The van only has 33,500 miles. Has anyone had this problem and have you had any satifaction from GM?
The power sliding door on this van has given us nothing but trouble. It won't stay closed in cold weather. I have to fight with it to stay closed. Sometimes I'll hit the button on the remote or inside the door, walk away, and look back to realize it opened up on its own (even in warm weather). Also, when the van is locked, you can still open the power sliding door when you pull on the handle. Just this morning, we looked out in the driveway, and there was the power slider hanging wide open. It opened up all on its own overnight. =(
What can we do? I especially want to be able to LOCK the van! Help?
SJohnS
Anyone else have this problem and know how to fix it?
Luckily the line at the dealership parts window where I went to buy two new circuit boards was so long that I got bored and started taking the light bulbs in and out of the panel! There it was, the base of the brake light was melted through even though while plugged into the unit the lamp bulb filament itself looked perfectly good as new.
Just a 2 dollar fix instead of 2 units at $50.
By the way, what are they teaching in the schools at GM engineering these days?!!! Why would you tie the cruise control to the brake light circuit????? What's next? tires that deflate if your oil is a half a quart low, or doors that wont unlock if you need wiper fluid???
can you tell me how to get to the connector, I have the same problem on my montana
I am new to the site and figured that I needed to post before spending another $3000 on my 2000 Pontiac Montana Van. I just had the rear wheel cylinders and shoes, and then took it back to replace the master cylinder. The problem is you need to press the brakes down instead of just touching them. (Spongy is the word that my mechanic used) My mechanic was not completely satisfied with the result, so he took it to the dealer and had them check it out. They looked at it and said that what he had done was right, and that if I was their customer they would recommend getting a new ABS motor. My mechanic said that he could get one from the scrap yard and put it on and this would be 1/3 of the cost.
Has anyone had a similar problem? If so, do you have any advice?
Suggestions?
Denny Jones
Davison, MI
Tahnks
Suggestions???
Any suggestions on how to fix this problem?
The problem I'm having right now is with the brake lights again, I read about the circuit board being bad in the taillight assembly and checked it out, fried. I have a bigger problem with it now though. The little cannon plug assembly that connects to the circuit board is fried also. I was hoping that the top of the assembly popped off so I could just connect a new plug but the grey piece on top of the cannon plug only holds the wiring in straight. I'm no electrician so I'm not clipping wires, did anybody else have this happen also? Did they just bring it to a mechanic? Any advice on this would be appreciated.
vanh8r
Thanks all.
I remove the plug (yes, the bcm prgrm one), get in the car (all doors including liftgate are shut), I turn to ACC, off and back on again (within a sec.), open a door (chime) close it (chime - seems because there's a key in the ingnition), wait 14 secs, nothing. hold lock/unlock for 30 secs, nothing. Somebody help! what am I doing wrong?
Well, after reading all of the problems about this vehicle as indicated by members of this forum, I cannot help but think I ended up with a GEM. I've had virtually no problems once the warranty expired (in warranty, like 6 seat heaters, an intake gasket at 32,000km, tie rod end, new rim, seat cushion, steering rack gear assembly, insulator bars, and a few other things). Now with 100,000km fast approaching... hard to decide whether or not to buy it out at the end of the lease or turn it back and get something new. All in all, this vehicle has been a dream to own. Not to mention all of the frazzled looks I get from people when they see the chrome rims, and how decked out the vehicle is on the interior. Don't know... it is certainly a tough call!!
Thoughts, Opinions?? mind you this was a $40,000.00 vehicle PLUS taxes (Canadian Dollars) when brand new.
The Thunder is a nice Montana (I think I have only seen one or two of them before) but the new SV6 Montana is also quite nice. The engine (now that it's fixed) and transmission should be fine for another 100K kms ++.
I would compare the cost of a new one vs. the buy out and the corresponding borrowing rates.
dealer $750.00 to change it. Today when I started it there was a very loud tapping sound. I can't get in touch with the dealer until Monday. I was hoping maybe I could get some advice from some of you guys on what that loud tapping sound could be. Any advice would be very much appreciated. Thank You.
I think I might go new unless you really love the van. If I kept it I would probably skip the EXT warranty, they are almost always profit for the seller IMO.
Purchased new May 2001.
:lemon: November 2001 - The first snowfall I discovered the tires and whole traction ability of the Montana was horrible! It just so happened that I had to travel up a small hill right past my dealer and it took me almost 10 minutes to get up with the tires spinning on the thin film of snow.
I went into the dealer immediately to complain that my UPGRADED equip package that was to have inclued tires for better snow and wet traction must have been missed - but they, and GM several times refused any fault. I continue to have great difficulty in low (or high) snow conditions - even with good Michelins on this Montana EX (Extended model.)
:mad: The front right wheel bearing went at 76000km - expensive replacement.
**The front wipers would colide every so often with the right wiper becoming bent at the top 5 inches, requiring replacement. The Dealers says nothing wrong with the wiper motor. This has continued almost every year, including yesterday - which has finally prompted me to submit some opinions on our fair "home grown" GM product and lack of support and service. Upon today's visit to the dealer they say these vehicles (even current models) are prone to this problem and all they can do is re-adjust the timing of the motor sensor - for a fee of course!
The rear wiper spray has never really worked correctly - poor spray and often clogged.
:lemon: Evidence of the poor, disolving head gasket was evident with the coolant level reducing and the low coolant light displaying. This began around 90,000km and I didn't discover/hear about the gasket issue until neat 110,000km - which of course was beyond basic warranty. Why in the world would I want to keep a vehicle past the basic warranty period - hmmm...had my '91 Jeep Laredo for 9 years! - with no trouble - only the front Ujoints went finally at 240,000km!
The front hood has been bubbling with corrosion since ~100,000km, now to the point where all the paint is off all the way across 2-3 inches deep on the underside and a few spots on the top side, all showing a nice contrasting light grey alloy! Apparently this is not covered by the corrosion warranty to 160,000km as the hood is an aluminium alloy and will not perforate ALL the way through to a hole - therefore it is not covered! - right. But we can pay $700-1,000 to fix it ourselves!
The driver seat heater stopped working after ~120,000km.
~120,000km the Air Bag light would come on and remain on. We were advised the air bags would not deploy in this state and had to pay $100 to have this serviced.
~125,000km the Keyless remotes stopped working - no resolution yet.
The air conditioning went at ~150,000km and will cost over $1,000 but they can't guarantee it will work afterwards!
Did I say the traction is absolutely terrible in thin, slushy snow?
Overall the comfort, usability and design of the Montana is good.
The overall quality and and GM's lack of support to stand behind their product is extremely poor. When will they get the message - before it's too late? After last week's GM news for the quarter - maybe it IS late?
:confuse: Why would I ever consider a GM product again?
In response to the person with traction problems? are you kidding me?... If the traction like is coming on alot.. well perhaps you should lift your foot off the gas. Also, you have Michelin tires on it? I do too.. NO complaints at all.. AND I'm driving the van in the winter with the 16" chrome rims on it. I can relate about the seat heaters though:S
I don't know if you still use this website, but I have the exact same problem with my 2001 Pontiac montana. The passenger side quit working some time ago, and since I rarely have passengers in the front, I put off fixing it. Now the unthinkable has happened.... the driver's side has gone as well, and my window is stuck down.
I'm wondering if you replaced the switch yourself, and how much the part cost. Also wondering the best place to pick one up...
Cheers!
Regine
I also baby the trans through the shifting when it gets hot to prevent that hard shift. The codes match up to my Haynes manual and it is internal on the transmission (transaxle). It's cold weather season here so as long as we don't drive very long distances and abuse the trans all is well. We will be going to Texas this summer so I'm thinking this will cause that transmission to go, excess heat won't dissipate quick. But this problem has been around for a year and a half now. I'm getting my money out of it first.
I've had the wiper blade clash, the driver window drag, air bag light, service engine light (with the trans hick-up) and now the PWR STR system is starting to leak.
I've only got just over 40,000 miles and I think that all the electronics that are supposed to help the mechanics troubleshoot and repair our problems quickly are the very things causing the problems.
Just remember, you only need: fuel, air and electricity to keep a vehicle running.
But with all these problems, I check out the van, pull a fuse or disconnect a harness or a fuse, jiggle a cable and the lights go out over time.
Try it and buy a Haynes manual to save some money.
I hope this information is helpful to others with the same hard shifting problems. I also replaced the thermostat and all the spark plugs and wires. This was done because of them being hard to access. The van runs as good as new.
Did the dealer contact GM for participation or did you go direct? Do you have a name? Thanks for any input.
Has anyone been able to fix this or touch them up and if so, what did you use? Thx.
Has anyone else had problems with their transmissions not shifting into overdrive?
