Volvo XC90 Ignition Switch
How is the release of the key controlled ?
I can not remove the key from the switch, need to remove the 5 amp fuse to park the car.
Shifting is not a problem and appears to be going into Park .
this will turn off all accessories and you won't drain battery. Until you can get to a dealer to repair problem. BE sure to you have your spare keys with you before you lock to door. Anyone have a answer to avoid dealship?
