Pontiac Bonneville General Maintenance and Repair
1323335373844
    rsutter1000rsutter1000 Member Posts: 1
    Did you ever get a reply to your heated seat problem? My 2002 Bonneville has the exact same heated seat issue.
    connie4connie4 Member Posts: 1
    I HAVE A 97 BONN.SSE 100,00 MILES AND I AM HAVING A PROBLEM WITH THE INTERIOR LIGHTS COMING ON AS I'M GOING DOWN THE ROAD AND WON'T GO OUT. I'VE ENDED UP TAKEN OUT THE FUSE TO GET THEM TO GO OUT BUT THEN I DON'T HAVE ANY INTERIOR LIGHTS. ANY SUGGESTIONS ON WHAT COULD CAUSE THIS? ALSO WHEN I APPLY THE BRAKES TERRIBLE SCRUNCHING SOUND FROM REAR ALMOST LIKE LEFT REAR BRAKE DRUMS ARE GRINDING AND SCRUNCHING. HAVE REPLACED BRAKES AND ROTORS BUT STILL HAVE THAT PROBLEM. CAN SOMEONE PLEASE HELP ME? WOULD BE GREATLY APPRECIATED THANKS
    96bonnie96bonnie Member Posts: 1
    on my 96 bonneville sse i had a similar intermittent problem with the dash and other electrical components
    after i replaced bulbs/ starter/ battery etc i found that the positive battery cable, where it connects to the battery is actually poorly designed as two seperate cables.
    these two cables ends are in one rubberized "boot" through wich a bolt passes and screws into the positive terminal on the battery.
    pull the boot back and there will be corrosion in between the two cable ends. clean and seal the ends. tighten the bolt and no more compass/information center/gauge reset problems!
    hope i helped-v
    ferris3ferris3 Member Posts: 1
    I have a '93 Pontiac Bonneville and I'm having major issues with it. A couple of weeks ago it died on me so I replaced the battery and alternator. It now runs but there is this loud banging or clicking noise near the engine. I've had 2 people tell me it may be a rod in the engine. My situation is that I am a single mom of 2 kids and I really don't have the money for diagnostic testing let alone to get it fixed if it is the engine. How much could I sell this vehicle for or does anyone know of how I can get cheap/free diagnostic testing?? Thank you so much for any replies!!
    Kelly
    mpetroskympetrosky Member Posts: 1
    I had a burned electrical smell when I turned up the fan speed for more heat. On the 5 speed fan switch the 1st 4 speeds do not blow any air, however on the 5th or high speed fan I get a very weak air flow. Is this problem the blower motor or something else. If so where is the problem located in the car?
    jgtmiljgtmil Member Posts: 19
    I read some messages earlier about the fuel gauge being wrong. I had the same problem so just to try something I put a different "gas cap" on this fixed my problem. some of you with the same problem may want to try this, if you have two cars just swap them for a while to see what it does for you before you buy another...
    farmguy99farmguy99 Member Posts: 3
    We have a 92 SE that had a similar clunk in the front end. Turned out to be nothing more than the bushings for the swaybar linkage. $50 in parts and 1/2 hour in the driveway and the problem was fixed.
    We have a 92 SE that has developed a severe oil/coolant leak. Mostly coolant with some oil mixed in. It seems to be coming from the top of the engine on the rear bank of cylinders. I suspect a manifold gasket leak. I have seen the thread on a similar problem with later models. I am wondering if the replacement procedures for the 92 are the same? Worst case scenario is a head gasket, but I think the leak is too high up to be that. Any advice would be appreciated.
    I don't want to spend a lot of money on it, as the book value isn't much with 114,000 miles on it and being 13 years old. Just want to fix it good enough to sell it. We got a 2002 SSEI, Supercharged this weekend to replace it.
    We just bought an 01 SSEI, Supercharged. The manual and the sticker on the fuel filler door say use premium unleaded fuel (91 octane)
    I have been told that the computer and anti-knock sensor will compensate and the engine will run fine with 87 Octane. Only that fuel economy and power may suffer.
    Any thoughts?
    motoman1motoman1 Member Posts: 1
    I have a 91 bonnevile which is missing eradically for about the first 30-45 min. of operation. Thinking it being a fuel delivery problem,changed fuel filter, no change. Installed new plugs as it has that typeof miss. Ran perfect for the 700 mile trip Thanksgiving(did that trip on one tank of fuel). Got home, next morning it was missing eradically from initial start-up untill driven some 45min. Shut it off for 5min., re-start and process starts all over again. Check engine light has never come on prior to , during or after shut-down and restarting of car. Steer me in the right direction, fuel problem, ignition, or electronic? Thanks..Brant
    thomjohnthomjohn Member Posts: 2
    If it is none of the above pulleys it is most likely the
    bearing between the trans & engine. The bearing will get dry and start to radiate noise like a pulley going out.
    If it gets real bad your looking at 10 hrs of dealer time
    to change out a $6.00 bearing. The best to you and may it only be a pulley.
    Did you ever get this solved-how many miles did it have
    on it when it started to have the noise?
    dadscar2dadscar2 Member Posts: 10
    Did you get this fixed, and if so, how? I have a 93 SSEi, recently acquired, and the RV mirror shakes more than I want it to. Thanks.
    I have a 93 ssei and rebuilt the steering column radio switches rather than paying the dealer $228 for new ones. If the controls on the radio itself work, but the steering column controls do not, Check Instr Panel fuse box, fuse 24.If fuse is OK, the book takes you thru a lot of other wiring tests and will not go into the switches themselves. but most likely the rubber (?!?)switch plungers which operate the microswitches have deteriorated and no longer are stiff enough to depress the microswitch. If you want the instructions on how to remove and test your switches, then repair them, let me know as I have done the work on it for my 93 and now have working SC radio controls.
    thank you I will check my fuses again but if you would let me know the rebuild info more so where to get the parts.
    The procedure will be to remove the airbag module on the steering column and remove the left and right radio control switches which are wired together into one plug which connects to the back of the airbag bracket. This procedure is labor intensive and the only parts you will need is 10 or 12 5d common nails available at any hardware store. These will subsitute for the deteriorated rubber plungers which no longer activate the microswitches on the circuit boards underneath the Volume, pre-sets, AM/FM etc buttons.
    1) disable your driver side airbag--remove IP fuse #7, and to be safe, disconnect the negative battery terminal (check to see if you have a radio activation code as you may need that to operate the radio after you have disconnected the battery). Let the car sit for 15 minutes so the airbag capacitor fully discharges so that it does not accidentally inflate.
    2) While you wait, spray some liquid wrench or other lube on the four star socket bolt heads on the back side of the steering wheel. My 93 takes a star socket T-30 with a 1/4 in drive for a socket wrench. Loosen the four star bolts till you can pull loose the airbag module far enough to disconnect the a) airbag yellow connector, b) the black radio connector plug, and c) the single wire which is the horn wire (leave it in the horn well).
    3)Turn the airbag module over and remove the 4 hex screws that hold the radio switches to the module (you may also have to remove another bracket to fully remove the switches together). You are now looking at the $228 (non-serviceable) part the dealer will sell you.
    4) Start on one switch piece, with the switch buttons face down, and remove the two inset hex head (3/16 socket should do it) screws which hold the capper housing on top of the bottom side of the switch circuit board, feeding some of the wire cluster thru the access hole on top of the capper housing to allow you to separate housing from circuit board. Lifting up the circuit board carefully, you will see the mechanical workings--the rubber plungers which push against the little white microswitches on the circuit board. put a piece of tape over the plunger holes if the plungers tend to slide out easily. Mine were dissolved in the plunger tubes and I had to clean them out with rubbing alcohol and q-tip.
    5) To test your switches, plug the black radio female connector to the male end on the steering wheel shell, reconnect your negative battery terminal, and turn the key to ACC to get power to the radio. Get your radio working using the radio set controls. Now try depressing the small white micro switches on the circuit board you just removed. If they function, your switch is OK. Repeat the procedure for the other side.
    6)Assuming your switches are OK, the challenge is to remove one of the plungers to determine the length. I trimmed the 5d nails to length with wire cutters, and installed them into the plunger tubes, having filed down the nail heads with a grinder so they are thin enough to not stick too far out past the end of the plunger tube. This will all become intuitively obvious to the casual observer once you get into it.
    7)When putting your new plungers back in and the switch housing back together, dont screw the 3/16 hex head screws in all the way. My switches worked after I found the right combination of length of the nail plungers and leaving the hex screws loose. I had to do this because none of my rubber plungers were intact for an accurate measurement. 8)Once you have your switches working to your satisfaction, reinstall the switches on the airbag assembly, plug in radio, airbag and horn connectors, tighten the four star socket bolts (a little on each one, then another till all are tight) to reconnect the airbag assembly to the steering wheel. Reinsert your airbag fuse #7, turn the key on test your steering column controls to make sure they are still working. I have to tell you, I ducked down when I first started up the car--fearing the airbags would deploy. But they did not and I laugh about it now.
    There you have it, just like a woman's skirt. Short enough to keep you interested yet long enough to cover the subject. Hope this helps you and anyone else who has trouble with their radio steering column radio switches and does not want to spend the money for new ones. Hopefully if you do get new ones, they will not be made with the same rubber plungers the originals came with.
    norm45norm45 Member Posts: 4
    Have same problem with my 92. Pound or hit the hood with your hand in the very front a few times after pulling the hood latch. If it opens, lube up the latch mechanism with wd-40 or similiar lube. This works for me. Once in a while it sticks and I have to hit the hood again.
    freddy111freddy111 Member Posts: 5
    Hello
    I own a 1996 SSE and just love the car. I have 178,000 kms on it with no major problems. Get consistantly 35 - 40 mpg at 125 kph. But like everyone I want an SSEI and I found one with 58,000 kms on it. But I'm wondering how hot this one will run, because my 96 SSE runs very hot and I am not able to tow anything with it. Will this 98 SSEI be any better and can I tow with it? Would appreciate any help.
    vosatka68vosatka68 Member Posts: 1
    can someone please help me. i just bought a 1990 bonneville with 130k miles from a one owner. i love this car but there is one problem that has me stumped. when you try to enter the car, and the interior lights come on, they dont go out if you do not enter the car. you have to open the door and then close it. sometimes that doesnt even work the first time. if anyone can please help, direct me to the right place or anything, please let me know. thanks so much.
    craig
    decemberdecember Member Posts: 7
    I just bought a 1994 bonneville started it and backed out of driveway when it died. I was adjusting the electronic seat controls when it died. My power windows also do not work. Any ideas.
    imidazol97imidazol97 Member Posts: 27,174
    Does it restart?
    If it restarts, I'd check grounds inside the car. There is one next to the emergency brake, one next to drivers seat between it and door and same on passenger side. In some cars those get corroded with moisture and whatever causing funny things to happen. But usually not including engine dying.
    You may have to adjust the latch,sometimes they get move down and they just latch too tight.Do you have to slam the hood to close it?If so try rasing the latch.
    If hood is ending up high, you could lower the two rubber supports on each side to take vertical tension off the hood latch. It's also possible the hood latch has a cable that's binding up. I'd check by taking cable off latch (if possible) and pulling to see if friction seems high. If so, try some graphite based oiling -- wouldn't use motor oil myself.
    wingnut8wingnut8 Member Posts: 9
    I have a 96 bonneville running rough & showing codes p0135 & p1133. Any ideas?
    curhollcurholl Member Posts: 2
    Car stalls at stops or while in reverse or sometimes when idling after cold start. alot points to a crankshaft sensor i scanned it with rental scanner and no codes were visible or stored as the check engine light comes on intermittenly. one guy told me to pull the plug from the tranny ??? are these sensors hard to change for the back yard mech haha thanks curholl
    first time user of this forumm not a reply to b mauzy on the 90 bonne stalling problem
    alcanalcan Member Posts: 2,550
    P0135 = O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
    P1133 = O2 Sensor Insufficient Switching (Bank 1 Sensor 1)
    Might be a dead upstream O2 sensor on the front bank. Check first for the sensor wiring harness melted to the exhaust manifold, or a disconnected or dirty connector. If ok, check fuse #5 (20 amp). This also provides power for the EGR and cannister purge solenoids. If all's ok, probably a defective O2 sensor. Can be checked for operation with a scan tool.
    I checked all the connections this afternoon but then my daughter had to go to work. I will check that fuse tomorrow.
    Just the o2 sensor should make my teenage daughter happy for an hour or so. Thanks again.
    Yep, I read your reply on the other site where you'd posted the problem. I'm one of the site administrators there. Glad to hear you got it sorted out. Good luck on keeping the teenage daughter happy. LOL
    The vents do not seem to be putting out as much air as they used to on my 95 bonnie. the blower motor sounds fine but it seems as if the air way is restricted. When I first start the vehicle the climate control blinks for a while but i don't know how to tell what that means. By the way this Forum has been very helpfull thanks to all who respond.
    Is it dual auto control air conditioning?
    The blinking indicates an error from the programmer (control) unit down on the heater box. Something is not working and you'll have to have the codes read by a mechanic with a TechII that can see the codes for the things beyond the engine control computer.
    A likely problem is the blend door for heat and cool air which is linked to the programmer by a rod at the bottom or the top door which controls passenger vs driver blending and is controlled by a small electric motor connected to the programmer box by tiny wires and a connector.
    The first thing to do is determine if you have vacuum control. Does most of the air come out the defroster and a little at the heater outlet at the floor? That could mean no vacuum and would explain why you hear air but get little effect from it. Check for that first. Turn on unit without starting motor. See where air comes out at defroster and floor. Then start the motor and vacuum should be able to change where the air is directed. Usual problem is when set for mid dash vents air comes out defroster instead which floor choice will work--if the vacuum from engine is reaching the programmer.
    Something I've run into numerous times is refrigerant leaking from the evaporator core, leaving a film of compressor oil on the core. Dust sticks to the core and eventually does a great job of blocking it completely, restricting airflow. Remove the blower motor and use an inspection mirror and flashlight to check the evaporator core. Should be reasonably clean. I've gotten passable results for some customers who weren't concerned about the AC not working by using a pressure washer to clean off the core, but the proper repair (obviously) is to replace it.
    palaltpalalt Member Posts: 25
    Your Bonneville might not be running as hot as you think. I own a 93 SSEI that at full operating temp looks like it's running at about 225, the needle being just above the mark between 200 & 240. At that point, the secondary fan turns on and it cools off to what looks like 210, then the cycle begins again. If you connect a scanner to the diagnostic port, while the needle shows 225 the temp is actually only 208 which is about what they're supposed to run at. I would say the true temp from the sending unit is not being correctly reflected on your guage.
    Also, to the guy that talked about his car not having vent circulation, I agree with the earlier response you received about the evaporator being clogged. I replaced mine for the very same reason and vent flow was vastly improved.
    I'm a longtime Pontiac guy. Currently own a 93 SSEI, 95 SSE and an 02 SLE, so while not being a certified mechanic I'm pretty familiar with Bonneville problems. Now If I can only resolve the ABS & Traction Control lights that stay on in my 93 SSEI that spits out multiple codes, I'd be happy. I've replaced both rear wheel sensors to no avail. Would like to know if the pump or computer would be next logical step. Errors point to both.
    Which ABS codes are current?
    Thanks for your responces i will give both of those a look.
    alcan! The ABS/Traction Control lights stay on solid and the codes I get are:
    033 R/R Missing 037 L/R Missing
    045 Inlet Valve 061 Pump Motor Run Fault
    It was suggested I replace both rear wheel sensors first, which I did. No change, still get the lights as soon as the car is started. This is on my 93 SSEI.
    I have owned an SSEI for years and I think you'll find out that the 5% savings you will realize by buying regular instead of the recommended premium fuel will be more than lost in the loss of mileage. This says nothing about driving the car with the computer retarding the engine to compensate for the crap gas. I tried one tank full of regular and lost 3 mpg and it ran like crap. Buy the premium fuel and enjoy the supercharger.
    dkurrledkurrle Member Posts: 20
    I have read a lot of post about this, but not sure if it is the same as my problem. My climate control display on my 96 bonneville flashes once and a while. When this happens my heat will start to blow out cold air. The only solution i have found is to manually go back and forth with the temp guage from 60degrees to 90degrees, and usually after about 5 minutes of doing this, it will finally kick back on. Or sometimes if it does this, i will simply turn the car off, then back on and sometimes the heat will kick back on. Also on a long trip, i wont even have the heat on, but my cabin of the car gets super hot, almost to the point of unbearable. Heat seems to be comin out of the floor vents, but not in a fast manner. A few weeks ago my heat was working perfect, then i had to replace my battery, and once i put a new one in, that is when the heat startin acting up again. Anyone have any ideas. Could a ground wire be loose? I heard some talk about vacumn lines, does that have anything to do with it? if so where are these located? Can i just reach in and examine them. Any ideas would help greatly since i am a poor college kid who is really cold this winter!!:) Thanks
    on my 96 bonny, whenever i hit the defrost button, the A/C light always comes on. Is this normal? I didnt think that the AC should come on when i am lookin to defrost. Anyone want to share what happens when you turn on your deforst. Thanks for the input!
    On any GM car I've ever had, the A/C Compressor engages on defrost cycle to dehumidify the environment. What you're seeing is normal.
    mikecrtmikecrt Member Posts: 2
    While driving on freeway, car gas pedal did not respond. I coasted off freeway. When restarted, car would not go in reverse, but only forward. It makes a clanging noise when going in drive. Is tranny shot or might no reverse be due to something else? Thank you for the help.
    You may want to check your tranny fluid first. the proper procedure is in the owners manual. When the fluid is low it will cause that to happen.
    I have a 95 ssei and this forum has provided a lot of help. The boost guage at idle reads in the negative. the owners manual reads as if it should read 0 at idle. is this normal or did I miss read the manual?
    4lewis4lewis Member Posts: 2
    This car has an issue - the alarm / security feature does weird things. Now, it will not let me start the car. The Dealers want anywhere from $500 to $1,000 to fix it. That is not econmomically feasible or possible at this time. I am looking to bypass the security feature, but the dealers say it is not possible. The last dealer told me it was a bad battery and the car works fine now. The battery they replaced was 8 months old... Now, the car is dead in the drive way with the new battery.
    What is the sequence to turn off the security ? I bought the car used 4 years ago - never having this issue. The alarm light stays on after it is started for about 1-2 minutes and shuts off, but never any problems.
    Please advise. Considering a bulldog by pass module with remote starter. What do u think ? Will the car have to be able to start before doing this surgery ?
    Really disgusted as I love these cars. Had my last 88 (with the c motor) for 250,000 miles, gave it to the american heart association to live on !
    I'm not sure which system you have (pass key, II) but if you have a visible chip on your key it is possible it may have went bad. That chip provides a certian amount of voltage resistance which in turn is used as the key code, also another common problem is that the two wires coming from the ignition switch to the alarm control module usually get broken at the ignition switch where you turn the key. If you can trace those two wire and put the key in the ignition you could check both the resistance and the connection,,,,
    Why is the battery dead?
    A battery that's putting out low voltage because of drain problems or charging problems will cause systems on the car to do funny things. Battery problem needs to be fixed to diagnose others. Is something draining the battery? Glovebox or trunk light staying on?
    When you sit in the car and turn the key to "on" without starting the car, what does the "security" light do? It should come on and remain on for a few seconds and then go off. If it stays on then you have a problem reading the key, most likely or some other more uncommon problem.
    If you have a light that stays on and won't let you crank, you can wait 3 minutes and then the light goes off and allows you to try again to insert a key with the proper chip in it. If you have a different key, try that one. If key resistor chip read is the problem, rub it with a pencil eraser and use rubbing alcohol on the key and insert into the lock cylinder wet to try to clean the contacts inside the lock. If you still have problems, there is a bypass method--same one they use when installing a remote start setup!
    dmax_me_amdmax_me_am Member Posts: 6
    It’s normal. Called a dry air system many cars Mfg. use it to first dry the air before worming it to defrost the window more efficiently. On some cars the AC light comes on and others don't, most don't. To me I like the reminder that I am using more GA$$$$
    but the light may indicate a request for defrost settings and the compressor may not be running if the outside temperature measures somewhere in 40s or below (Fahrenheit). The compressor isn't run below a certain temp to protect the compressor.
    fallsalotfallsalot Member Posts: 3
    I have the exact same problem as you have described. I have a 95 bonneville ssei. The dealership diagnosed it as a control panel malfunction. I know this is not the problem becauuse I installed two other control panels in the vehicle and I had the same problem. I check this site daily. If you have found the solution to your problem I would appreciate it if you would post it on this forum. THANK YOU!
