Yukon - No speedometer, odometer-won't shift to 3rd
I have a 2004 GMC Yukon 4WD...the speedometer and odometer stopped working(the other gauges are fine), and the transmission will not shift into 3rd gear. no check engine lights...I replaced the VSS sensor which did nothing. Could it be the cluster? Would a bad cluster stop the transmission from shifting?
