Cadillac SRX Loss of Acceleration Problem
Member Posts: 1
edited August 2018 in Cadillac
Purchased 2004 cadillac and while driving looses acceleration, no warning if I stop and shut off car and restart problem goes away. Intermittent pro blem. Problem will pop up again without warning. Car dealership cannot fix the problem, car has been into dealership several times. Can anyone help to troubleshoot this problem? I did bring car in when problem was happening they retrieved the code but it did not indicate the error. Now the car needs a #3 ignition coil and I am trying to find out instructions for replacing this part. Car is sitting in my driveway inoperable.. If anyone has any information would greatly appreciate the help.
«1
  • Member Posts: 1
    edited March 2010
    Did you ever find out the problem? I am having the same problem, along with many others! The Stability engaged message is coming on, the rpms rev up whenever I start the engine ( it stops when I put it in gear). I have had it to the shop every other month for the past year. The only thing they can find is crimped wired. And this doesn't take care of the problem.
  • Member Posts: 1
    I had this problem on my 2004 SRX. Dealer troubleshot with me over one phone call. This was the description on the work order...
    Check engine light on. No power at times, after shutting car off and restarting problem may go away. Scan system code P0221 stored found internal short in TPS in Throttle Body Assembly. R&R TBA and new harness soldered.
    Total cost parts and labor - $502.82
    Hope this helps.
  • Member Posts: 2
    Just put mine in the shop this morning - same problem except #5 ignition coil and spark plug. I am told I have 6 coils and that when one goes, others may follow. Labor is the same for 1 or 6. Cost about $75 each coil + Labor. Mine acted the same way - no code, turn off and problem goes away etc. I opted to do the whole thing as I trust my mechanic and figured may save me money in the long run. Lesson learned - never buy the first model year. Only one problem of many since purchased new.
  • Member Posts: 1
    My wifes 04 SRX check engine light came on. No big deal I figure gas cap right? On the way home from dinner when accelerating it would sputter and delay. The RPM were there but the response from the engine were not. When we got home I popped the hood and white smoke was coming from the engine with a bad odor. Not oil or antifreeze. I called my local mechanic took it in and it was an ignition coil. Total cost with labor $374. I had them replace all the spark plugs too. Total cost of that $150. I'm learning quickly you need to be rich to drive a cadillac!
  • Member Posts: 1
    Has any one experieced problems with the 2007 model where the accelerator appears to stick on during over run and the vehicle speeds up on its own even when the brakes are applied.
    I would be greatful if anyone has experienced this to let me know what happened, what the experience was like and how you compensated for it.
    Also what did the repair consist of to rectify this and was it carried out under warranty.
    If anyone has suffered this was there a service recall for the fault?
    Thanks in advance for your interest and help,
    UK_Police
  • Member Posts: 4,252
    uk_police,
    Could you please email me your VIN and current mileage? I would like to look further into your situation.
    You can get my email by clicking on gmcustsvc.
    Thank you and have a great weekend!
    Caron, GM Customer Service
  • Member Posts: 2
    I noticed many people are starting to complain about the electrical system in the Cadillac SRX’s. Well, I just brought mine after returning from Iraq a few months ago, for my wife and family to have a larger vehicle to get around in the city while I’m gone to work. Just recently, she complained that the electrical panel would completely turn on and the “Engine Power Reduced” alert would come on and the vehicle would completely shut off in middle of the road. Not a safe situation at all. She would glide onto the side of the road or push the vehicle; Try to turn the vehicle over and it would turn over after sitting for a while, and then try to make it home. I started to take the car to work to see how it was acting. Driving below 50 mph it would do the same. While gliding with no power I would throw the car in Neutral and continue to try to restart. Sometimes it would catch and sometimes is wouldn'T’t, which left me in middle of the road with my emergency lights on until it finally did catch.
    I have an extended warranty on the vehicle so I brought it into the Cadillac Dealer yesterday. The dealer said it had many codes that came up but he thinks one code, specifically, maybe causing all the others: Freight Booster Hose is busted. $175 plus tax to fix. Warranty does not cover it. I was kinda relieved that he may have found the problem until I read this forum on Edmunds.com. My family will be riding in this vehicle. Am I looking at a Doomsday Situation; a forever permanent problem that will never be resolved? I expected more out of GMC…not to mention a Cadillac.
    cnw1979,
    I apologize for your frustrations. Can you please send me your VIN, complete contact information, current mileage, and involved dealer? I look forward to your response. Thank you for your service!
    Christina
    GM Customer Service
  • Member Posts: 2
    Well the car was acting just fine for one whole day. The next day, the check engine like came back on and the same problem occured. The Hose was replaced, but, obviously that did not fix the electrical problem. My warranty company is having some issues at the moment so they told me to wait 2 weeks before I make another claim so looks like I'll have to let it sit until then. But it is starting to look as if my SRX is going down the same path as all the others. I checked the recall list and did not see anyrecalls about electrical issues, but all these problems are reoccuring.
    Are there any direct options? Maybe someone has figured out the exact problem somewhere.
    cnw1979,
    I would recommend continuing to work with your dealer. If you continue to experience concerns I would recommend setting up a case with Customer Assistance.
    Christina
    GM Customer Service
  • Member Posts: 2
    I am having the exact same problem too. I have had the throttle body replaced, had the catalytic converters done on the recall, ECU flashed, and numerous $$$ spent in diagnostics. Does anyone have a solution to this problem?? This is a major safety concern as I do not want the engine dying on a highway corner and not to mention the hassle of dealing with this vehicle.
    04 SRX with 160,000kms
  • Member Posts: 3
    I notice that several people have had the same problem with their Cadillac SRX that I have had and am wondering if GM has done anything to assist them. I seem to be getting the run around from GM and am thoroughly disappointed with the service they provide.
    In June 2011, I coasted out of my driveway, coasted down a hill to a stop sign and coasted down another hill to another stop sign at a busy road. When I went to turn left and accelerate the car the dash was completely dark and the check traction control light was the only thing lit and I could not accelerate the car. This is completely unsafe and scary when there is traffic coming behind you and you can't move. I rolled it over to the side of the road and shut the car off. Once I started it again, I still could not get the car to accelerate while it was in drive. I shut the car off again, waited 10 mins and started it again at which time I was able to drive the car. That day we took it to a dealership 25 miles away from my house in Hendersonville. The dealership was not able to replicate the problem and said the car was in working order. At this point, I accepted what the dealership said and figured it was an isolated incident.
    Sometime in the fall of 2011, this car did this to me again where the whole electrical system in the dash was completely black and I cannot accelerate the car. Luckily I was leaving a parking lot so having traffic around me was not a huge concern. The fact that it was the second time that his car has done this became somewhat of a huge concern to me. This time my husband took it to our personal mechanic who handles all of our company trucks. Once again, the problem could not be replicated and the diagnostic didn't show anything. He did, however, find a long laundry list of issues that have been reported with this year, make and model that have yet to show any recalls.
    Last week, March 13th, I was driving home from taking my child to school and the same thing occurred while I was in motion. I was able to pull the car over to the side of the road and had to shut it off and turn it on several times before I could get the car to accelerate again and get it to my house.
    One time - isolated incident....two times - something is not right....three times - this car is a HUGE SAFETY ISSUE. I called my leasing company, Ally/GMAC to tell them my issue and to see what it would cost for me to terminate my lease earlier than the end date - $9,737.88. I told the girl that I spoke with what was going on with the car and she transferred me to General Motors. I spoke with a person by the name of Ben who was helpful and understanding of my concerns with the safety of this car, especially since I have a child in the car with me the majority of the time. Ben aided me in contacting a different dealership in Asheville for me to take my car to try and locate and repair the problem. He offered to have it towed for me but the cost of the towing would only be covered if I took the car to a different dealership - the first one I took it to when the problem first arose. I wasn't interested in taking the car to that dealership since they were unable to locate a problem to begin with and I wasn't interested in absorbing the towing costs to get it to a different dealership, so I drove the car there myself avoiding the interstates in case it happened again. Ben arranged for me to take the car to the Asheville dealership via a conference call with a service tech at that dealership. I was told they could give me a loaner car and they would see if they could figure out the problem. I took the car and left it, completely unhappy with the poor quality loaner car I was given from a rental place.
    The next day, the dealership called me to tell me my car was ready and that they couldn't duplicate the problem. Not a big surprise....I can't replicate it because there is no rhyme or reason as to when the electrical system will shut off. I also advised the dealership that I frequently get a loud pop out of the stereo system and it will also shut off as does the entire center console, including the air conditioning/heat system. The disc will eject itself and if I pull it out and reinsert it, the stereo will come back on. Again, they said they can't duplicate the problem.
    So now it was back to dealing with Ben at GM. I expressed to him that my concern for the safety of this car was my number 1 issue and that I wanted to terminate my lease. The car was a gift for my 40th birthday from my husband - it was exactly what I wanted and loved in a vehicle. Up until this issue started, this car needed nothing but oil changes and tire rotations. Once these issues started the love for the car started a fear of driving the car, especially with my family in it. He had stated to me that I could possibly get a different one or that terminating my lease shouldn't be a problem but that I needed to be assisted by a senior or district specialist.
    Enter Jim, the district specialist, who is nearly impossible to get a hold of. On March 19th, Jim called my office and left a message for me to call him with his extension number. He never bothered to reach me on my cell phone even though it is part of the case number. I have made more than 70 attempts to reach Jim on his extension to no avail. I have left him several messages to return my phone calls and he has failed to do so. Once I got a hold of an actual person at GM, I was told that I was scheduled to receive a phone call on Friday, March 23rd between 4 and 6 by Jim. Again, Jim has failed to call me. I hate to think that this person is a specialist in the field of customer care for General Motors because his customer service leaves little to be desired.
    Today, March 26th, I was able to get a hold of an actual person named Elizabeth. She connected me with a different specialist by the name of John. John reviewed the case briefly and proceeded to tell me that since the dealership could not duplicate the problem with the vehicle that there was not a problem to fix and that is the resolve to my issue and GM could not help me any further. I expressed my concern again with the safety of this car for myself, my child and my husband and he really didn't seem to care. I was told, in no uncertain terms, that is the resolve on GMs end. He refused to connect me with a supervisor and told me I needed to wait until my scheduled call this afternoon with Jim between 2 and 4 and would have to talk to Jim's supervisor, who incidentally has no extension number to be reached. Now I am irate! I asked him if General Motors is going to assume liability if I am injured as a result of this acceleration issue. His response was rude and uncaring. When I told him I wanted the lease terminated, his reply was again rude he basically said they can't do that.
    I find it hard to believe that I am the only person who is having this issue
  • Member Posts: 1,964
    hollyw108,
    I understand how concerned you are with safety from your post, and want to apologize for any unsatisfactory interactions you have had with our Customer Assistance Center. What is your case number? I would like to look through it to make sure that everything has been handled appropriately.
    Sarah
    GM Customer Service
  • Member Posts: 3
    Sarah,
    I am glad you understand how concerned I am for the safety of myself and my family in one of your products, apparently the people I have dealt with do not. According to Jim, GM has done all they can do and recommend I should continue to work with the dealership. I will NOT drive an unsafe car.....it is being parked until my problems are resolved to my satisfaction - I am the person paying for this car after all. Case no. is 71-1048003541.
    Good morning hollyw108,
    Would you mind sending me an email? I have looked up the case and would like to ask you a few clarifying questions. Please send it to sarah_grace@gmexpert.com
    Talk to you soon,
    Sarah
    GM Customer Service
  • Member Posts: 1
    I have a 2011 SRX and am having the same problem. Brought it to the dealer 8 times over the course of a year for various electrical issues, three times it has completely shut down - I get free law service at my company and I honestly think thats where I am now - Car is one year old.. and I just want them to take it back! I am petrified of driving it, afraid its going to shut down and I will get killed... its a nightmare - never a cadillac again.
    michele61601,
    I'm sorry to hear you describe your SRX as a nightmare, although given the details you have posted I understand. If we can look into this further with you, please send an email to socialmedia@gm.com with more information, including: your name/Edmunds username, phone and address, the last 8 of your VIN and current mileage, and the name of your servicing dealership. If you would also please include any details you recall about visits to your dealer for the electrical issues you alluded to, that would be helpful as well.
    Best,
    Sarah
    GM Customer Service
  • Member Posts: 1
    edited April 2012
    I am the original owner of a 2006 SRX. I have had multiple prpblems from just turning off to replacing the front axels at 80,000 miles, they were knocking. Last June the engine light come on at 95,000 miles. There was a lose of power and rattle under the car. I spoke to the caillac dealership, they said "catalytic Converter. However, the warranty ended at 80,000 miles, not to mention the parts were back ordered for at least 4 months. Therefore, I took it to a local tech. He placed bothe catalytic converters, and the sensors. $1700+. Now 5 months after getting out of the shop, the engine light is back on, and power loss, same low engine roar, and oil coming back to the air filter. To top it off, I have found where now after the fact GM has extended the warranty on original equipment to 12 years, 200,000 miles. HELP!!!!
    stwall,
    Thank you for taking the time to post your concerns. I apologize for your frustrations. Can you please email me your VIN, current mileage, and GM dealer of choice? Where did you have it fixed last time? Have you spoke with the dealer since it started again? I look forward to your email.
    Christina
    GM Customer Service
    SocialMedia@GM.com
  • Member Posts: 2
    Sounds like we are all having the same issue with this vehicle. If anybody gets a solution, please post. Mine is about to the dealer again for a re-flash of the computer; hopefully that will fix the problem instead of having to purchase a new ECM.
    Has any one at GM figured this issue out yet? It's hard to imagine that with their available resources they can not nail down the issue. I'm not looking for warranty, I'm just looking for a solution.
    Hopefully the re-flashing of the computer is successful! Please keep us updated on your progress, and if we can be of any assistance let us know.
    Best,
    Sarah
    GM Customer Service
  • Member Posts: 3
    Here's a solution for all you having this loss of acceleration problem....get rid of the death trap you are driving and get yourselves something safe for you and your families to ride in!!
    I went back and forth for weeks with GM to no avail. It seemed as if they were helpful in the beginning but once the car was at the dealership for the 3rd time and the problem could not be duplicated, there was no problem on their end and became rather rude in their approach to my problem. Their advice...keep working with my dealership until the problem is resolved. Frankly, I expected more from GM, especially Cadillac.
    I knew I would get no where with this corporation when I was asked if I had sought legal advice. Advice was not what I needed - legal representation was. After discusssing with my corporate counsel my best options, I came to the conclusion that it wasn't worth the fight and the money it would cost me to go up against GM. It was worth it to lose a little money, buy out my lease and trade that junk car in on a very reliable, foreign model. I now have piece of mind that my car will not stop operating while I am driving it and that my child and my family are not in danger on the road.
    Thanks for nothing GM... I get a new car every 3 years and I will never purchase another one of your products again.
  • Member Posts: 1
    I have a 2008 SRX4. I bought it two years ago with 18k miles and have enjoyed the car with the exception of multiple trips to the mechanic for engine issues. The ifrst time was for some known 'timing chain' problem and then recently for an ongoing battle to keep the car on the road. My car has an issue going over the railroad tracks in town. It decides to accelerate for 2 seconds and then dumps power with the error message "engine power reduced". I dropped it in nuetral and restarted the car which made it run for about a mile. Then we repeated this process about a hundred times trying to drive the 30 miles to my mechanic. He flashed the computer and told me to sell the car. He said that if thid fix didn't stick-which it wouldn't-we would have to put a $1200 computer in it. Well, guess what, it didn't stay fixed. The engine light came on the same day I got it back. One week later, It died again-on the same railroad track. It's killing me. I seem to keep having motor/computer issues. I haven't even hit the suggested tune up mileage yet. I am sooo disappointed in this car. I can't even get rid of it because it's value is in the toilet. What is wrong with it this time and why doesn't Cadillac care that they have a bunch of lemons on the roadway!
    I am a Paramedic. I know what happens when cars just speed up or stop running in the middle of the road. Not to mention the personal injury to me and my family-I am going to be sued civilly for driving a POS and endangering the public!
  • Member Posts: 1
    I just bought a 2011 45 days ago twice while driving in the rain the car shacks rattles and losses power when you give it gas I have had it to dealer it is there now first time they couldnt get it to mess up after reading all the post I am worried if I should sell it before it is to late I was told that there is no electrical problems with this model so I know my dealer lied to me any idea on the problem so I can tell my dealer what to fix because they have no idea
    Good morning grizz62442,
    Congratulations on your new SRX! I'm sorry that you're already encountering some difficulties, however. Have you contacted Customer Assistance already? Looking forward to an update on how your dealership visit went.
    Best,
    Sarah
    GM Customer Service
  • Member Posts: 9
    I have a 2004 SRX that is losing power also and no one can figure out the problem. My mechanic said I better take it to the dealer so I did an $800.00 later they tell me the car is fine and 2 days later I lose power again. Its been in and out of the shop for the last three months and no answers. I'm scared to drive it but need to have my car working any suggestions for me??
    Hello blondie54,
    If we can look into this with you, please email the following information to socialmedia@gm.com: your name/Edmunds username, phone and address, the last 8 of your VIN and current mileage, and the name of your involved dealership. With this information, we'll set up a Service Request (a file in our database), contact the dealership you've been working with, and move forward from there.
    All the best,
    Sarah
    GM Customer Service
  • Member Posts: 1
    Hi
    I am having a similar problem but only at 60 MPH. It briefly loses power.
    I am wondering if it is an inherant problem or not. just yesterday then engine symbal flashed a few times then went away. I check my oil level right away and it was fine.
    Good morning,
    If you were planning on working with a dealership on getting this diagnosed, we're available to you during the process of resolving this and can be contacted at socialmedia@gm.com (please include your name, contact information, and the last 8 digits of your VIN should you email).
    Sarah, GM Customer Service
  • Member Posts: 1
    srx 2006 brought used in 2009. Driving speed droped to 40miles per hour on the highway. Made it almost home. Then car died. Would not restart. Towed to dealer. Dealer states this is a serious engine issue. Wants a grand to see what issue is. Called GM the need to know what is wrong before they help. This should not happen with this car. I have just over 100,000 miles on it. Out of warranty of course. I thought this was suppose to be the best engine that gm makes. Any thoughts or any one else had these issues?
  • Member Posts: 1
    We own a 2004 SRX (V8) with 86,000 miles that we have been having problems with the Traction Control Light coming on since the day we bought the car just over a year ago. The light comes on, the car runs rough and then usually stalls. If I turn the car off to clear the system and then back on. SOMETIMES it will be ok… but not always. And it doesn’t work to turn the light off manually.
    We have had it in to our local garage two times now and it has worked fine when we get it back… but only for about a couple months each time. They have reset All codes.
    Any suggestions?? It sounds like others have had this same problem. I don’t want to drive it!! And I love the car…
  • Member Posts: 1
    Sarah,
    As I am reading all these posts over the: a) the stability control system, 2) the lost of power, 3) and all other non maintenance problems. I just bought a 2000 SRX with 56 1/2 K miles, I am wondering how pervasive is this problems, and , is GM about to issue any king of recall for all these frustrations the owners are complaining about?
    Good morning!
    I saw your email come through and you will be receiving a response back from my co-worker Cortland from socialmedia@gm.com; we try to divide up the workload as Edmunds is quite the extensive forum!
    All the best,
    Sarah
    GM Customer Service
  • Member Posts: 2
    I have spent all day reading all this post and hoping to find a solution before i take my car in to a dealer. We have a 2006 SRX and my wife just came hope telling me that the car just suddenly shut off and a message came up on the stereo control "Engine reduced power". The car could not accelerate and so she had to find a way to pull over and after a while it start and could accelerate again. But the engine light has stayed on since then. Has anyone had look with this issue so far. I really will not like to spend money and not get it fixed. Help!!!!!!!!!!!!!
  • Member Posts: 2
    Hi i was just reading your post and wondering of you could point me to where i could find information on the extended warranty you indicated. I am having the same problem.
    x840wagon,
    We hope you get the feedback from the community that you're looking for, and see that you're considering working with a dealership on this. Please let us know if you would like for us to check into anything further! We can be reached at socialmedia@gm.com (include your name and contact information, the last 8 digits of your VIN and mileage, and a brief summary of the situation).
  • Member Posts: 2
    Ok so my wife and I just rolled out of the Cadillac parking lot at 7pm w/ her new (used 2010 SRX Premium), heading I-95s and literally at 8:35pm we were on the phone w/ OnStar trying to get a tow because the Check Engine light came on as well as the "! Engine power is reduced" indicator. Words can't describe how p!ssed off I am, I realize we bought it used but from a Cadillac dealer.
    We hope everything worked out okay last night, sully5591, although we're very sorry to hear about the situation. Please let us know if we can look into anything further for you by emailing us at socialmedia@gm.com (include your name and contact information, the last 8 digits of your VIN and mileage, and a summary of the situation so far).
  • Member Posts: 2
    So Moore Cadillac calls us yesterday apparently the SRX checked out they couldn't locate and problem, today my wife is running errands w/ our new born (7 week old daughter) and right in the middle of Rte 1 "Engine power is reduced" causing my wife to instantly have to pull over to the side of the road. Now i'm researching Va Lemon Laws because it hasn't even been 48hrs since we bought the crossover and already twice w? the same message. I'm sure after we get it towed again this time further away that Moore will run the code say they didn't see anything have a nice day. God forbid my wife and baby get into an accident behind this its a Lawsuit waiting to happen.
  • Member Posts: 1
    I have a 2006 Cadillac SRX. Since I have had the car 4 times, it will just start spitt and sputtering down the road, won't hardly go. The check engine light will flash. We have took it to a dealer, and independent mechanics, the computer shows miss fire, nothing wrong with the car. It will go good for about 3 months and then the same problem all over again. I have spent a fortune on everything but the problem because no one can figure it out.
  • Member Posts: 2
    Hi there, I just wanted to let everyone know that when engine light came on it was because of a bad gasket which got replaced then the engine light continued on so our mechanic said it was the accelerator chip that needed to be replaced. We are replacing that tomorrow however they said if its not the chip then its the whole accelerator, I guess we'll see tomorrow.
  • Member Posts: 2
    Is your Mechanic in San Diego? I had the same problem with my 04 SRX
  • Member Posts: 1
    I own a 2012 SRX. After nine months and only 6000 miles, the car started to hesitate upon acceleration. It would slowly roll me forward and then jump suddenly as if I were peeling out. This has left me and my family in very scary situations. Pulling out into traffic is frightening because you never know if the car will respond as it should. This does not happen all the time. But once was plenty. It has occured at least 15 times. I have taken the car to the dealer 3 times for this same problem. The second time, they actually admitted that the car did it, but that it was only slightly? I was informed after 4 days with my car that the dealer now has a piece of paper that lists my Model, Make & Year car as having this known " Characteristic". Within minutes of retrieving my vehicle from them, it did it again while exiting their drive way! My Father and I were almost struck by a truck. I contacted their service department immediately ( from my car) and told them what had just occurred. I asked if there was video of their driveway and was told yes. I then requested for someone to go see what happened just then. I was told that it was not necessary, and asked to bring the car back again. I did so and left it for a week. They drove it 44 miles and had no problem, so I'm on my own dealing with this. I did contact GM from the beginning..... Worthless all the way through. They call and act like they care and are there to help.... But it's all lip service. The GM contact (Cindy) @ 866-790-5700 x 41084 repeatedly would say "no problem" , what???? This is a problem! I have personally owned at least 15 GM vehicles, and this will be the last. My two businesses have fleets of GM trucks. This too will change. I can't believe that GM will put me and my family in danger to save a dollar. Its very disappointing that they don't stand behind their product. This vehicle is NOT fit for the purpose it was sold!!!! GM needs to step up and do the right thing. All I want is for my car to be fixed, not excuses about characteristics. If it were characteristic, it would not have waited nine months to start showing. I would have noticed it from the beginning. GM case 71-1226526070.
  • Member Posts: 1
    Ralf Nader should have waited to do his thing with this POS. "unsafe and no speed" and in my opinion this is the worst car ever made. My wife bought this car new and still have it today and trust me not because we want to. We have dumped more money in repairs into this crap wagon than we paid for it new. The local Caddy shack by us knows us by our voices on the phone. And now that the government owns GM I'm sure the people who own these rolling money pits will never be taken care of. We can't even trade this pile in no one will take it and now it is putting itself into low power mode and engaging the stability control at random! I currently have it for sale locally but don't feel comfortable selling it to anyone except a child molester. Thanks for ruining our life GM!!! No joke!
  • Member Posts: 1
    I purchased a 2013 Cadillac SRX at the end of January. Around September, I was told I had 3 recalls and a system update. About a month or so after the repairs, my car started to lose acceleration. The car would jump and then lose acceleration for a couple of seconds. Took the car back into the dealership December 2nd, and they could not replicate the problem. I googled the issue and found 2 forums with customers having the same issues. I showed the dealership the forums and all they said was, "hmmm, we will have to do more research, because there's nothing we can do." 2 weeks later I was at a four way stop, and the car lost acceleration again, and I almost got hit by a car. Called the dealership back up and explained how unsafe the car was. They said the only thing they could do is drive the car around until the problem was replicated. I contacted Customer Service, which turned out to be a complete waste of my time. I was told I would receive a phone call from a customer service manager within 24 to 48 hours regarding the issue. A week has gone by, and the service manager never contacted me. In fact, he told the service agent to deal with it. According to my service agent, my issue has now come "full circle". He has now said driving my car around to duplicate the problem would be a waste of time since I've only had 3 issues this past month. He did finally agree to put a monitor on the car for a couple of weeks to see if it can read any problems. $50k is a lot of money to spend on a car which is CLEARLY unsafe to drive. I've never experienced customer service this bad in my entire life. My family and business will not be purchasing any more GM cars, in fact, I will be trading this car in if the issue is not resolved promptly. I should have known better, and gone with the Lexus.
  • Member Posts: 1
    Please add me to you list of people having the same problem with the 2010 Cadillac SRX. We had our car tuned up days before leaving on a road trip and the car was fine. I am on a trip from Arizona to New Orleans and back to Arizona. We had the engine losing power problem on Rt 49 heading to NOLA a few days ago. I pulled the car into the break down lane and after shutting the car off when restarted it drove fine but the engine light remained lit. When we arrived in New Orleans and the car was restarted the engine light went off. Now driving back to Arizona on the same route in approximately the same area the problem reoccurred. The only other place we had a problem with this auto was twice at Route 66 casino in New Mexico one year apart where we were not able to start the car in the morning after staying in the hotel. In those instances our OnStar service also would also go out. I have noticed that in most cases dealers are not able to determine what is causing this problem might it be an external electronic signal effecting the engine?
  • Member Posts: 19
    edited January 2014
    Would anyone like to forward an opinion as to why Cadillac is producing such poor performing vehicles nowadays? i have read all the posts and the litany of complaints is amazing. I just want to understand why Cadillac, once at the forefront of engineering excellence is at the back of the bus now.
  • Guest Posts: 52,454
    edited January 2014
    Well, it's a "problems" discussion. People typically don't take the time to brag on their cars anyway, but when something breaks, they like to vent.
    That said, JD Power Circle results are "only" 3 stars for the SRX and CR says the model has "declining reliability". This USA Today story is a bit dated, so you may want to hunt around for newer numbers if you are in the market.
    For the newer models, it'll take a while to see if the stats have turned, what with GM coming out of bankruptcy etc.
  • Member Posts: 1
    I have a 2004 SRX and I have been having similar troubles. Does anyone know if there is a updated wiring diagram for the Throttle body & harness connector? I have replaced mine, and still doing the same things. I have also replaced the Throttle pedal & the ECM.
  • Member Posts: 1
    I am experiencing the same thing with my 2005 SRX. My car looses acceleration when I am driving. It has shut down twice while driving which is scary in Dallas traffic. Engine light comes on and I have gotten a "theft error code" twice. A couple of times it has "jumped" when I hit the brakes to stop like it might be a problem with antilock brakes or transmission. I have had it to my mechanic twice and to the Cadillac Dealership three times but they have not been able to find the problem . It does not show any error codes. They told me they need to see what it does before they can fix it but it doesn't happen consistently so I am in a Catch 22 situation. My car has problems that need to be fixed but nobody can seem to find the answer. I am afraid to drive it and don't want to sell it to someone else with that kind of problem. It is dangerous.
