Front Wiper Problem - 96 Town & Country
I'm having a problem with the front wipers on my wife's 1996 Town & Country. They were working somewhat sporadically and then stopped altogether. So I replaced the wiper motor (a pain in the patukis!), the power relay, and the switch, and they still don't work.
Doing some snooping around the net has led me to believe that the only thing left, other than replacing the wiring, is the body control module. Am I on the right track?
Note: The wipers will move a bit when I push the windshield washer...
Once I replaced the body control module, the wipers worked fine.
Here is a link to the instructions that I used to replace the module:
http://wiki.answers.com/Q/Is_it_difficult_to_replace_a_body_control_module_on_a_- dodge_caravan#page3
i have a 96 town and country my wipers dont work at all they only make noise if i push the washer fluid button....the washer motor makes noise but the wipers dont move....if i run a wire directly to the harness on the wiper motor they work fine
