01 Focus ZX3 won't start! HELP!!!
I am beyond done. I've had this car literally 2 weeks, and have only driven it to work 3 times. And after saving up for 6 months to finally buy a car, I'm not very happy. I replaced the rear passenger wheel bearing. Then, on my way to work one morning, BAM! It started sputtering, then wouldn't accellerate when I stepped on it. The RPMs ran up, but nothing. Put the OEM tool on it, came back with a code that the cat was completely plugged. Had it replaced, BUT IT STILL WONT START!!!! So, I replaced the fuel filter and still nothing. It cranks and cranks but just refuses to start. It tried to start once or twice after I got the fuel fiter on, but it just won't turn over. So, I disconnected the outgoing line on the fuel filter and cranked it. Not even a drop of fuel came out and I don't hear the pump kick on when I turn the key, so I'm thinking it's the fuel pump. However, someone told me it could be the timing. I checked, and there is spark at the plugs, so I don't know what else it could be. I'm a chick that prefers her cars pre-1969, so I don't know where else to go with this god foresaken hell beast. lol I really appreciate any help I can get! Muah!
I know nothing about Fords, but I would get for any and all fuses/realy related to fuel pump. I have also seen something about inertia switch on passenger side kick panel in front. There may be a little door to open and then press the button to see if that helps. There may also be something with the wires to the switch having issues (maybe). This may be a start until someone who knows something comes around. Good luck
