Again, I guess I got lucky. 159,000 and it neither burns nor leaks oil.
And, yes, the interiors are nice. I’m 6’4”. Buying cars with sufficient headroom and legroom has always been a problem. The Passat, with its “bubble roof” and seat rails extending well toward the rear has made it a dream for comfort. Crummy crash test rating, though—one of the worst, if I recall correctly.
VDC is offered on additional models for 2007, if that is your sole buying criterion.
But the data on ESC as a "safety feature" is greatly skewed, since it was mostly only available on expensive, powerful cars with much higher accident rates than most passenger cars.
I doubt there will be a big difference in accident statistics between non-ESC equipped and ESC equipped Toyota Camrys - or 4 cylinder Outbacks, for that matter. But if a vehicle has ABS and a drive-by-wire throttle, the additional expense to add ESC is so minimal so it will likely become a standard feature.
I'm sure this will generate screams of outrage, but before you react, call up your insurance company and ask them how much of a discount you get for a model with ABS brakes versus non-ABS (some vehicles have it as an option). The answer, in most cases, is zero. ABS has undeniable safety benefits - but ABS equipped cars have the same # of accidents, all the insurance companies care about.
Oh, and when it comes to Subaru, say H6, not V6. The pistons are 180 degrees from each other, so no V. Think of two boxers throwing punches while facing each other.
-juice
Maybe that’s the rub. I know the GLX came in an available six. I think it was around a 2.5L. Don’t know if it was a turbo.
Anyway, with my recent purchase of an '06 Legacy SE, the Passat is now my "beater."
Jim
=gregg=
Early models had some heat soak issues, and were losing power. I never heard an official explanation or fix for those, however. Ask in a Mazda thread.
Around me, a base Legacy GT would run about the same as a Speed6, but I'd still pick the more proven and familiar (to me) Legacy GT. Plus, I still have a bad taste in my mouth from an unreliable 626 we had. My Miata's fine, though.
-juice
I know that we were torn between the XT and LLBean last year, and my wife felt the Bean seats were more comfortable.
Mark
Now they seem to have removed it. I saw a red one driving around, but Subaru dealer tells me no such thing as red.
Can anyone clarify? I really liked the red. (I'm talking about the Legacy Outback, not the Impreza). Thanks!
Phil
It seems that all the subaru part houses online don't carry any 1999 sedan roof racks.
Have any of you ever ran across any roof racks online for my particular car? I would love to get out cheaper than 350 for my rack.
Thanks ~ Jason
The Passat is "one of the best." The Legacy is "THE best."
Check out this link for midsized cars:
http://www.iihs.org/ratings/default.aspx
Just picked up a basic 2.5 Outback wagon today. Was wondering if anyone knew the details on the "pre-wired" satellite radio. From what I understand, it is wired, but missing the receiver. The radio has options for CD, FM/AM, Aux, and Satellite. I was wondering if I could use the pre wiring for a sirius receiver I already have. Thanks.
dashboard. This led has never lit up and I can't find any
mention of it in the owner's manual. After owning the car
for a couple of weeks I called the salesman and he did not
know what it was either. Anyone have any ideas what this is
for?
post a pic.
And oh, it was sooo much more than that. Battery cables nibbled away, gasket valve leaking ALL OVER the place, oil pump and filter shot, tranny filter not looking too hot. I'll pay $2400 (on a teacher's salary, no less) to fix this.
Am I getting screwed by the dealership? Has anyone else had these kind of problems? I still have a year left to pay off the car...would it be worth just chucking the car when it's paid off and getting a new one? I love my 99 but it's literally going to send me to the poor house.
HELLLLLPP!!!
Okay, so where to start:
First, battery cables. Nibbled away? Mouse problem? Oh, wait, hahaha... no, CHIPMUNKS!!! (Hahahahha, juice!) So, perhaps you need to replace them. Big deal, maybe what, $60 for both stock or aftermarket cables and 15 minutes to install? Not a dealer item. You could do this yourself without even batting an eye. Really. You pull the cables off the battery, disconnect them from their tether points (each has one), connect the new ones to the tether points and tighten well, then clean your battery terminals and connect them to the battery. Viola! Not even a sweat broken.
Next, valve cover gasket leak. Yes, this is a problem area. A quick fix again - if you were charged more than $200 in labor it would be a travesty (I cannot imagine it being more than perhaps a 2-3 hour job), but have them both replaced at the same time to prevent duplication of effort a short while down the road. THIS is probably the oil leak you noted and which prompted you to take the car into a dealership.
Oil filter shot? Um... who cares? This is a normal replacement item that should be changed every 3-4000 miles along with the oil. Get an oil change and call it good - $40 tops.
Oil pump shot? Really? How did they determine that? The fact that your engine still runs should mean the oil pump is working fine. I am not sure of your car's mileage, but if you have not changed the timing belt yet and are at, over, or near 100,000 miles, then get the timing belt replaced and have the oil filter inspected at the same time. The t-belt job should not be in excess of $500. Actually, that is a good time to take care of the gasket leak as well as it eliminates duplication of labor efforts.
Transmission filter - okay, so I think the '99 did have an exterior filter on the transmission. What should that take? 10 minutes to replace? Again, depending on mileage, if you have not had your transmission fluid drained and/or flushed yet, then probably time to do it and you can replace the exterior filter at the same time. MAYBE a $150 job.
Okay, so we tally.... have we hit $1000 yet? No way.....
The verdict is that screws hold better than nails. Find yourself a different shop and tell THEM what you want done. Take a look at the maintenance schedule for your car, figure out what you have done and have not done, then get the "to-do" items done and address your problem areas at the same time.
Good luck to you..... my choice would be to look to a few years of "free and clear" ownership before plunging back into car payments.
Remember this is a 5sp auto. With 2,200 miles on the car the mileage is averaging between 20.5 - 21.5 MPG. Premium 93 Octane is used full time. The vehicle also has TCS and VDC as does the 2007 Legacy GT. We traded a 2005 Legacy GT Limited 5sp auto for this 07.
First and foremost the car is very tight. And you want to talk about fast - when you put it in S# it goes realllly good. It appears to operate "normally" in S and it seems underpowered in the I position. RPMs don't seem to change between S and I.
I'm sure the 2007 Legacy GT Limited is going to perform as well - if not possibly even better. The car feels tighter than the 05 we traded in, which by the way had 50,000+ problem free miles and the mileage was averaging between 22 - 23 MPG (averaged 26+ MPG on a 2,000+ mile trip). I firmly believe the tighter feeling is due to the TCS and VDC.
I believe this 07 will get better mileage once it has an oil change to synthetic oil at 3,000 miles. All changes after that will also be synthetic oil (Did same in 05).
Why did we get the Outback rather than a Legacy? - the dealer did not have any 07 Legacy GT in stock when we purchased the Outback and this XT was the only one the dealer had.
The Legacy GT will also have a Spec.B version, however that will have the 6sp manual (which should be very sweet).
We haven't taken a long trip 1,000+ miles, but I think that is where the I in the Si drive should give some better mileage.
Bottomline you can't go wrong with either the Legacy GT or this Outback XT. If gas goes back up you can use half premium 93 and half mid grade 89 i.e - 91 - if you have it in your area. Some areas of the country seem to treat 91 Octane as premium.
Personally I don't think you can go wrong with either model. Hope this helps.
The headroom in the 07 Outback and 06 Impreza, both without sunroof, was great, but I preferred the Legacy's handling over Outback, and Legacy's interior over Impreza (and it looks like Forrester's interior is the same as Impreza's). And it looks like new 2006 Legacies are pretty much extinct on dealer lots.
I posted awhile back about replacing the OE tires on my OB. I was wondering if anyone had experience with these tires? I know people liked the Turanza LS-H and Nokian. Tirerack had better reviews for the G-009 than the Turanza LS-H and it's cheaper.
For what it is worth,here is my experience.
I replaced the original Bridgestone RE-92's on my '05 Outback Limited with Turanza LS-H tires.
I like them so much, I wanted them on my 03 Camry XLE.
The dealer suggested I look at the G009's....less expensive and had the attributes I needed. Research showed they had very good reviews. I have had them on for about three months so far and have been very pleased.
Don't think you can go too far wrong with either tire.
Doug
A base Legacy GT would fit the bill, though they're not quite entry-level priced. Go for it for the extra performance, though, it transforms the car.
-juice
Thank you for your input. I think I will order the G-009. Did you purchase the tires from Tirerack and have a Subaru dealer install them? How much did they charge you per tire? I called one dealer and they quoted me $23/tire for installation, balancing, valves, and disposal.
A GT is way out of my price range at $28k. Not really looking for huge performance. The SE is sort of the top end of what I'm looking to spend. Maybe I'll have to contact Subaru directly to see if a non-SE base Legacy can even be ordered. I'm not opposed to a sunroof (and the 8-way power seats would be nice), it just cuts too much into headroom.
I live in Canada and did not get the tires from TireRack....so the dollars would be meaningless to you. The price of $23 each seems unbelievably cheap to me....are you sure you have priced the proper size?
Doug
Yep, pricing will be different. I called the dealership and the service person I talk to said it was 23. I thought it was kind of low myself. I guess I will call again to confirm.
Have you driven in wintry conditions yet? If so, how do they handle?
Thanks again for your response.
Krzys
Yes, the $23 is for installation only per tire. I will be purchasing the tires from Tirerack. $75/tire.
pf2001
That's for 07s, too, you might find a left over 06 for less.
-juice
Has anyone else found headroom insufficient when looking at new Legacies? I guess I could drive it again and see if I could live with it, look for used 06's, or keep looking at other models.
I'll also be picking your brains for dicsussion suggestions for the Subaru vehicle groups as we reorganize the forums. Your input and assistance is greatly appreciated!
The Subaru Crew Chat is on tonight. The chat room opens at 8:45PM ET Hope to see YOU there! Check out the schedule
Do not do it for the "problems" topics! Breaking the topics down into a bunch of microtopics is not going to help anyone find anything easier and will certainly help decrease the participation in active discussions. I can see perhaps creating topics like "Subaru Accessories" or something for asking questions or finding info about cross bars, carriers, towing, etc., and then "Tires" for the annual "which is the best tire?" questions, but when it comes to discussing and diagnosing problems, a one-size-fits-all gets the job done because everyone knows where to look - if you have a problem, go here, and those who have answers, suggestions, etc., can check in regularly to easily monitor the activity.
That is my opinion, but I know Edmunds is hell-bent on destroying the user-friendliness of these forums, so let come what may... and let go who may.
