I leased my 99 Concorde LXI new in june of "99"and now have 58,000 miles on it.
My Concorde did require approx. $1200.00 dollars in repairs between the expiration of the 36,000 mile factory warranty to date but I feel that amount of needed repairs to be totally acceptable with todays high auto repair costs.
My Concorde is in excellent condition both mechanically and cosmetically and would have to say that with almost 60,000 miles on my car that solely from a mechanical aspect I feel the Chrysler Concorde is a well made vehicle which has been very much improved from the pre 98 model year Concordes.
On the other hand the basic Concorde with the smaller engine for my situation may not be adequate as I often drive on two lane highways that cause me to pass and get back into my lane as quickly as possible.
So to answer your question I feel it would just depend on your individual driving needs but I would think if you drive mostly in the city you will find either engine will do the job adequately.
Two things you may want to check before you purchase your new Concorde is...if you are 6ft.or over try and sit in the front passenger seat with the seat all the way back and see if there is enough leg room for you because as hard as it is to believe for a car that large it has very limited front passenger leg room......the driver and rear seats on the other hand have more then ample leg room.
The second thing you may want to check is the road noise inside the car....I would strongly suggest that you take the car on the highway before you buy it and see if the road noise will be a problem for you.....in my situation I have to say that I do find the road noise very annoying and when I have passengers in the rear seat I find it difficult to hear each other without speaking at a higher then normal voice.
The passenger leg room and the interior noise is more then enough of a reason for me to not to purchase another Concorde but I also feel in my opionion that if those two things won't bother you that you will love your new Concorde as it is truely a beautiful and well made car that is reasonably priced and will get you complements wherever you go.
The difference is that your "butt dyno" feels its going faster (higher speed) quicker (in less time) because of the torque at lower RPMs in Buick Regal/Pontiac GP. As an additional effect of more torque, your back slamming against your seat is more felt in the Buick or Pontiac.
Since I have experienced smaller engines - from 4 cyl DOHC engines that make their power at 6000RPMs and higher, the high-RPM whine of my LX when I'm accelerating hard does not bother me at all.
The Concorde is extremely light, with lots of plastic body parts, and the hood is aluminum. But it's just slightly heavier than the Regal. Consequently, the base engine is adequate for its weight. My family is small and I don't lug around anything that's heavy, so the LX is just fine.
If you want more felt power, you probably have to go to the LHS or 300M with their 250HP and 255lb.ft. torque. The 300M in particular has a reputation as a sporty sedan backed up by enthusiastic owners. It's got better handling European style suspension, more grip around curves, and quite a lot of upgrades over the Concorde LX like the leather seats and better wheels/tires. A dealer around N.Va. advertises occasional $25,000 specials on 300Ms, while his Concorde LXs are advertised as low as $18,000 occasionally. Try test driving the 300M, and compare to the supercharged Regal.
The Concorde is just so damn good looking though!
Then tried the switches again - worked!
Got out the window cleaner, and cleaned off the rubber gunk around both sides of the glass on all windows. That does it for now, I should remember to clean them again in a few days.
This is the only issue with this car after 1.4 years of ownership.
The engine (2.7) is good most of the time power wise, but with a full car and the AC on, be careful trying to pass.
I had a chance to look at the 02 Concorde, I like them. The only thing I wish is that they had the old front end with the LHS's back end. Now that would be a sharp car. I noticed the LXI model had the 3.5 engine in the cars I saw at the dealership.
Yesterday, while trying to start the car, the car would start faintly and then die off. This happened a few times. I even felt a very mild vibration for 1-2 seconds before the car died off. Then I stepped on the gas pedal and started the car. This kept the car from dying off. Then I shifted to drive and drove off to the dealer. I think I got a very faint smell of smoke at one time. The dealer ran a diagnostic check and din't find a problem and now all seems well. Does this indicate a future problem ? Any thoughts ?
Has anyone performed this TSB on their Car ?
Got my car back from the dealer. The TSB which I mentioned earlier was not performed because the tech din't think it applied, after a detailed test. The invoice mentions that they have flashed the PCM Module. The following are the part numbers listed: Part# CMC 04669020 and Part# CMC 04275086.
The car seems to behave better. The starting problem has not occurred, so far.
"Mechanics: Horror Stories." I bet all of you have had at least one bad run in with a dishonest mechanic. Please post your horror story under my new topic. I hope to see this topic in the top ten list with your help to get it going. Here is the link: easyrider300m "Mechanics: Horror Stories" Oct 28, 2001 10:38am ---Ok, Guys--start your postings!
I have noticed within the last 2 weeks that I have a strong vibration in the wheel while stopping at higher speeds.
Thanks for the input.
I finally installed my custom airbox (which reminds me of a lunar lander) and all of its plumbing, and it works like a charm! While I get the desired deep throaty growl while accelerating, it is no louder than stock otherwise. It also feels more responsive.
The box:
http://albums.photopoint.com/j/ViewPhoto?u=1280646&a=13764864&p=55243320&f=0
Final install:
http://albums.photopoint.com/j/ViewPhoto?u=1280646&a=13764864&p=55718914&f=0
Plans:
http://albums.photopoint.com/j/ViewPhoto?u=1280646&a=13764864&p=55785794&f=0
Old v. new:
http://albums.photopoint.com/j/ViewPhoto?u=1280646&a=13764864&p=54971393&f=0
I have ordered two digital thermometers from JCWhitney so I can compare the temperatures between the inside and the outside of the airbox.
I have the same problem you are having with vibrating felt in the steering wheel while braking and that is almost always caused by the front rotors which should be resurfaced when you have brakes installed and that should take care of your vibrating problem.
With only 10800 miles on the car I thought it should be free, but the car is 18 months old.
The reason that was given to me was the short trips caused the warping. None of my other cars ever had this issue and I have owned a lot of new cars.
With 0% around maybe it is time to shop. The only downside is that the car is probably not worth much as a trade
When it comes to brakes, I do my own. That way the lugs are only hand tightened. Of course, getting tire work done can cause the same possible issue.
I've got an Intrepid R/T with almost 15,000 miles, and the brakes feel as good as the day I bought the car. Of course the R/T has the high performance brake rotors for the LH cars, they are supposed to be more heavy duty.
99 Concorde LXi
Some questions (for starters):
1. What are some differences (with things as "unimportant" as cup holders) between years '98, '99, and '00? I'm trying to get an idea if Chrysler has a habit of de-contenting in successive years, or do they tend to add goodies instead.
2. Everything else (mileage, condition, etc.) being equal, what might be a reason to buy a '00 instead of a '99, and vice-versa (related to item 1., above, but also such things as engine/power improvements, etc.)?
3. Of the two V-6's offered in the C'corde/Intrepid in a given year, my understanding is that the smaller (non-LXi) engine is interference (meaning if a timing belt breaks, there will be serious engine damage), but the larger engine is non-interference - is that true?
4. I have started seeing comments on other forums that there have been serious tranny problems in these cars, but also have seen indications that such problems were fixed before the 99's were released. Comments on that situation?
5. Are there other good forums specifically dedicated to Chrysler products, more specifically, the C'corde/Intrepid? Preferably technically/motorhead oriented.
6. I believe that the some engines in the LHS and 300 are hi output versions of the C'corde LXi engine. Would it be feasible/simple to convert an existing C'corde engine to the hi output, or would that involve serious/very expensive mods (or somewhere in between feasible/simple and serious/very expensive)?
Much thanks in advance. I'm new here - just starting my serious info. gathering to make sure I want the Concorde (right now all I know is I *really* like its looks and, if I'm careful and patient, I can afford it).
2-98 year cars were new and when you start building new cars you learn things that change year after year, so the newer you get the more bugs get worked out.
3-The two engines were 2.7 (no timing belt,uses timing chain)3.2 rubber timing belt and for 2002 model a low output 3.5. -same basic motor as the 3.2.
4-see answer number 2
5- not sure
6-no , if you want the H.O buy an LHS or 300.
If I was buying this car I would buy the newest model I could afford. IMOP take care and good luck
I would like to find out a little more about the alleged tranny problems - don't want to get stuck with one of those - a couple of people on other forums (not Chrysler-product related) are pretty upset, and according to them, Chrylser seems to be stone-walling them about (apparently) taking any responsibility for a serious defect, although supposedly it's fixed for '99 and newer - but I don't want to make an expensive mistake based on hear-say.
Thanks again.
http://www.allpar.com/fix/trans.html
I don't think they decontent. They add on one or two things each year and typically up the price a couple hundred.
one of the main external things are the wheels. In my 99, the wheels are 15". From 00 and up, the wheels are 16". Steel on the LX, and alloy on the LXI, although aluminum alloy wheels are options on the LX also.
I personally prefer the cloth seats of the LX, and not the leather of the LXI. Just bugs me when it's summer the leather seats are hot, and when in winter will freeze your butt.
I actually prefer the 2.7 V6, I am not the expert but I understand that the transmission is different than on the bigger engines. The different transmission actually helps the smaller engine accelerate with equal speed as the bigger engines. I could be wrong, the experts around here should know. I actually got that idea from the 300M board, where the 300M owners bewail their low geared cars, and wish they had the taller gearing of the Concorde LX.
On the transmission problems from previous years, the 98/99 and up models (current bodies) are much better, light years away from the previous one.
These cars are just much better designed and built.
As you have read above, there are some complaints about premature brake rotor warping. I'm at 30,000 miles on my 99 Concorde, and had to have the rotors replaced. No, the dealer did not offer to pay any part of it. It's also the first time I replaced the disk pads. That's been my only big repair bill. Everything else has been regular preventative maintenance.
There are some complaints about rubber stripping around the doors, which shrink in really warm weather (actually stretch, then shrink when it's colder). Also the driver's window gets stuck cause the window seal melts somewhat and sticks to the glass like glue. Lots of folks mistakenly have their winder motors replaced usually under warranty. But the wiser people just keep the windows clean and wipe off the gunk every other day.
You might read in this topic or in the other two (300M and LHS) topics that when folks had their window motors replaced, some of their door panels were actually badly mangled (and not repaired) by the technicians (probably cause they didn't have the right tool from Chrysler). Just beware.
You may want to rethink your buying an off lease for about $14,000 or so. You can get a brand new 2001 LX for about $17,000 with all the rebates at this time. Hurry though, I suppose they're getting the old models off the lot, cause they want to sell you the new one. The new 2002 Concorde is actually last year's LHS externally.
Visit the dealer and you'll see what I mean.
Here's a site with Chrysler/Dodge info in general":
and the 300M club is very active on this board in its own topic as well as on ezboard:
http://pub88.ezboard.com/b300menthusiastsclub
This one was pretty good but haven't had success accessing it lately:
http://www.car-truck.com
happy motoring!
rick
In one of the boards, I remember you mentioning something about a leaking a/c on your 300M.
Can you tell me more about this ? (symptoms and how it was fixed).
I have recently started hearing a 'low' hissing sound from the a/c when the compressor is running.
Sometimes, the sound gets louder.
Of course, it is fine when in the dealership.
thanks for any info.
My 99 Concorde Lxi now has over 66,000 miles and I now need my 3rd power window switch replaced as well as 1 window motor and 1 power door lock mechanism also required replacement....also required a new dual cooling fan replacement in the past....all I can say is I sure got my moneys worth out of my extended warranty this time especially by being able to pass on all the dealer suggested high cost preventive maintenance they have tried to recommend since I purchased my Concorde.{other then oil changes,brakes,belts,and hoses I feel there is no reason to pay for both an entended warranty and also pay for preventive maintenance that is not required by the manufacturer.)
Other then the above mentioned repaires which added up have cost Chrysler much more then the cost of my extended warranty I would have to say that my Concorde mechanically as far as the drive train(engine&tranny)it has been a very reliable car and to date have not required any drive train repairs.
For your item #4, transmission problems seem to be caused by using other than Chrysler 7176+ or ATF +3 fluid. Never use Dexron or get ready for a re-build. I've not had a transmission problem and changed the fluid once at 120K miles.
The A/C evaporator rotted out at 70,000 miles and was replaced by Chrysler. The problem was that their supplier did not properly wash out the acid rinse during manufacture. The A/C is very powerful and does a good job here in Central Florida. The rest of the system including compressor is original.
I just replaced my brake pads this past weekend for the first time. Had original rotors turned. The four wheel disc anti-lock brakes do a good job. We travel to our mountain home every month or so heavily loaded and have pulled trailers and pull my 2000# boat on the hottest days. A reason for the larger engine is towing capacity. I have the 3.3L and can tow 2000#.
To answer your question #5, visit allpar.com for Chrysler enthusiasts site.
I'll probably buy another Concorde after I finally wear out my '94. It still runs and looks good. It can maintain 80 MPH all day, get over 28 MPG with air and still uses very little oil.
Good luck. Hope you find a good one too.
I don't know if you have the answer to question 2 posed in message 591 or not, but I too would like to know the answer. Why does the Chrysler 42LE Tranmission Learn and what do we gain by having this feature?
I personally think my 300M drives best when at default settings. Like when we test drove and fell in love. I reset my computer occasionally after I get annoyed with the way the tranny is shifting in Drive, especially after I've used autostick for a little agressive driving. I would expect luxury smooth shifting to return in drive,
Incidentally, my mother's 2000 Concorde shifts fairly consistently. Is this because it doesn't have the autostick and have to switch between the firmer sport shifting and soft luxury type shifting?
Thanks for the feedback on the learning tranny.
I understand what you're saying but I still prefer the tranny in my 94 Dodge Ram.
I would like to swap out the plain looking gage cluster for the retro-looking (black letters on cream background) cluster. Does anyone know what determines what years or models (LXi?) determines that the vehicle has that cluster so that I can efficiently search for it from a salvage yard or other source. Is there any chance that the similar looking cluster in the 300M's (and I assume LHS's) are a drop in fit (to possibly broaden the availability)?
BTW, I also want to swap out the factory radio/cassette for the factory radio/cd/cassette. Figured a good source would be someone that has installed an aftermarket system and has the factory one to sell.
If so, post here and we can go from there.
Also, if I were to do a retrofit, I assume that I would need the whole cluster - not just the individual gages?
I love the Concorde and feel very comfortable driving it. I feel with the luck I have had with the Neon the Concorde should be even better. I am confident that if anything should come up I can fix it without spending thousands of dollars.
I have read a lot of complains about road noise and wonder if maybe
a. Some of the people on this board are older and have hearing aids which might amplify the noise
b. Have become accustomed to there cars and their ears are more in tune with the cars noises translating that to more noise.
I have noticed that with my Neon. Sometimes I feel my neon is very noisy especially after driving it straight for weeks and not riding in another vehicle. Then I will drive my wife’s car for a day or so I come to find my neon not as noisy (I must state here though that when I fist got my Neon I added my own sound insulation throughout the whole car so it is probably quieter than the stock Neon).
I do want to thank everyone on the board that has posted positive and negative feelings for their Concorde it has been helpful to see what possible problems could arise and maybe even how to fix them right the first time and even though Chrysler products have there faults (show me one manufacturer that doesn’t) that they are good cars for the price/performance/enjoyment factors.
You mentioned "You can get a brand new 2001 LX for about $17,000 with all the rebates at this time."
What rebates? are they regional? I have my eye on a 2001 LX....it's new, a leftover. Small number of options including ABS. Sticker is 23K. I figured I can get them down to 19K or 20K, but do you think 17K is realistic? (Edmunds "True Market Value says 18K + about $500 for the ABS and of course $625 destination.)
I'm not a good haggler. But this is the same dealership I bought my 99LHS brandy new (should count for something I guess!) The dealer is great with a terrific service department (from what I read on the groups that's pretty rare !!) Plus DC is offering the 7 year 100K mile warranty even on the 2001's.
What do you think is a fair "bottom-line" price??
Tom
Will pass along some random thoughts and observations.
1. I avoided the '98 because supposedly they had some transmission problems which were cleared up by the '99 MY.
2. There's an '01 blue Intrepid in a lot I was shopping at for (I couldn't believe it when the guy told me this) $8950 - and that's the asking! It does have 70k miles on the ticker, but that may or may not bother you. The good side of that - with that many miles on it in such a short time, that has to be a salesman's car with all highway miles. Looks to be in good shape. It's not the color I wanted, and I had already bought the one I now have two days ago. I thought I got a good deal at $10.5k very tight and clean with 57k miles until I saw that one - but I still think I got a good deal.
3. Prices are all over the place, but I have seen them drop over the 6 months I have been shopping around. What was $11.5 to 14k now can be had for well below $11k - and in very good condition. Used car dealers are having a very tough time right now, and the mfgrs. are stockpiling used cars right now to keep used car prices up so people will still have some incentive to go new.
4. Regarding road noise, I noticed it on my mother's '98 and other 98's that I test-drove - seemed to be bearing or tire noise from the rear axle, but probably due to poor sound insulation in the rear seat area rather than a mechanical problem. My '99 has no noise like that whatsoever - very quiet - they must have fixed that also for '99. Another reason to go with '99 or later, IMO.
Oh - and the '01 I looked at has the black letters on cream gages.
sorry haven't come to this board in two weeks.
In the No. VA area, there are a couple of dealers who do the low-price car ads, you know the ones they advertise then when you come to the lot find out that the ones you REALLY want (with the bells n whistles)cost a little bit more.
Anyway, one of them is Darcars Fairfax Chrysler.
I waited for one of their ads back in April 99, it said $18k for a brand new 99 Concorde LX. I took the ad, went to their lot and looked for that car. Found it and bought it. Note that it was stock LX. No leather seats, no moonroof, no CD player, had the stock 2.7L engine, etc. And since there was only one on the lot, I could not choose the color. It is a candy apple red color, very attractive to cops hiding behind flyover pillars.
Three weeks ago they advertised a brand new 2001 Concorde LX for $17500. I figure that includes all of the factory incentives plus some holdback.
This is the same dealer who advertises "up to $7,000 discount on brand new 2001s" in big bold letters. I have not found out which car it is they have the 7,000 discount on. Probably a Grand Voyager.
In your case, you probably will get a good deal if you have the dealer come down to $19k+ from 23k, assuming you have some goodies on the car. Beware they don't get you back with a high APR. I usually go to the dealer with a pre-approved loan from my bank in my pocket. My bank will lend me 101% of the price of a new car. Or they might try to bring down the trade in price. Another nice thing Darcars did for my trade-in is the salesman went to the computer, showed me KBB.com, punched in the exact model car and mileage, printed out the 'seller' price and offered me 300 below it.
I asked for the price printed and he said ok.
It was for my 92 Toyota Camry with 61k miles worth $4500.
