95 Jimmy Braking Difficulties
curley34curley34 Member Posts: 2
edited April 2014 in GMC
I bought a 95 Jimmy with 73K miles on it. Previous owner said he had never done anything to the brakes. When towing my boat, the truck was hard to stop, and I ended up downshifting in addition to braking (on a level, paved street). I re-did the front brakes, but the backs were hardly worn at all so I left them alone. Same problem. So I also did the back brakes. Still having problems. It almost feels like the back brakes aren't working. (A different Jimmy that I test-drove with 135K had a similar problem.. new brakes, but you had to stand on the petal to stop it, without a trailer) My mechanic said that the brakes on this vehicle are under-designed and oh well. Is this real? The boat is 3000 lbs, but the truck is OK to pull this amount.
    Sounds like your power brake booster is failing or has failed completely.
  • jgmilbergjgmilberg Member Posts: 872
    Your mechanic is right, they should ave put larger brakes on the Jimmy/Blazers, but didn't. GM used the brake system right from the S-10 w/o thinking of the added body weight or the extra passenger load. There are upgrade kits for them that give much better stopping, but they are expensive , around $1500. Check out stainless steel brakes. com for more info on them.
    Is the truck hard to stop w/o the boat? If so it can be the power brake booster, or the vacuum filter may be plugged giving a hard pedal. It could also be a bad proportioning valve, or the rubber hoses are flexing too much. I changed he ones on my car to stainless steel braided and it made a HUGE difference.
    I can recommend to have trailer brakes installed. Will help greatly in the stopping power. I really don't think this should be nessessary with only 3 K lbs. Plus in addition to the brakes, you will need a controller and more wiring on the truck itself.
  • poisondartfrogpoisondartfrog Member Posts: 102
    Have you changed the brake fluid? Brake fluid absorbs moisture over time, and that can cause the calipers/wheel cylinders to be lazy, and not be as effective transferring the hydraulic force through the line from the master cylinder to the calipers. Since you have a '95, the rear brakes are drum. From '97-on, the S-truck SUVs use four-wheel disc, if memory serves, such as on my '97 Bravada.
    I believe my brake problem stems from GM using a hard pad compound, which wore my rotors to under service limit in the front (@ 38K miles) and the rear (@ 46K miles). I replaced them with NAPA premium pads and rotors, and flushed the system. Brakes work well. and I live in a hilly region, and pull a boat trailer, although I use electronic brakes.
    So give the fluid change a shot... you'd be surprised how gunky brake fluid can turn, especially if it's original in your '95.
