Speedometer Spike When Starting Murano
Is it normal for the Speedomoter to quickly spike ( the the max point ) and then return to Zero when starting ?
SUVs and Smart Shopper
I test drove 3 Murano's (the last being the LE AWD trim) and noticed this behavior with all 3 trims, hence was better prepared when I bought my own SL.
If you don't like it, you can disable it via the "DIAL EFFECTS" option on your dot-matrix display.
Just an effect - has nothing to do with an engine or start "spike"..
As others mentioned many race indicators / performance vehicles etc perform a complete swing of the gauge/needles as either a start-up calibration, or indication that the gauge is working properly and will display the entire range/parameter.
Cheers
