115v power outlets?
just got home with my 09 Sienna XLE and have a question. I see the two 115v outlets - can these be used for anything? can i plug my laptop in there and run it continuously while the car is running? i realize when parked it will drain the battery but i'm looking for some guidelines as to what i can use and how long - both while the car is off and when the engine is running.
thanks so much!
thanks so much!
Check in the owner's manual for the limit on amps.
It's probably meant for things like laptops, portable DVD players, and Nintendo DS/PSP portable gaming systems.
*** Relative to doing it correctly, PSW, Pure Sine Wave, inverter.
my laptop uses 90 W (per the fine print on the power adapter). I use my laptop all the time. What I don't know is the following:
is the limit of 100 W total for the sienna between the two outlets and therefore I only have 10 W that can be used in the other outlet or is it 100 W per outlet so if I had another laptop I could run it in the other outlet at the same time.
the manual seems to imply it is total for both outlets combined but does not say so explicitly :confuse:
or one laptop per outlet => two laptops per van (180 Watts) assuming we've only got two AC outlets
this is so dumb. in this day and age where people depend on their cell phone it would be nice to let your phone charge while you are out of the car for a while or even over night.
the argument that it prevents a battery from draining does not hold up as most devices do not draw that much power and they stop when the battery is full.
What does the owner's manual say is the max amperage?
