it done). he placed the original key near the ignition, and he was able to start the car with the replacement.
you would think this sort of thing would be explained in the users manual...
Thanks for the help from you guys. I repair my car by myself and only cost me $4!
Today, I replace the 4 spark plug by myself. Everything is fine now. No acceleration dealy, no a/c clutch disengagement. For the a/c problem, I think it is because the engine may be stalled because of the bad spark plug. The automatic control system try to disengage the a/c to remove the load of the engine. Now the spark can generate good spark, so the engine can run powerfully. So the a/c need not be disengaged any more.
The old spark plugs have very large gap, so the sparks may be very bad. That caused all of the problem.
Hope to give you enough information to help you to deal with your car.
Find a shop you trust and get it looked at ASAP!
It has nothing to do with owner's manual or any car design. It is designed in gas station refeuling gun. To prevent over flowing the gastank and cause gas spill. Correct me if I was wrong. There is built in mechanism in the gas gun. It's pressure sensitive when you fill the gas tank almost full the pressure will increase due to less space left in the gas tank, so it will trigger off the gas gun. You could only fill up slowly to prevent trigger off (built up too much pressure in short time) the gas gun.
bjk.
Sorry user osum02 (post #1324), for not being able to provide you with some insight, but I wanted to write to let you and others know that I have a similar problem, and maybe many more 2002 Civic sedans owners have it, too (please speak up if you do!)
We plan on taking it to the dealership after my husband returns.
1. Difficulty starting the car in the morning (the car is usually parked in the garage). Takes several tries before the engine will start.
2. "Dinging" noise after the car has been turned off. It lasts for several minutes before the noise will disappear.
If the above has happened to others, please let me know if they are very serious. My husband is still driving the car (no time to take it to the dealership until a week from now).
I don't belive the dealer who told some one who posted that hondas are known to give you a static shock
I have heard that certain tire can cause static
it's the material they use to get less resistance on the road
I have had static shock with other cars but i think it was my clothing anyway i would hold the key and touch the lock with the key the arch would go from the key to the lock and i wouldn't fell a thing
Many Thanks!
TJ
Could you elaborate on this "extended crank"? Does it happen in the morning or afternoon? How often ? Does it happen when engine is cold or hot? We don't have this problem on our 02 EX auto. How long do you have to crank it? Do you crank it once or twice or until it start?
Have you taken your car to different dealer?
bjk
Tks..... Rody
Yes, the new platic gives off vapors that may fog the windows in a new car (depending on humidity, etc.). It's not a hazard and will go away (parking with the windows cracked open a little helps).
But the "oil" substance? What does it smell, is it coolant? Check under the dash for a hose leak.
Civics of late seem to exhibit low fuel pressure when the fuel is at some 1/8th tank (or lower). If this is the case, then it's "normal".
Relax folks!
Would you please elaborate.
