Acura TSX Electrical Issues
Just picked up an 04 tsx for a good price at a Nissan dealer. Took it to mechanic first who oked it for me, They would not warranty car. Did find some small problems (ie CD player and passanger side window switch) Negotiated a 400 discount due to the CD, and have found someone who wiill fix it for 300. Here's the problem.
When I brought the car home, went through the car, the left rear backup light is not working(the round one), and the rear right light that goes one with the headlights is not working. Took it back dispite the as is sale, the mechanic tried, but obiously doesn't know what he's doing.
The first thing he did was disconect the battery, without knowing the nav or radio codes, so I was on the phone with acura while sitting inside the trunk in their shop.
Would anyone know what the cause of the light problem would be?. Believe it or not, otherwise the car is real nice, drives well. But, I would not have chosen the RED color if I had a choice. I look like a fireball going down the street.
By the way, YES, I am a little teed off at the mechanic who OKED the car for me. I did pay them to go through the car. But, they've been working on my Hondas and Acuras for years, and don't want to burn that bridge.....
On the rear of the vehicle, you have your rear side marker lights, your signal lights, your brake lamps (the outer most round red lights), your parking lamps (on the trunk red round lights) and the backup lights. None of these lights illuminate with the headlights. all your markers and driving lights(including your brake lamps dual filament) will turn on with your parking lights.
Are you saying that the right parking lamp on the trunk and the left back up light are not functioning?
couple of things to trouble shoot..
** there is a TSB for Acura TSX 2004. There was a problem with a wiring harness at one point where the wires would rub through. This would only affect lights on the trunk lid, though. Might be worth a call to the dealership or acura to find out if the car has had the wiring harness inspected
1. Replace bulb with new one
2. Using a DMM, check for voltage in the socket when parking lights are on
3. If it is a parking light, they should be in parallel from one central point. I will try and check my manual later to see what the deal it.
Does anyone know what the problem could be? and is it safe to continue to drive the car?
