91 Nissan Stanza radiator fan
I just bought a 91 Nissan Stanza and am having a problem with the radiator fans coming on when the car gets hot. I let the car idle for awhile and noticed the fans weren't turning on. When I got in the car, the gauge was near hot. So I turned on the AC switch and the fans came on and the engine cooled back down. Yesterday, the fans ran non-stop and I had to turn the car off to get them to turn off. So is this a fan relay malfunctioning or is it the thermo-switch in the radiator(if it even has one). I would appreciate anyone's input, as there is no manuals out there that has any info regarding this problem.
In the service manual it says to check continuity at 194 deg. F.
The switch is open(fans off) at 193 deg. and the fan is on at 194deg.
the switch is closed. Or the relay could be the problem. Some models
have two relays. One operates the fan when the A/C is turned on,
and some the thermo switch operates another relay. Cheers
