Mazda MPV: Problems & Solutions
1282931333486
    stone20stone20 Member Posts: 22
    No problems with rear noises in my MPV. The suggestions are good ones. They still have not came up with a fix on the front end noise with brakes or what ever the noise. Any body with any luck on this matter? Mazda suppose to come up with a solution.
    alexv1nalexv1n Member Posts: 248
    Are you talking about the clicking sound when you start to go in opposite direction and brake? If this is the problem, then first of all I would like to note that it is not a problem actually. All disc brakes do that. Here is a brief description of the problem:
    "A clicking type noise may be noticed when first applying the brakes after changing vehicle travel direction (Drive/Forward to Reverse, Reverse to Drive/Forward). This is a normal noise caused by the required brake pad-to-caliper clearances. When the direction of travel is changed, the brake pads may "shift" towards the new direction of travel. When the brake pad contacts the caliper, a clicking noise may be heard."
    [The above description is taken from a Toyota TSB for 1995 Tercel, so it's not Mazda-only issue :-)]
    Mazda has found a solution to reduce the noise significantly and they released a TSB that recommends installing "font disc spacer plates" whatever they are. They performed the fix on my '00 LX and it seems to have helped. The noise now is barely noticeable.
    I hope this helps.
    evaddaveevaddave Member Posts: 156
    alexv1n:
    We have the Front Brake Noise. For us, it's not when the van changes direction, but when approaching and leaving a stop (and I recently heard it while going over a speed bump). When the van is warmed up, and all the associated components are warm, too, as we're approaching a stop sign (or congested traffic, or whatever), we hear a kind of clunk. Then, when we start going again, we hear the same clunk.
    We've had the van to the dealer a number of times, but they can't fix the problem. They have, finally, been able to reproduce it, but they say that Mazda knows about it, and doesn't have a fix yet. I took the TSB about the tie rod ends to the dealer, but they say that's not the problem. I'm starting to wonder if we have a possible Lemon Law case, since there are obviously plenty of MPVs that *don't* have this problem, yet Mazda can't seem to fix ours.
    jstrauss88jstrauss88 Member Posts: 7
    evaddave, we had the same noise on our MPV. It was especially bad at high ambient temps, like during the summer here in Texas. The dealer did the brake fix first and assured me that would take care of it, even though I told him it did not sound like brakes to me. When I got it back, it did just the same. I printed out the TSB on the tie-rod ends and noted that the description of the problem in the TSB was EXACTLY what I had told him, i.e., worse at high ambient temps, and they gave in and did it. Have not heard the noise since. Brakes do not make a deep clunk like what you and I are experiencing, brakes normally make more of a clicking noise.
    cmunizcmuniz Member Posts: 604
    Evaddave - Ther noise you are hearing is exactly the tie rod problem, especially if it happens when the temperature is high and the van has been running for a while. My dealer fixed it using the TSB info and it cured the problem, but I had to insist on it. They have to replace the ineer tie rods.
    I think the problem is the tie-rod myself. I live on a hill and every time I go down the driveway exsp. it makes cracking and clunking noise, while applying the brakes more so than any other time. The noise is while I'm applying the brakes and any change in weight/direction is the best way for me to explain to you. It's not because of what your explaining. I was told by the dealer that Mazda was working on the matter. They replaced the caliper bolt already, that did not do anything for the noise. Please give info. on the TBS. I know Alex is the man for the info. I'm new, so be easy on me. I agree with evaddave on this matter, should be recall on this problem. I talked to a few people with Mazda MPV vans and it seems were all in the same boat. Frustrating for a lot of them. JL
    scarter7719scarter7719 Member Posts: 89
    I know this is already in this archive somewhere, but go to either of these two sites to find TSB #0200101:
    http://www.vakcer.com/mpv/
    http://www.nhtsa.dot.gov/cars/problems/tsb/index.cfm
    It's easy to find on Vacker. On the NHTSA site, just be sure to choose MAZDA TRUCK as the make to get the MPV model. I went to both of these sites and printed out the TSB's for my rear-brake squeal. Even though you can't get the full-blown details of the fix (ie. parts involved/replaced, etc.), the summary info should be enough to get you going, as long as the dealer is competent in locating TSB's.
    This TSB applies to '00 MPV's with a VIN lower than JM3LW28**Y0137197, though it could occur in higher VIN's (I've read). My VIN is not much higher, but I don't have this problem, thankfully.
    evaddave, sorry to hear your dealer is giving you such a hard time! The Lincoln-Mercury dealer adjoining the Mazda dealer services my MPV (same owners), and my CSR said that their LM techs were more familiar with the TSB process vs. their Mazda techs. Lucky me, I guess, since I have received excellent service so far, probably due to that fact.
    SC
    I was pretty certain it was the tie rod ends, and the volume of responses saying that only makes me more certain. I took the TSB to the dealer, and after they "determined" it was the brakes they said, "We'll take care of the tie rod ends if we fix the brakes and the problem doesn't go away."
    me: "When will the brakes get fixed?"
    them: "We don't know; Mazda hasn't published a fix for the brake problem yet."
    aaarrrgh.
    This and many other TSB details are now available from http://www.vakcer.com/mpv/
    I hope this helps.
    Merry Christmas and Happy Holidays.
    Alex
    jubnemjubnem Member Posts: 5
    I just wanted to send a note of warning out there to anyone who doesn't keep up their maintenance as well as they should. My last oil change was about 10,000 miles ago. I know, bad, bad, bad. And I've paid the price for it now. I threw a rod and killed the motor. The warranty won't cover it due to lack of maintenance. I don't drive hard, no drag racing or anything. The engine started knocking on my way home from the mall Sunday. Five minutes later, the motor was blown. No oil light, no engine light, no over heating, nothing.
    Just wanted to let everyone know so you don't end up where I am.
    bill124bill124 Member Posts: 246
    Any advice on solvents, rug cleaners, etc. that would be good for cleaning the beige rug?
    I have after-market rugs that cover some of the carpeting and put plastic runners in other areas but it hasn't worked as well as it could have due to the little ones.
    msgjvhmsgjvh Member Posts: 196
    You should fight, fight, fight. How many miles do you have on the vehicle? Even VEGA's and Pinto's drove a long way with out oil changes. (NOT SAYING YOU ARE 100% RIGHT). But I highly doubt that you are totally wrong for letting one or two changes go longer.
    Good Luck
    My van has 28,810 miles on it. I've called the corporate office and spoke to Tom. He acted like I committed a crime by not changing the oil on time, said I was lucky it lasted as long as it did. The last oil change was around early summer, so I know it was way too long. My husband went to see the motor at the dealership and he said it did look pretty bad, sludge under the valve cover and such.
    I remember back when I was a teenager, I had a little blue chevette. I'd drive that little smurf around for a week with the oil light on constantly before I could find time in my hectic social calendar to take it and have oil put in it. My dad flipped out one time he checked it and I only had around half a quart of oil left! And I don't think I EVER had an oil change. But I never killed a motor.
    Anyway, I know I should have had the oil changed. I know better than to have let it go for so long. I just trusted that if anything were wrong, my oil light would come on. And I never imagined that my engine would blow up without ever having a warning light of any kind come on.
    I've cried my eyes out over it. This happened Sunday, so my holiday was pretty much ruined. I just don't want anyone else to learn this lesson the hard way.
    28K is too young for that engine to die. They should cover at least half the cost of the engine or give it to you at cost at the very least. Was the level low enough that the light should have come on but didn't? If so that is clearly a problem they should be responsible for. If the dealer did the last change for you did they do it properly? If that filter is not more than hand tight on the flange than it will drip oil, which is a factory design problem if you ask me. There is a deeper cause to this failure than just your untimely changing of the oil! Get an independant opinion if you have to, I would not take this sitting down.
    One last question, what kind of filter were you using?
    and I am very sorry about your engine, I'll be changing our oil this weekend! ;(
    BTW, my subie has run on little if no oil they are bullet proof! Of course it has had that Duralube stuff in it too.
    javadocjavadoc Member Posts: 1,167
    Sorry to hear about your engine going south, and I won't harp on you about oil changes.
    Your oil warning light didn't come on if you still had oil in the engine, or at least oil pressure. I wonder if you can have the oil tested to see if it had broken down, but that's prolly too late to do. Do you know where you folks bought the oil, like what brand it was? Or, if it was at "Iffy" Lube? Those quick change places are not known for their quality service, or oils.
    I think John's right, fight them on this, or at least try and come to a compromise... it sounds fishy to me that your engine went after 10k on oil, as it's not *that* much further than the OEM recommendations. My thought would be the filter clogged somehow and you weren't getting adequate flow, but still pressure (hence the light not coming on), but that's just a guess. I'd try and grab the filter (it's still your van, every piece) and have it tested at an independent lab or trusted mechanic.
    /java
    I use and swear by Resolve High Traffic carpet cleaner. I get it at Walmart. Here's that I'd recommend: You vacuum the van out thoroughly, then sprinkle the Resolve powder all over the van, and use the included brush to scrub it all in. Let it dry about 30 mins and then vacuum it all up (it takes a while). This should get your van nice and clean. You can use Tide and a toothbrush (not your wife's tho...) to work on the most stubborn stains.
    Others have used different products with similar results. A Rug Doctor would work wonders too I'd imagine.
    Best of cleaning luck!
    /Java
    nngimnngim Member Posts: 6
    Going 2,500 miles beyond an oil change interval (assuming there was sufficient oil in the engine) will not cause an engine failure. Something else was probably defective.
    Also, isn't the warranty 3 years/unlimited mileage? Shouldn't all MPV' s sold still be under warranty?
    I'm running synthetic oil and I am planning on leaving the oil in for 10,000 miles.
    I don't have my warranty book here but for those of you who don't follow the book, be forewarned that it probably says if you don't pay attention to their scheduled maintenance, it could void the warranty. As a legal matter, that won't get them out of everything, but on something like a blown engine, it will give them a lot of leverage, particularly in court. I would definitely try and fight this and tell them, if true, that the reason for the blown motor had nothing to do with the failure to change the oil -- it wasn't the proximate cause of the loss so they are responsible. If you go to court, you will need someone with expertise (a trained mechanic) that will testify to what I said in the preceding sentence because they will come in with someone that will say here's the warranty and they didn't do what they were supposed to so the warranty has been invalidated and most judges will accept that as enough to toss you out.
    Don't you have some bills that suggest maybe you "forgot" some of the oil changes ???
    tboner1965tboner1965 Member Posts: 647
    ...to have the oil sampled and analyzed. If it came back as being out of spec, then you don't have much of a case.
    However, if the oil was still within specification, then it makes Mazda's case weaker.
    I think Mazda has to prove that the failure to change oil at recommended intervals was the cause of the failure.
    Who is to say there wasn't a mechanical problem with the engine.
    Given the several thousand dollars up for grabs here, it certainly would be worth your while to spend certainly under $100 for oil analysis.
    However, it might be hard to find oil now that was not contaminated with coolant and other such items.
    I believe the longest mileage interval Mazda recommends between oil changes is 7500 miles. (It could be 5K, but I don't have the manual with me right now!)
    Food for thought. Most European carmakers recommend 10K intervals, or intervals dictated by the "computer" that gauges how the vehicle is being used.
    I am very comfortable with 10K intervals in my 87 LeSabre given that I will still do three oil changes annually. Of course I'm using Mobil 1 and changing the filter every 5K.
    The Mazda and the Contour get a change every 6 months, again with Mobil 1. That is between 3-5K on each vehicle.
    I do recycle the Mobil 1 on the Contour since it is "low mileage" and use it in the lawnmower crankcase before it finally gets turned in.
    Some of it may also find its way into the Buick as "top up" oil during the 10K interval.
    FWIW,
    TB
    IIRC, the warranty period is 36months/50k miles.
    I wonder where one goes to have oil analyzed in your area Jubnem? I know you can send it to Amsoil if you're using their products (check amsoil.com), but there's gotta be some labs in any metro area. We have five labs in our town that test oils, but this is an oil producing state.
    With today's technology, I can't imagine how a good lab tech couldn't sift through debris and junk already in an oil sample and tell you just what was up with the oil's makeup. Prolly tell you if it was from a Bronto or Stego-saurus for that matter!
    FWIW, if you do your own oil changes, I've heard of cases where a lawyer would argue that a consumer couldn't prove that they actually changed the oil, even though they had receipts for oil, filter, funnels, shop rags, etc... unless they had dated pictures of said oil change. They had to prove they acutally used the oil for the car. Craziness.
    Jubnem, plz keep our group posted on what's going on with your situation. I can't imagine Mazda being very unreasonable with this blown engine story, esp. if a newspaper got wind of it. I recall recently a story of a guy that had all kinds of (according to him) trouble with his VW, particularly with a certain dealership, and just wanted a rental reimbursed for around $50. Well, ugly things were said by both sides and lawsuits were filed, but then the news media got tipped off about it, and the dealership quietly settled the issue.
    I hope it's all going to work out for you Jubnim!
    /javadoc
    mpvowner2mpvowner2 Member Posts: 4
    Has anybody else had the following: Wednesday evening, tried to start the car (2000 MPV LX w/25K mi) which was parked in a heated garage, no luck. The battery was fine, the starter revved the engine, but there was no sign of ignition. We tried several times over the course of an hour, then the van was towed to the dealer, who looked at it the following afternoon, when (of course!) it started with no problem. The dealer has no idea why 3 people, over the course of a couple of hours, could not start the car -- does this sound familiar to anyone? I'm not looking forward to having a fairly new car with an intermittent starting problem... (BTW, I was using the same key as I always use -- the same key the dealer used to start the car)
    How weird is this! I too had the same problem on Christmas night. The wife couldn't get the van started. I pushed it in the garage(it was out while the kids rode the new ATV), recharged the battery, and it started for me. I did have to crank it and mash the pedal but it finally started. I just chocked it up to the kids leaving the door open and draining the battery and then the wife cranking it until it couldnt breathe anymore.
    Unfortunately, that same night my HD crashed on the computer and on the ATV the choke lever broke off. It was not a very good day for technology. I went to bed early!
    Well, I decided to call both corporate and the service manager again. Didn't do any good though. I asked the service manager if he even looked into the possibility that something else caused the problem and he told me no, because he was 99.9% sure with his 31 years of experience that it was due to lack of maintenance. He said he'd be glad to tear the engine apart to check the oil pump and so forth if I foot the bill for it. Basically, I got no where with him.
    With corporate, well, things got a little ugly. I talked to a different guy this time and he was just as obnoxious. I know I should have changed the oil, but I'm tired of these guys acting like it was just the crime of the century. They keep telling me that anything beyond 3000 miles puts the vehicle in grave danger. Puh-leeze! I've pointed out over and over that my manual recommends 7500 miles and they dismiss that every time. I ended up mentioning an attorney, something about small claims court, I also threw in something about putting a big sign in the window reading, "MAZDA ENGINE BLOWN AFTER 28K MILES," and parking it in front of the dealership. In the end, I told them I thought it was only fair that they offer me the engine at cost. I could tell the customer service guy wanted to smack me, but he just said that he'd forward my message to his boss.
    I'm sure it won't do any good, but I did feel better after venting a little. I don't know what to do. I appreciate all this advice though.
    My dad changed the oil last, and I doubt he's kept any receipts from anything. Besides, the service manager said it wouldn't make any difference if I could prove an oil change this summer. He said from looking at my engine, he knew it was lack of maintenance. He went back to his 31 years of experience bit.
    Again, I do appreciate all your advice. I'll look into have the oil checked. I just feel like I'm fighting a losing battle here.
    It might be a problem addressed by TSB #01-002/01 "Excessive amount of cranking time before starting" ( See details here: http://www.vakcer.com/mpv/info/tsb/0100201.htm ). It seems to cover VINs lower than JM3LW28G*10166896. I believe all 2000's fall within this range.
    I hope this helps.
    If you have receipts for oil and a filter that support you changed the oil, then don't accept what the service manager said. Then the burden of proof shifts to them. I don't agree with the earlier posting that says that even if you don't live within the service guidelines, they have to prove the reason for the failure. The validity of the warranty is premised on proper maintenance. If you admit you haven't done the maintenance, it gives them the opportunity to say you have no warranty for a particular item.
    Because you seem to have told them at least once you didn't do the maintenance, you are going to have a tough time getting them to believe now, even if you have the bills, you did the changes. I would find out the cost of the engine, get at least two estimates and go to small claims court and sue. See what that does, but it may not do much since these guys really do get sued a fair bit and chalk it up as the cost of doing business. Depending on the judge you get, you may need a mechanic to testify on your behalf because the guy with 31 years experience is going to say you are the cause.
    TOO funny, msgjvh -- my computer lost power just after the van had to be towed the other night. I too felt I was cursed & didn't want to touch anything else! I got the van back today, dealer couldn't reproduce problem, etc, etc. My own theory is that I have a car with an intermittent electrical problem (the alarm went off for no reason last summer as I was opening the door -- could this be related?), & I just have to wait & watch (& carry cab fare). Alexv1n, I don't think it's excessive cranking, because it works fine normally... I'll keep you posted if anything concrete turns up, & meanwhile will continue combing through the old messages -- what a gold mine!
    likaglovlikaglov Member Posts: 82
    I also posted this to "MY2000+ Mazda MPV"
    OK, I know how to tether my 3 yr old's car seat which is forward facing, but what about my 6 month old who needs to be rear facing for the next 6 months? I obviously want him in one of the middle row captain seats, but there isn't a tether bolt and I can't find a place where one could be attached. Anybody know about this? There's nothing in the manual. The only way I can see to tether his seat would be to put it in the third row and use a middle row tether. But there's no way I could climb back there with him to get him into his seat. Thanks in advance.
    pjd58pjd58 Member Posts: 366
    The engine didn't fail due to a missed oil change. But you shot yourself in the foot not doing regular maintance and not having the receipts as proof. What a terrible situation that could have been easily avoided. Mazda is under no obligation to save the day. It would be nice if they would met you half way, but don't hold your breath.
    You should check with the dealer, because I believe that they have the parts to install tethers in your MPV van, and the tether bolts will be located behind the second row when they do this. I had mine installed one day during an oil change for $18 IIRC, others have paid slightly different prices, but it's not expensive (s/b free imho).
    /java
    I think your best bet is to find a lawyer! Do it quick! Have him sue everyone, the dealership, MAZDA, the oil company etc., He will know the right steps to get it resolved. I am sure you will find one that is willing to take it on contingency.
    Hi Java, thanks for the input, I neglected to mention that I have a 2001-LX, therefore the tether bolts you're referring to are already built-in. My problem is for a rear-facing car seat. The tether would want to go under the driver's or passenger's seat, but I can't find anything to attach it to. The dealer looked at me like I have two heads when I asked him the question... Has anybody else experienced this issue???
    I didn't think you were supposed to use tethers on rear-facing seats? I could definitely be wrong in that assumption and I've never tried it. I'm trying to visualize it though. Where would the tether hook up to the child seat? Does a tether hook up at the foot of the seat? I can't wrap my brain around the use of it, but I'm using DayQuil (thx to my germ-factory kids, lol) today, so I'm prolly not thinking too clearly ;-)
    /java
    I have a Britax Roundabout car seat, it is convertible and they
    recommend tethering in either position. I've used it successfully
    for #1-son in our Civic and Corolla, but attaching the tether to the
    seat rails below the front passenger seat. We sold the Corolla and
    got the MPV while waiting on #2's arrival. Now I need to bump him
    from the carrier to the Britax, but still rear-facing. The tether
    comes out of the same place (top of the seat) but since he's rear facing, the tether should really attach under the front seats. see
    below - if my ASCII picture works
    (where: t=tether, ||=Mazda seat, //=car seat .=nothing,
    it wouldn't allow multiple spaces)
    REAR-FACING
    ||.......//t
    ||......//..t
    ||.....//....t
    ||//////......t
    =========......t
    ||.....||.......t
    ||.....||........t
    FRONT-FACING
    ......ttt
    ......t||\\
    .....t.||\\
    ....t..||\\
    ...t...||\\\\\\\
    ..t....=========
    .t.....||.....||
    t......||.....||
    Oh, I get now what you're working on here... the dayquil fog is clearing, and your ASCII artwork is inspiring.
    Big Kudos to you on getting a Britax, #1 rated child seat I do believe.
    Maybe THIS will help you. The link is from the NHTSA site, and it features a Fisher-Price Safe Embrace II seat (what I use in my cars) and it's using a LATCH system, that I suspect you can easily convert to be used for the Britax seat and using the OEM tether hook-ups in the MPV. From the pictures on the Britax site, it looks like you can loop tether straps through the lower restraint pathway and run the strap thru the gap in the seat cushions to the tether hooks that Mazda provides.
    Or, looking at the Britax site, they recommend you attach it to something like a seatbelt anchor point. Is this doable? I suspect you've already investigated all of these possibilities tho with every possible front-seat anchorage point. Can you install an anchor in the floor below one of the front seats and attach the anchoring strap there? Of course, if one is to drill a hole in the pan of your van, inspect the area first so you don't pierce something vital underneath the floor.
    Hope this helps,
    /javadoc
    I found out from a friend on a Volvo forum that Amsoil will analyze an oil sample for about $15, plus nominal shipping charges. I believe a company called Oil Analyzers, Inc. does the independent lab work and they reportedly can tell you any/everything about the oil sample.
    /javadoc
    Java - thanks for the research! I had to edit the ascii art due to the space issue, a little disappointing. It is so much easier in a fixed width font, but I digress...
    I did investigate under the seat, in fact there is a plugged hole under the passenger seat! I ripped the plug out over the weekend hoping it was a tether location, but alas it was not. I'm not sure what it is for??? The Britax site does mention a "connector strap" which should solve my problem. Worth the $4 to order it and find out anyway... Thanks again.
    jmokeojmokeo Member Posts: 1
    The connector strap works. We wrapped the connector strap around the base of the front seat "track", then connected the tether to that. It worked very well.
    Good Luck.
    cards_200cards_200 Member Posts: 44
    My dealer includes spark plug change in the 30K mile maintenance ($417). At that price I'll do the maintenance myself. But is spark plug replacement really needed at 30K? Manual says 60K miles. But perhaps this is like oil - and the platinum plugs should be changed prior to 60K? What are other dealers saying on plug replacement interval? Thanks.
    There is a spark plug replacement FAQ on www.contour.org and it should apply here as well. It shouldn't take much more than 60 mintues. On the front, you have unbolt the IMRC box (attached with 3 10mm bolts) to reach two of the plugs.
    On the back, you need to unbolt the coil pack (4 7mm bolts) and be careful that you reinstall the ground wire.
    I used a rather long extension, a really small dab of anti-sieze on the plug (too little is probably better than too much), dielectric grease on the top electrode on the plug attaching it to the wire, and liberal amounts of WD40 on the spark plug socket so it would release the plug instead of the extension releasing the socket.
    Took me less than 60 minutes the first time I ever did a Duratec, and that was with changing plugwires. (I had to have the 9mm Ford MotorSports wires because they looked good!)
    TB
    TB have you done the plugs on the MPV? It looks extremely difficult to get to that rear bank of plugs. Might not be worth my knuckles!!!
    pricetagpricetag Member Posts: 10
    At 32,400 miles the water pump needs replacing. Seems there are others out here with this problem too.
    Not done the MPV yet, but it does look doable.
    Waterpump, can you get pics. Autozone sells one with a metal impeller. If my guess is right, either the plastic impeller came off the shaft or simple broke up.
    TB
    Just curious, what symptoms were you seeing when the water pump failed?
    Someone before asked a Mazda tech about which waterpump is used in MPV and was told that it's a new design with a metal impeller? Anyone can confirm/disprove this?
    tango_28tango_28 Member Posts: 35
    The symptoms were that I smelled antifreeze. The waterpump in MPV is the new designed. The tech who replace the waterpump said that it was leaking at gasket. I did see the waterpump on mine MPV and it had the white impeller which indicates the new waterpump design.
    I just wanted to thank everyone for the great advcie and give an update. I finally got to speak to the district manager for my area today, 17 days after my motor died. He said that while he thought it was entirely possible that my missed oil change(s) were the cause of the blown motor, he's agreed to repair the van under warranty because they can't prove that was the cause. He was very nice and just asked me to promise never to miss an oil change again. I'm not exactly sure what brought on the change of heart, but I'm SO happy they've agreed to fix it!
    My next question now is what DID cause the motor to die? If I keep the van will it just die again? There's no way I'll ever miss another oil change, but I just don't know if I can trust it now. If it were your van, what would you do? Keep it, trade it in, sell it, what do you think?
    I'd keep it. Frankly you are the only one reporting major engine problem so far (no, I remember another one over a year ago - a guy did an oil change at a quick-lube-place and they didn't tighten the oil filter probably. Eventually the filter blew and engine died). Many owners already have considerable mileage and the Duratecs generally don't have a history of failures.
    But it is, of course, my own opinion.
    P.S. Are they going to replace the engine with a new one or rebuild the existing? Just curious.
    P.P.S. Glad they agreed to fix it for you. You must be lucky :-)
    maltbmaltb Member Posts: 3,572
    Glad your persistence paid off.
    I'd keep it.
    I'd vote to keep it also. Like Alex, I'd be curious if the dealership rebuilds or replaces the motor.
    WTG for keeping at it! I was figuring that they were going to need to prove that a missed LOF was the cause of the motor's expiration.
    /javadoc
    billmckinleybillmckinley Member Posts: 167
    First off, congratulations on getting Mazda to own up to the problem. Says a lot for your intestinal fortitude, and it says a lot for Mazda's essential commitment to customer satisfaction.
    Whether I kept it or not would entirely depend on whether they replaced or rebuilt it. With a new engine in there, the chance of lightning striking twice would be pretty slim--the Duratec is too reliable. But if they rebuild it, who knows if they'll address the underlying problem [always assuming that your motoral hygiene habits weren't in fact the cause, which I don't see how they could have been]? I might not get rid of it tomorrow morning, but I'd be trading it at my earliest financial convenience.
    On a 2002.
    My $.02
    RJ
