But folks who have had the experience tell me that evently it will not. On the other hand I talked with a man the other night who has had 2 sensors replaced since Jan. and the darm car refused to start again the other night and the dealer says it's a defective sensor. So, good luck !! :confuse: :P
to do this proceedure ?. :confuse: :surprise:
says will work for my 03. But I can't locate the Mall Pgm Fuse. I've checked all fuse boxes and the layout in the manual and there's not a list for this fuse. Can some one tell me where to find it. Please !! :confuse:
Rachel
In other words, constant problems one after another.
The reason is, I might buy one, however, I am not a big GM car fan. Seeing how they are put together.
Jhamaul Hanner
pontiac dude-
sounds come from under the dashboard like splashing water? No leak in the heater core either. I checked under the dash. Any suggestions? Ken
Since it would start I drove it for about two more weeks, some times it would fire right up and some times it would have trouble, and one day it wouldn't start again. It sat for three days, I tried to start it again but it wouldn't fire. I brought it back and again after unloading it would start again. The mechanic has had it for a week now and it has started every time for him. I can hear the fuel pump working when I turn the key Run position just before ignition. Before replacing the fuel pump I would like to know if there is anything else that could be causing this ignition problem. I use regular gas, should I try using Premium? fuel cleaner? anything else I should try checking?
Doug
mjh
Thank you in advance.
Fernando1
pontiacdude
Was a 97GT available with manual? Yes, only with 4 cyl engine.
Hope this helps you!
Chantal
