Does this sound like the starter? has anyone experienced this? I don't want to change out the wrong thing, so all advice is appreciated.
If there is a separate starter relay remotely located from the starter, I suppose it could be that, but our 1985 the relay was part of the starter. I frankly don't know how your 1999 is setup.
Removing the old one and installing the rebuilt one is not that hard. If you are a little bit mechanically inclined, this may be one of the easier parts replacement. No alignment or timing to worry about. As a safety precaution, do not forget to disconnect the ground connector of your battery before you start removing that starter.
as the vehicle gets older, the struts also get weaker. I owned an '88 Reliant Wagon that used gas struts to support the tailgate. As the manual explained, in cold weather the strut got too weak to support the tailgate. As the car got on in years, the strut got to weak to support the tailgate even in hot weather.
Another son has a 99 GC SE with 70,000 miles with no problems...not even had to replace front disc pads or shoes on rear brakes.
DaimlerChrysler reliability has drastically improved in the past 5 or 6 years.
Glad Chrysler vehicles last longer than Volvo.
They said this was caused by lack of use of the e-brake. Has anyone ever heard of this? This is my wife's van and she probably only uses the e-brake when parking on a hill, but I would not think lack of use would cause this. Even so, can't something be lubricated to help with this?
Thanks for your help.
Paul
Computers are my forte`, cars are not. I figured I'd ask you experts here (and even those of you with similar experience;) about a problem with the power window on me and my wife's Caravan SE 2001. Basically, it doesn't work. While rolling up once it seemed to slow down a bit, then stays in the up position. Is this a fuse or motor problem? Anyone have suggestions that I could check? I know there's a fusebox under the hood somewhere LOL....and another under the dash somewhere? LOL thanks in advance guys
I have a 99 Grand Caravan. It is an intermittent problem.
When I turn the delay wiper on to various delay settings, they may swipe a few times, then it appears the wiper "jumps" and quits. At this point, none of delay wiper setting work, and I need to turn wipers off and then back on. When I turn the wipers off, the blades will swipe windshield from 2-4 times before shutting off.
from Gatineau
When the dashboard is out we lose all lights in the driver's console and none of the instruments function. Cruise control still works but its' indicator light does not come on. Mileage does not increase when the dash is out. All the controls (turn signals, headlights, radio,heat and a/c, cruise) still operate properly. There does seem to be a loss of engine power when the dash is out, but it is subtle and only really noticeable when passing at highway speeds. There seems to be no rhyme or reason as to when we lose the dash and when it starts operating again. It's gone out while driving and come back on while driving. Other times it's fine one day and then out when we start the vehicle the next day. I did notice once that the gauges came back on at the instant the passenger side sliding door was slammed shut while driving slowly. Check engine light has been on constantly for about 18 months.
Anyone have any ideas? I am hesitant to take this back to the dealer without a better understanding of what might be going on. The few cases I have found with a similar problem have been back to the dealer numerous times at great expense mainly without solving the problem. I have re seated all the electrical connectors that are accessible under the dash. The dealer solutions that mostly haven't worked that I've read about are: Replace the computer, Replace the body control module and check a ground in the area of the passenger side B pillar. I really don't want to pay $400 for a new computer from a dealer that does not solve the problem.
I have checked the fuses many times. They've always been fine. Have re-seated all fuses as well. As for the check engine light - I'm fairly certain it's coming on due to the small loss of engine performance that happens when the gauges go out. Back when the gauge problem happened much less frequently I could disconnect the battery and reconnect to get rid of the check engine light. Never came back on until I would lose the gauges again.
Check out the problems that I've encountered over the last 3 and 1/2 years:
* September 5, 2001 - Mileage 5,457 - Rear Lift Gate failed, brought to the Dodge dealer for repair. Action - Adjustment.
* October 12, 2001 - Mileage 7,050 - Rear Lift Gate failed, brought to the Dodge dealer for repair. Action - Special Order Parts
* November 3, 2001 - Mileage 7,870 - Rear Lift Gate failed, brought to the Dodge dealer for repair. Action - Install Special Order Parts.
* November 8, 2001- Mileage 8,086 - Rear Lift Gate failed, brought to the Dodge dealer for repair. Action - Repaired Connection.
* November 21, 2001- Mileage 8,095 - Rear Lift Gate failed, brought to the Dodge dealer for repair. Action - Replaced Motor Assembly.
* May 10, 2002 - Mileage 16,575 - Recall, brought to the Dodge dealer for repair. Action - Reprogram Powertrain Control Module
* June 10, 2002 - Mileage 21,561 - Battery Died, brought to the Dodge dealer for repair. Action - Replaced Battery (This Required Towing Service)
* October 30, 2002 - Mileage 29,097 - Lights and Horn Flashing uncontrollably, brought to the Dodge dealer for repair. Action - Cleaned/Dried Front Control Module (This Required Towing Service)
* March 21, 2003 - Mileage 36,422 - Engine running rough, bucking and jerking, brought to the Dodge dealer for repair. Action - Replaced #3 and #5 Spark plugs.
* August 10, 2003 - Mileage unknown - Battery Died. Action - Self replaced battery. (Note: Two Batteries in Two Years)
* September 25, 2004 - Mileage - 52,741 - Air Condition stopped cooling, Anti-Lock Brake Light Activated, Headlights Flicker intermittently, brought to the Dodge dealer for repair. Action - 1. Replaced Condenser and Drier for Air Conditioner 2. Replaced ABS Control Module for Anti-Lock Brake Light problem 3. Replaced Front Control Module for Headlight problem. 4. Additionally Transmission failed on mechanic test drive, requiring replacement of Transmission Control Module... Total Cost for these 4 repairs $1,604.16
* October 8, 2004 - Mileage - 53,051 - Headlights flicker intermittently, brought to the Dodge dealer for repair. Action - Replace Body Control Module.
* October 25, 2004 - Mileage - 53,??? - Headlights still flicker intermittently, brought to the Dodge dealer for repair. Received it back this evening November 4, 2004.
It took me 30 years to have that bad experience fade enough in my memory to get another Chrysler product. Two of my 3 sons now drive Dodge Grand Caravans and I own a 2002 Chrysler T&C.
I have a 00 Grand Voyager SE with 101k. The shifting of the transmission seems to be jerky, especially if it is cold. Is this the "bump shift" problem you spoke of? Is it serious?
lee9
It depends on the year, but a PCM reflash resolved this problem on many units. Expended ATF has also been attributed to this problem. I would recommend you see a dealer. They are (...oops! Should be...) the most familiar with this problem.
Best regards,
Dusty
C.B.
C.B.
