Chevrolet Monte Carlo Warning Lights and Problem Codes
how do i reset the engine codes on my 87 monte ls had to replace o2 sensor and cant get the bad code out of the system
The temperature display is always 10 degrees cooler than the actual outside temp. It has always seemed to be ok, now all of a sudden it's constantly lower.
Thank-you
If you don't get an answer here, try typing your question in the "Ask the Community" box on the right side of this page. It's a good way to get a quick answer to a quick question.
Rod
