Need to find replacement HVAC control module for 03 Buick Rendezvous
attached
is a picture of the dash of my 03 Rendezvous. I have been looking for a replacement HVAC control module that looks like what is displayed with no luck. Does anyone know of a used replacement? Is there a compatible replacement that looks different?
help would be appreciated
Best Answer
imidazol97
Member Posts: 27,744
@bgrossenbacher said:
is a picture of the dash of my 03 Rendezvous. I have been looking for a replacement HVAC control module that looks like what is displayed with no luck. Does anyone know of a used replacement? Is there a compatible replacement that looks different?Rockauto offers it for $252 new.
It's used only from 2002-2007 Rendezvous.Search on car-part.com for option CJ3 for the heat control. That's manual with auxiliary control for passenger side.
Verify that RPO label "CJ3" on the trunk tag that shows all the options on your vehicle.
It's probably on the top of spare tire cover.Note the one column shows grade of part for quality in appearance. Another column sorts
based on distance from Zip Code you entered so you can find yards closer to call.
Note the column that shows the year Rendezvous the part is on.Also ask about pick and pull parts to do yourself in your area.
But some of these are showing $100-85 from car-part.
6
