Saturn Maintenance & Repair
Also, with that many miles on it, you could also be looking at a bad coolant temp sensor. It ins't what's causing your converter to code, but it could be contributing to the problem. The universal model is about $6, and is solid brass instead of plastic so you'll never have to replace it again. Worth the extra $6 just to be sure, but that's up to you.
Is your car blowing any smoke? If so, what color - white, blue, black?
It was probably a pressure test they did - they cap the radiator and pump air in the system, and if there's a leak it will squirt the fluid out to where they can find the leak. If this isn't the test they did, find a different shop and get this done. As for your #2 question, it could very well be caused by #1, but right now getting your coolant system fixed should be your top priority. If fixing #1 doesn't fix your #2, you may have damaged your engine by driving it without coolant. Either way, keep us in the loop.
I have a 93 SC1 that is doing the same thing as yours with the exception of the noise being more of a hum then a clicking sound. All your other symptoms are exactly the same.
hello everybody,
please help me !! i have recently bought a used '99 saturn car, L2 SERIES.
the problem is the car wont start in the morning due to moisture. if i start the car in the afternoon it runs perfectly fine.
i took it to the garage and they said it was a starter problem , so i had it replaced and got it home. the next day morning when i again started it , it didnt start.
i took it back to the garage and now they have said that it could be a wiring problem..
i have spent close to 300 bucks already when i havent even used it. what do you think i should do and would it be a wiring problem. please suggest what i need to do next .....
The starting issue is your real problem and is related to the "smoke". if it is white smoke it is due to coolant getting into the cylinders. Check the condition of your oil, if it is milky and not normal you have a real problem related to your heads and can lead to engine failure. If you see oily residue in the coolant overflow this is another bad sign. This can be a bad head gasket or cracked head.
Pull the spark plugs and check their condition. If one looks overly clean it could be the bad cylinder since it has been "steam cleaned".
This is not a problem that will go away, have it checked ASAP.
The mirror is hanging on the side of the door and the glass is gone, and a piece is chipped off. About how much can I expect this to cost? Also what is the repair time for this, is it complicated? Can I replace it with a manual, will that be cheaper?
I would also try to have the car looked at my another dealer or an independent third party. sounds like a computer problem. Check the lemon laws in your state,
You may have one. Good luck
John
Routine
I change the oil every 3K, clean the carbonized throttle bodies at 20K, flush coolant sys annually, rotate the tires every 6K, and for 5-spd manuals: change the transaxle fluid every 50K, EGR 30-40K, air filter 10K, plugs/wires 60K, serpentine belt 100K, O2 sensor when I screw-up and use the wrong throttle body cleaner...
I bought the car new in Fall of 1994, so the replacements are many, but pretty good for 11 years of service:
6 rotor turnings (solves vibration when braking)
2 sets of front rotors (due to turning and wear)
2 sets of front bearings (waited too long to get new rotors)
1 set of front brake calipers - 190K
1 electronic ignition module (premature failure) - 25K
4 sets of tires
5 batteries
1 cooling fan (radiator) - 190K
2 alternators
1 catalytic converter (1 pending, strange...) - 190K
1 TXV (thermostatic expansion valve - A/C) - 219K
10 O-rings replaced (A/C, one-time deal) - 219K
1 radiator - 219K
1 gear shifter bushing (famous Saturn problem fixed w/ 10-cent zip-ties) - 219K
2 tensioners - 30K, 190K
1 parking brake handle (teeth worn down)
1 hood release cable/mechanism (under dash)
Unaddressed Issues:
Air bag code (idiot light flashes)
Center console backlight failure
Cruise control intermittently throttles-up until driver manually disengages
Burns 1 Qt oil every 750 miles (seems typical for this engine) - keep case in trunk
Decreasing milage (24-27 mpg) - signs of age?
Windshield is badly pock-marked - like a gradual sand blast over the years
Everything else works --> power windows, original clutch, original A/C compressor... (knock on wood)
Anyone have a catalytic converter last only 20K? Maybe it's due to the extreme oil-burn in this engine causing heavy deposits in the converter?
I have the 94 model and i was wondering what the trick is to getting the heat casing off the battery so i can change it. any suggestions? thanks!
PS- ur not alone!
Last night happened again while on the freeway: while cruising around 55 mph, acceleated to pass another car. Car hesitated to accelerate, then after a few seconds did accelerate, then downshifted into 3rd while accelerating. After passing the car, my car shifted back into 4th. 20 seconds later while cruising around 65 mph, the car started to buck a bit. Put it in neutral and RPM dropped to about 300, then engine died. Was able to restart. I am unable to make the car stall on-demand.
There is a hill near where I live. When I accelerate to go up this hill, car does fine, but once I top out and begin to come down the other side and begin slowing to come to a stop, the car often stalls (4 out of 8 tries). Once, it came to a complete stop and did not die but idled very rough for a few minutes (which means it can't be the Torque Converter Clutch, right?). Engine Warning Light came on for a few minutes but then went off.
Any ideas what's wrong? The mechanic who replaced the fuel pump thinks it might be the torque converter clutch or the solenoid-driven valve used by it. I am wondering if it isn't the Throttle Position Sensor.
I am considering unplugging the Torque Converter Clutch as a way to rule it out. Any concerns in doing so?
- Michael
what is "gear shifter bushing?"
I am having a problem with my 94 SL2 gears where I can not shift them when the car is started. No problems when the car is off. Someone suggested it might be a synchromesh problem. I have about 103,000 miles on my car.
Andy
someone at my job also said that it could possibly be my timing belt due to the milage on it...so...does anyone have any ideas?
speedometer didnt get the right reading
a slow lead of something...i cant remember what he said
ems failure (i think thats what he said)
and i cant remember the 4th one
he reset my light and told me to see if if comes back on, so now i guess i wait...thanks for telling me to do that though
i had a cyl 1 misfire p0301 and a camshaft position sensor error p0310 i believe i changed the plugs wires coils gas filter ects i then had a cyl 4 misfire p0304 but it was on and off not all the time the car drove great for 3 hours then like crap i put it on the compuyter at the shop for 3 hours it said cyl 4 misfire he ran tests on everything nothing came up with a problem everything checked perfect went to another shop checked the ohms on the wires coils perfect changed the plugs 4 times after went away for 5 minutes 1 hour 3 hours came back each time switched the cyl 1 and 4 wire at the coil thinking maybe the wires got switched ran great for 1 hour then got a cam shaft position sensor then the next morning got a cyl 1 misfire camshaft error was gone switched the wires back stayed on cyl 1 misfire took my msd coil off put back on old coil cyl m1 misfire took that coil off bought new stock coil put it on cyl 1 misfire took it back off put back on old stock coil cyl 1 misfire all my plugs are black the same black pretty much now here is were it gets tricky when it said cyl 4 misfire i pulled the cyl 4 wire off while it was missing it ran even worse very confused and mad i put it back on and pulled the number 1 cyl wire off while it was missing no difference apparently it has been cyl 1 the whole time but it was reading it as cyl 4 after i pulled the wire off it is now reading it as cyl 1 consistantly i pulled the wire clip off the injectors one by one while it was running cyl 1 gave me a noticable difference cyl 2,3,4 gave me a difference but not as much as cyl 1 all in all injectors seemed good the car is running rich but i do not smell gas i do smell some oil burning but it does smell normal for a saturn with 152k on it so i do not believe it is the regulator i also did a compression test each cyl has about 195psi so that checked out ok so i don't think it is the head i have spent a lot of money trying to figure this out and nothing is working i am about to go buy the module for $130 at pepboys and try that if anyone can help me with this at all i will name my next child after you thios has been going on for weeks and appears to be getting more often now everytime i start the car it idles great until i give it gas and let it rev back down as soon as it revs back down it starts missing before it just did it whenever it felt like it please any help will be greatly appreciated
Also, does anyone know how to reset my radio. There is no Saturn dealer nearby and I don't have the damn code!!! I'd like to reset the radio, then disarm this security feaure. Thanks
Has anyone seen something like this? Any ideas?
