-September 2024 Special Lease Deals-
Chevrolet Malibu Maxx Accessories & Modifications
Does anyone know of a source for an engine cover for the 3500 engine that is in the MAXX? I see I mine does not have one and others do. Thanks!
Where is no engine cover on my 2004 MAXX LS.
Is it suppose to be there?
Can you post the link to where you got the part?
Larry :-)
Larry :-)
"Larry,
My parts department went to order the engine cover and a message popped up that said engine cover not available for year make and model of vehicle. So they called General Motors and in 2005 General Motors did not put engine covers on the Malibu Maxx. There is not even one that can be ordered. This was a big surprise to me, apparently you can get one for the regular Malibu's but not the Maxx. Anyways, let me know if there is anything further I can do for you. "
So back to square one. Oh, and what does it look like? They are black plastic, with "3500 V6" on them and they cover the top of the engine. Looks rather nice!
However I should have mentioned this - cover won't attach properly to older engine because there were some other changes to put in attachment provisions. One would likely have to have 2 cars before/after to see what changed
Those are merely sound insulation - they will not drop down and smother any engine fire.
I am sure someone else will post about replacement tires since there have been some messages previously on that subject. Not from personal experience but I have seem many positive comments on the Goodyear TripleTred however it depends on how much you want to pay.
What gear ratio is in the Maxx and the Malibu? I understand they are different. I wonder what the Maxx would get if the ratio's were swapped. But then could the speedo be corrected?
The final drive ratio on transaxle for the sedan with 6 cylinder is 3.05, for the Maxx and Sedan SS it is 3.29.
I remember reading (C&D perhaps) that the Maxx was 3.65 or something like that?
It was one reason the Maxx SS did so poorly in fuel economy ( but burned rubber easilly, a trait delighting the CD folks).
Thanks for catching it
the other item I did....since I had custom rims for two years now.....five spokes.......I painted the brake calipers this weekend ceramic silver...really makes them stand out..behind the rims now...also wired brushed the rusted areas of the rotors..and spray painted them a high Temp black...to offset the silver calipers and wheels....paint kit 7.95 at any autoparts store
I have a 05 Max LT with the dual line UN0 radio unit. It has a band selector but when I cycle thru it doesn't show an aux (just fm-am-cd). I want to connect my Sirius Sat radio via an aux-in.
Questions:
Are there straight forward aux-ins (ie no need for converter, DIN plugs, ect)?
Will the "band" button recognize the aux unit?
Where do I start in taking apart the panel?
Almost 16K on my 2005 Maxx LS... only issue has been the driverside front turn signal... rigged repair from dealership waiting for new socket to come in... unfortunately they gauge the hell out my lamp module and are replacing that as well.
Its called an AR Power Chip (for Max 04-06 part #1010)from Accel Racing (AccelRacing@tampabay.rr.com). Here's the ad:
Specifically created for the CHEVROLET MALIBU MAXX, the AR power chip is built and designed with horsepower in mind. 20+ to be specific. Amazingly small and simplistic, this mod is guaranteed to increase your engine’s horsepower and torque output.
Accelerate faster. You can be guaranteed to feel a difference. 20 horsepower is exactly the type of performance upgrade you could expect from more popular yet more expensive modifications. The AR power chip gives you this exact same performance boost out of a small, inexpensive chip. And best of all it’s easy to install. NO MECHANICAL EXPERIENCE IS NEEDED. You plug and play this chip.
No soldering wires. No splicing wires. No cutting wires. No welding. No disassembling and reassembling required. This allows YOU to install our chip. Even cold air intakes require some sort of mechanical knowledge to install. With our exceptionally detailed instructions you can be rest assured to have the chip installed in less than 5 minutes by YOU! Don’t pay a mechanic $60 an hour to install an expensive modification that has exactly the same effect on performance as the AR power chip.
With such a small price tag you might think this mod is nothing but an ebook with instructions to modify your engine as it is. But the AR power chip is an actual electronic chip that is plugged into a sensor near your vehicle’s air box. It’s a simple plug and play installation that is guaranteed to provide results. It’s small. It’s simple. It’s amazingly effective.
Many of our customers tell us that the price and performance promise of our chip seemed simply too good to be true. Paying less than $20 for a modification that will have the same effect of a brand new cat-back exhaust just seems mind-boggling.
So how can we sell you such an effective modification at such a low cost?
First of all, we manufacture and distribute our chips in extremely large quantities. Add in the fact that we avoid overhead costs associated with keeping a storefront, and you can quickly see that we can sell a valid product at an extremely low cost.
Maybe you’re looking for just a little added horsepower to get rid of your car’s sluggish engine. Maybe you’re looking for a little bit of added torque to tow your boat. Maybe you’re just interested in more horsepower for as little $$$ as possible. In any case, you simply cannot go wrong with the AR power chip.
So what are the facts?
Complete AR power chip kit including the chip and instructions for under $20 shipped
At least 20 added HORSEPOWER
Increased TORQUE output – increased TOWING CAPACITY
Improved ACCELERATION
100% satisfaction guarantee backed by our 100% money back guarantee. NO FINE PRINT. NO HASSLES.
I haven't used it nor have any information beyond this, but I guess for $15 and a willingness to tamper with ones car it seems like the solution for you.
04 LT here
