Toyota Highlander Keys and Remotes
Hello all,
I am new in here, I have a 2004 Highlander limited and the keyless entry remote suddenly is not working tonight, I tried to replaced new battery, but still no any response when push lock and unlock buttons. What could be the problem?
Any help will be appreciated.
Cyberlei
Cyberlei
the alarm has gone off 2 or 3 times and i just have to wait for it to stop...
Is it the battery in the remote? we are searching for a new battery...hard to find around here.
Help...need my car back!
I am new here,i am having problems using the keys to open the doors without the remote.
As it stands now if the battery in the remote runs down and the car is locked i cant use the key to open the doors,its that how it is supposed to be?
please need answers urgently!
Cheers,
odeh
Shelly
The biggest problem is the horn. You can unplug the dual horns by delicately pulling the connections out just behind the grille but you lose your horn. You'll still have the flashing lights though. Or, you can disable the alarm system completely by pulling the electrical connection from the hood latch alert switch which in the '08 is centered directly behind the grille. If you choose the latter you can re-connect the horns and, sleep at night.
*2008 Limited
