Meade
... That'd be the first thing I'd do.
Meade
I also suggest a bottle of techron a few times a year to clean injectors and other intake areas.
My Pro5 has not experienced this problem after 30K; my sparkplugs were replaced last year as part of the standard maintenance and this baby continues to hum. Replacing the sparkplug wires is inexpensive and reasonable. A diagnostic may not be a bad idea if the problem continues.
wilson
Many things can contribute to uneven idle speed: MAF/MAS, EGR valve, PCM, plugs, plug wires.
On my '99LX, with the 1.6L engine, it's located behind the top of the engine, toward the driver's side. It's pretty hard to get to. The easiest thing to access is the electrical connections, so you can check the impedance across the pins (to make sure the electrical components are OK). Pulling the entire thing off to clean is a 2-3 hour task, so I pay the dealer's shop to do that.
Meade
Doesn't sound like a very comprehensive diagnostic test. Did your dealership do it?
I did a continuity test on the old switch and it failed. So buying the new $25 switch was worthwhile.
As far as this correcting the low idle issue when I initially shift into neutral, I am not sure yet. It still seems to drop too low initially (250 RPM) before coming back up. I need to check the amperage output from the alternator and also check the spark, wire resistance, cap and rotor, etc. I will get it all straightened out by the end of the summer and hopefully share some answers.
Tim
Meade
Perhaps related: two years ago check engine light came on. Turned out that oxygen sensor needed to be replaced. The light is on again. I have not yet had it diagnosed. There is no relation between timing of check engine light and badly behaving radio but thought maybe that whatever is causing the check engine may also be causing the radio.
Disconnect and reconnect the wire harnesses. Corrosion forms on these eventually and these motions should cut through it.
If all else fails, replace it. I put in an aftermarket (as the factory unit is very expensive), and I haven't missed the tape player (which I did get as an add-on option). However, I did put in a unit that offers a front AUX input jack, so I can plug in my iPod.
I'd also check to see if the drive mechanism may have gotten misaligned or any components may have gotten loose or worn.
In my '89 323LX, the manual sunroof would tilt up, but not pull down and retract. Turns out the main drive gear was loose and wasn't engaging the cables enough to overcome resistance in the retract mechanisms. All I had to do was tighten a screw and it worked perfectly again. Too bad it took me 2 years to overcome my fear of popping off the rear-view mirror to get at the main drive gear. I was going to be putting it up for sale, and I figured I may as well try fixing it before showing it. Gads, I miss that car.
When I change the spark plug, I found that the third plug was terrible. There was some white deposit like ash all over the porcelain insulator, the wall of the plug hole and the surface of the rubber connector. I don't know what caused it. The other 3 spark plug looked fine. I am going to change the wires.
Anyone can give me some suggestions what is the cause of the check engine light? what should I do other than changing the spark plug wires?
Check out above link to get an idea about your spark plugs under normal and abnormal wear. As for the check engine light (CEL), most times the CEL denotes an emissions warning/problem. I could be as simple as replacing your air filter or as problematic as your MAF sensor/housing, O2 sensors or EGF going out. Try the simple stuff first e.g. replace air filter, one bottle of Tecron fuel system cleaner in the next tank of gas, replacing all spark plugs and wires at the same time before you lay out money at the shop. Good luck...
Idea: wouldn't it be great if every car had the option for an electronic as well as printed manual? Imagine your Nav screen or your laptop walking you through a repair.
Motor is better, but I don't usually find them in stores. I stumbled across them in the local public library. They don't have the latest editions, but maybe one before. For most of us, that works.
Before you buy, check to see if your local public library carries them. You can then compare them side-by-side before you decide which is better for you.
When I start the car in the morning, everything is fine. After driving several miles. the hesitation starts.
I searched this forum and found in message 31 and 32, someone were talking about a similar symptom. they cited a "protege 4 thread, post 300". How can I found that post? Please help me. Thanks!
mine is a Mazda Protege 99 with 52K on it ...:) I am getting a strange sound
(not periodic) between 40-50 miles ..never heard/noticed on high speeds
i had taken it to the dealer and they test drived it for 7 miles but they couldnt reproduce the problem ..:( ..
1)when pumping the gas pedal .
2)Occurs more on bumps or Turns or UpHill Driving
3)it goes away anytime I apply brakes.
any thoughts on it ????
the problem of low revs on my 96' pro has almost vanished after i switched to premium grade chevron fuel !!
i have put in a couple of tank fulls till now & the problem has significantly reduced, though not completely solved.
i will go ahead and change the plug wires too, will give the feed back then.
thanks guys,
amit
I have 01 Protege and the audio system failed second time, and this time it is not under warranty. I wonder if it's a known issue and if I have options.
While not moving and engine was running I inserted a CD and I got no sound. The radio looks like working but no sound, and the CD is stuck there.
The same problem happened two years ago and the dealer changed the whole system. I think it will cost much considering I lost my job two weeks ago.
Do I have other options; fixing, other brands etc?
B.Insel
