Volvo XC60 Lights
Thanks in advance for the advice. The right rear tail light lense is broken on our 2010 XC 60. Fully operational but unfortuately a baseball size hole in the lense. No other damage thankfully. Based on what I can see of the Volvo parts inventory list on-line, the entire light assembly must be replaced in order to replace the lense. I am hoping it is a plug in unit and that I can replace it myself. The method of holding the assembly in place is not open and obvious other than a clip that appears under one of the hatch door rubber stops. Has anyone seen a manual on this or are you otherwise familiar with whether this is a DIY project or one for the dealer. I appreciate the help.
Instead of red cover, Volvo should change to a clear cover like other car makers did, then problem solved. With only the left one on, not only it does not look good but also the police may give me a fix-it ticket.
Does anyone know how to fix it (re-wire or fuse, connection...) in order to turn on the left for light?
You can't "fix it"... it's working properly.
regards,
kyfdx
Thanks for your reply. This is my first Euro car (always have Japanese cars) so I don't know that until now. I will take a look of my sister's BMW and Mercedes in order to satisfy my curiosity.
I don't think BMWs come with rear fog lights... Audi, Volvo and Saab for sure.... don't know about Mercedes..
