Dodge-Plymouth Neon Overheating
Hello!
I have 95 neon sports. 114k miles. (I know it's crap!) It's overheating after 10 mins of driving. The shop I took it to said the problem was thermostat housing, which I replaced. Coolant is usually full, though sometimes it is gone (I don't know why). Even with coolant, it heats. If I turn on the heat at max to my foot, heat marker gradually normalizes. If I turn off the heat, it goes up again. I don't think I should be driving like this. It makes me hot.
I don't wanna go back to that shop. Anyone have an idea what is the problem? Thank you!
its good clean car. I just replaced timing belt and waterpump. I'd like to at least reach 150k, before dumping it.
I can see the the radiator fan is not kicking on when this happens. I also turn on the AC and the radiator fan is not starting (I believe turning on the AC, turns on the radiator fan.)
To try and troubleshoot this, I put +12V to the radiator fan motor and it worked fine, so I am guessing it is one of the relays and/or switches. I checked the connection to the engine coolant temperature senser and it was good. Also, I replace the engine coolant temperature senser. I am now stuck. I checked the Haynes manual and it explains that this problem could be in the PCM (Powertrain Control Module) and should be serviced by a dealer.
Does anyone have any recommendation before I go to a dealer? Would it be better, easier, cheaper to just replace the PCM.
Thanks in advance for your help.
Do you know where the relay is?
Looking in my Neon 2k manual from Haynes, the relay is shown on the electrical schmatic for the AC and physically located inside the fuse/relay box.
Once again with bad news thanks to whoever said my overheating problem was my head gasket
Shyleen
And if its not that what else could it be and how much would it cost to fix?
Also my spedometer works on and off anyone else have this problem? How much is that to fix?
It was the head gasket. My car had 66000 miles. I had the dealer also replace the timing belt, water pump, and alternator belt. By calling customer assistance I only had to pay $500. I think that is pretty good response by Chrysler for a 9 year car.
By 66,000 miles it was leaking 1 quart of oil every 1000 miles. So I brought it into a five-star dealer. It was diagnosed with a head gasket failure. They also want to replace the water pump. (I heard bearing noises when it was cold outside.) I told them to replace the timing belt and alternator belt while they are at it. I also asked if there is any assistance available due to the known design flaw in the head gasket. The dealer said no, that it was out of warranty, and that there was never a recall. So I said okay to about a $1000 repair.
So, I called the Chrysler Customer Assistance (800-992-1997) to see if they could provide assistance. I told them how nice the dealer was. To make a long story short, they told me I had to pay the first $500 and they would pay the rest. I'm very happy with their offer. The car is 9 years old! It is long out of warranty. I think this is outstanding customer assistance on the part of Daimler Chrysler.
From my view it's hats off to Chrysler!
I have owned a lot of cars and I have never had one this old with so many problems, time to go with an import!
Farout
Nick
It all started with me leaving the cap off the reservoir after checking levels and two days later overheated in stop and go freeway traffic on a warm summer day.
I think it has to do with the computer, because the fan runs when the engine is cold, even on 30F degree days.
BTW I'm here because we "inherited" a 2001 Plymouth Neon with nearly 120K miles from the stepson (eventually for the next stepson) and was wondering if anyone could advise how much to invest in maintenance.
http://www.complaints.com/november2002/complaintoftheday.november19.7.htm
The AC unit works well- but falters (as in warm air) as the temp fluctuates. When I "open it up" the temp returns to normal.
Any assistance would be greatly appreciated as car repair costs are not something I can absorb right now.
Any information on this subject would be helpful.
I re wired the fans to come on when the ignition switch is on so I know they work.
You can test the coolant for combustion gases and you can also pressurize the cooling system with a pump and then pull the spark plugs and look for coolant on them. Both these tests would reveal a bad head gasket issue.
It isn't always the case that coolant enters the engine oil. It depends on where the head gasket fails within its pattern of various sealing surfaces, holes, openings, etc.
You can get water in the oil, oil in the water, gases in the water, or none of the above and still have a bad head gasket.
I'd certainly keep an eye on this since Neons are a bit notorious for bad head gaskets. But unless you are overheating, you don't have to worry just yet. But keep an eye on that temp. gauge.
Mechanic2. told me I need a rebuilt engine, and that he thinks the Neon is burning oil inside of the engine, and this is causing the overheat. However, I am not noticing any leaks, and no "brown" antifreeze. The car is not burning oil. Can it be still an engine/head gasket problem? :sick:
Now, I read at another Neon site, that this overheating might be related to the speedometer not working (another notorious Neon problem). Apparently, the speedometer data controls the time the fan comes on and off. Any advise how to check the vires for the spedometer?
Get a proper diagnosis. Have the cooling system pressurized by someone who actually wants to fix your car and cares enough to diagnose it, and with the system pressurized, extract the spark plugs and look for the presence of coolant in the cylinders.
You don't necessary have to have a water/oil mix with a bad head gasket.
You can also test the coolant with a chemical for the presence of combustion gases in the radiator. If there are combustion gases, you are "boiling water" as you drive, like a tea kettle--either from a bad head gasket or a cracked cylinder head.
If both these tests show up negative, then you have to check for radiator clogging, inoperative cooling fan motors,etc.
Once you've eliminated head gasket as the issue by a pressure test and combustion gas test then you can confidently throw money at cheaper repairs.
One reason I'm pushing on this is that the Dodge Neon is notorious for head gasket issues. It's one of the "usual suspects".
I took my girls on a little trip in the hills and on the way there my neon started getting hot. It has never done this, actually, I just purchased this car less then 3000 miles ago and it has ran great. Anyhow, There was no where to pull over so we turned the heater on and it cooled down long enough to get to where we were going which we was only 5 miles away when this happened. I checked and the overflow was completely empty. We let the car cool down and before leaving put in antifreeze and headed home. About 10 miles outside of where we was the car started over heating again. We switched the heat on and all it blew was extremely cold air. at this point the steam bellowed out of the hood and the car shut its self off. We rolled to a stop and popped the hood the overflow was still full! we let the car cool down and put fluid in the radiator which had cracked right at the top about 4 inches long. After the car completely cooled, we tried to start it if for any reason but to get it off the freeway and it only turns over, nice strong battery but won't start. Is there some sort of fuel ignition switch or something keeping it from starting? I pulled the spark plugs to see if there was any fluids in there and they are clean, I did remove the intake to get to the last spark plug cable and maybe I didn't put that on right? is there anything else I can check? Thanks
The speedometer is also erratic. Sometimes it doesn't work at all, then it will come to life and work erratically?
Also the dash gauges will suddenly go off. Slapping the dash hard on top will bring them back? Anyone got an idea what is causing these various problems?
