This may not be your problem but it might be worth a try,even if you just change models of goodyears.
I live near a very successful Dodge dealer and consequently I know very many people who own Dodges. Almost everyone I talk to is absolutely satisfied with their vehicles.
Dodge fans are probably the most devout fans there are and we can't all be stupid,I am willing to bet that Dodge is at least on par with the quality of the rest of the companies.
First person I ever heard disappointed with Michelin performance.
When the belt tensioner bearing goes out, as mine did, it's loud as hell. It'll sound like a machine gun under your hood. You'll lift the hood and see it chattering away like there's no tomorrow!
30,000 miles until a persistent whine drove me
to Pep Boys...needless to say they wouldn't even
mount the 30,000 mile tires as a spare...too
worn out ...nothing new in my experience with my
Goodyears..
I noticed a tapping noise in 'PARK' seemingly from the steering wheel - found that the linkage from the gear select lever to the tranny has one link without bushing. It will continue to get worse, I assume, as the constant rattling eventually makes this link wear and open more. The bushingless link is 2nd or 3rd link FROM tranny.
eb
It has 8500 miles. Rotated tires at about 7500 tires in front were scalloped on outside edge. Got worse since clockspring assy. was replaced. Going back next week for another appointment. Supposedly all front end parts are fine. Now they are saying it might be steering shaft/column, possibly rotors, etc. Just wondering if anyone experienced this. Jackarse of service manager tried to initially tell me it was the nature of the truck and the aggressive tread pattern. Test drove a new one, much tighter and no vibration like mine. Hopefully I won't have to go through lemon law or buy back but not driving it like this much longer.
The reason I ask, is because the recall notice indicates that it applies to only "some '00 and '01 model year Ram pickup trucks" and according to the general info. that I have been able to acquire on the Rams prior to and after my purchase, seems to indicate that the Saltillo, Mexico trucks (such as mine) are less prone to flaws and assembly problems than those that are from Missouri. I'd rather not have the dealer screwing around with the truck if not necessary.
My gf's 2001 4x4 QC just started this a month ago. When you turn left or right you get a thumping in the floorboards and the steering column I don't believe it's in the front suspension because it drives great, except for the thump. I think it's a bad bushing in the steering column Sometimes you can feel it in the pedals but I believe it's just the vibration traveling down the column I also read in this forum somewhere about a similar problem and they replaced the entire front end and it was still there. Finally they ripped apart the column and found the shaft bouncing around.
Anyway, her truck goes in next week for the clock spring and I'm gonna tell the guy to check it out. Keep me posted @ dodge826@aol.com if you hear anything before I do. Thanks
and automatic transmission. At approx 10000
miles the transmission begin to slip and sung
when put under a load. The dealer replaced
the front transmission pump and said the problem
was corrected. I did not get a block from the dealership when it started slipping and surging.
The next trip they adjusted the TV cable and
pressure in valve. Same results the problem
continued as soon as I left the dealership.
The next trip they replaced the clutch plate and
separator. I thought this corrected the problem
but it did not. It now operates fine in the
morning when the engine and transmission is not hot but in the afternoon when the engine and
transmission is hot and I am going up a hill
or putting a load on the truck such as passing
gear the transmission slips when shifting into
a higher gear. This is a random thing it may
go two or three days without a problem. The
dealers service manager and I drove the truck
for an hour yesterday afternoon and of course
the transmission would not slip. The dealer
connected his diagnostic equipment to the trucks
computer system and it did not show any problems
with the transmission or torque converter.
Has anyone experienced similier problems, if
so what was the fix if any.
Its got fuel its getting pressure at the filter (the pump runs for a short while after its cranked so I loosened the banjo on top of the filter lots of pressure/fuel)
It turns over fast but will not start, any ideas?
the thing is I am in england so there are no dealers at all so I have to fix it myself could it be a sensor somewhere, please any suggestions
Do they have one as standard? it has an alarm and key less entry.
He says its a lap top job to get it going again then said good luck and went.
If it has an immobiliser can it be disconnected and it so where is it and how.
