Subaru Impreza Outback Sport & TS
The OBS does get the 16" rims and a few other things. The TS has added some content so it's closer to the OBS than it was in 2002.
-juice
However, I will say that for short people (I'm 5'3") it is not designed too well. I got the arm rest but have to sit close to get the clutch pushed in all the way to start it that the arm rest is essentially useless. In addition, the sun visor is about 1" too short too because of having to have the seat so close. Otherwise, the car is fantastic - great power, good gas mileage, and has gotten me through some snowy days in the last 3 months. I would highly recommend it.
Subaru needs to consider power, adjustable pedals, as I'm sure you're not the only one who has experienced this problem. I know my daughter (5'2") would be another.
Bob
-Dan-
CT is a high-demand region, so you may find prices higher than in other places. Try e-mailing offers to dealers to see if they'll bite. Or see if you can find a no-haggle dealer that already discounts the car to the final sale price.
Van Bortel is in NY some where, and in MD we have Fitzgerald. That's how they sell new cars, but used too, I believe.
Is there a CarMax near you?
-juice
Yep. Subies are in high demand here (something about a dozen ski resorts within an hour's drive...) lol! Read back through the last page or two of posts, a few weeks back the subject came up.
I'd follow Juice's advice... do you really need to work with a salesman if you can research the car online? It is not in their best interests to give you a good deal. Have you considered private party sellers? That will save you some bucks vs. a dealer.
utahsteve
I'll try the email approach, thanks!
-juice
Tuckerdog
Subaru = Full-time AWD (80/20% Split on 4EAT, 45/55 Split on VTDEAT, 50/50 on MTs)
-mike
Basically the Honda doesn't have a center differential so it's a part-time only system meant to be engaged only on slippery surfaces.
The Subaru system is full-time. Even on dry surfaces it can send power to both axles while allowing just enough slip (in the center diffy) to make a U-turn.
-juice
Later...AH
-juice
Subaru's full time system eliminates torque steer and you end up with more neutral handling. The systems are such that you're less likely to slip in the first place, because the power is distributed before you slip.
I'll take B, no question.
-juice
Later...AH
-mike
Toyota had the sludge debacle, and treated its customers poorly, which adds insult to injury. They finally bowed to consumer pressure.
Every brand has its hiccups. Those problems affected Acura and Lexus, BTW.
-juice
Your dealers may not do it, but ask for an overnight or longer test drive. Most dealers around here are closed Sunday. If it's the same there, maybe you could take the car Saturday & return Monday. When I saw the Subaru I bought ( although it was a used car ), the dealer suggested I take it over the Thanksgiving holiday. It wasn't even my idea. So I had it a good part of Wednesday, all day Thursday & a piece of Friday...Well actually I just bought it & kept it. It's really pretty hard to notice some of the little things that will bother you ( or please you ) about a car in the 2 or 3 mile around the block test drives most dealers give ya. But if you've narrowed the choices down to an Impreza or a CRV, I don't think you could make a 'bad' choice. Both seem to be excellent cars.
And while I have the floor...I have another question about the AWD system on the Subarus.
( Sorry if it's becoming an old subject ). Can more power be directed to a specific wheel than is directed to the other three? Or is it always a equal amount to both rear wheels and an equal amount to both front wheels?
Power on Manual models always tries to achieve 50/50 split F/R on ATs it's 80/20 but can vary up to 50/50 depending on slippage. On VTD equipped models it's 45/55 split F/R up to 80/20.
On VDC models it can route power to a particular wheel by applying the brakes to a slipping wheel and forcing power to the other side of the axle.
-mike
WRX can on the rear axle. STi can on both.
-juice
-Dan-
-mike
-Dan-
So how's your OBS?I am enjoying my TS Wagon.Great car last winter.I have put on some accessories to spruce it up a bit.
Just thought I'd say hi.Remember this was the time I was going to buy a new car(spring '04)?In a way I wish I would have because of some changes with the 2005 Impreza.It won't be out for a while still and that would have meant putting a lot of dollars into my former car('94 Probe GT)which was miled out basically.
Anyhow,have a good work week and Easter weekend down there south of Lake Erie!!!
DD
TWRX
Chuck
I'm just loving my OBS...just a great car. Putting snows on it certainly helped with the Erie snows. I'm sure you've got something decent on your TS, right? Glad you're enjoying it.
The safety can't be overstated, considering that I came out of the wreck just fine. Solid, dependable and fun to drive. What's not to like?
I'll have to get this tint thing done soon...when I drive home from work the sun is at just the worst angle.
-Dan-
-Dan-
Plus, if winter tires tame that tail-happy characteristic completely, I think I'd miss it. It's a lot of fun doing that when you've got lots of room to play. The damage to my front bumper actually happened when I was on a deserted street practicing catching the rear end, deliberately using way more throttle and steering than I would in normal driving, and ran out of room and into an ill-placed pile of ice. After that I found a more wide-open area to use.
Side note: saw my first green 2004 OBS today. According to the Impreza brochure all 2004 OBS's are supposed to have Steel Grey Metallic as their lower body colour, but the medium grey on the green OBS was nothing like the darker, goldish-grey on my silver OBS. The colour used on my car as well as on all the other silver 2004s I've seen is closer to the colour used on the OBS in 2002-03, Platinum Grey I think it was called. Weird.
DD
PS-I can't believe I am actually looking forward to a bad winter.This past one was a piece of cake here.
If you like a tail-happy car in the snow, far be it from me to steer you otherwise. I prefer lots of grip, but I can see how letting it slide around a bit could be fun. Different strokes for different folks.
I have the same green car that you saw. I like the silvery color for the lower...offsets the deepness of the green well, I think.
-Dan-
I prefer the silvery colour you have on your green car, and I think it would have looked good on my silver OBS. I wonder why they didn't use it.
Yep, I like that silver color too. Not sure why the rest of the car can't get that color.
Does anyone have the tweeter upgrade? If so, is it worth the money?
-Dan-
I have the tweeters in mine. They do make a difference but not a huge one. I've seen other owners say that installing a WRX 6-CD head unit, readily available online from WRX owners who are upgrading, gives good bang for the buck in a regular Impreza.
-juice
Might do the WRX head unit thing. The sound really needs work in this car.
-Dan-
We did have the power mechanism on one of them jam (closed, luckily), but that was fixed under warranty no questions asked.
I think they've come a long way. ASC makes ours, they also make OEM moonroofs.
-juice
The F-XT will be leased as well (dw's business) - the lease company doesn't have a problem with adding one, as it can increase the value.
I wouldn't worry about it if it's installed by a decent shop (an ASC one would be preferred).
-Brian
I might just give it back at lease end and get a Forester. I'll have the moonroof with that, and I like the car, perhaps more than the OBS.
If I add on, I'll be sure to look for an ASC one.
-Dan-
I like the huge sunroof in the Forester, but the last time I drove a Forester (2001) that had one, I found out that it only slid back and didn't tilt up to vent, I assume due to the size of the panel.
-juice
TWRX
Later...AH
