I have a 95 Lumina LS which recently started having transmission issues. It occasionally slipsat random times for no apparent reason. Is this common? I am looking at possibly purchasing a trannie out of a 2000 Impala which has a 3.4 in it. Does anyone know if the trannie will fit?
Thanks in Advance,
Krys
I have replaced the thermostat, radiator cap and passenger side fan motor. The radiator has also been flushed since it hadnt been in a while and the car has 110k miles.
The driver side fan comes on but the passenger side fan still doesnt come on even though I replaced it with a brand new one. Could the fan not coming on be the problem? Are both fans even suppost to be running at the same time? I have checked all fuses both inside the car and near the engine and all seem to be ok.
What else can I check.
All of these problems occurred at exactly the same time so I'm fairly convinced they're related. I checked my bulbs but all the the filliments looked ok.
A few things I'd like to clarify : The back lights come ON, they just don't brighten when I press the brake. Also the turn signal lights turn on (Part of the parking lights) but do not "Blink" when I press the lever on the stearing wheel. Also the middle brake light above my trunk still works normally which only further confuses me.
Any help would be greatly appreciated!
However, there are a few thing that bother me, the biggest of which is the front bench seats. I freaking hate the combination armrest/console which all to often gets in the way and doesn't fold up flush with the seats.
I know that bucket seats were available on the later LTZ models and the Monte Carlo's, but I dont know if they were available on the same year.
What I am really to do is swap out the seats for buckets and the console, if I can. Anybody have any ideas on the feasibility of doing this?
I have already pulled open the dash and installed reverse-glow gauges and threw some EL wire behind the controls for the AC on the dash (looks much better in blue then that horrible pale green!)
I look up in the manual and ask a mechanics. But I did not get any answer.
Somebody can help me?
Thank you very much!
I am getting code #PO341
Glad to know I am not the only one with this problem with the 96 Lumina. It has driven me nuts. But if it happens I wait about 5 minutes and it would start. Replaced the Ignition switch 3 years ago and same problem still happens.
It has been a strange glitch.
Now the ignition switch has gone bad at a cost of about 240 to replace again ouch.
Turns out the Ignition switch is good. Time to lose the car.
Ouch
Brad
For the money it's been a fantastic car, no matter what happens. I just hope I can keep it going a while.
rwalton
I always carry an extra door key on a different ring than the ignition key just to be safe.
