Old Jeep CJ-7 (82) Headlights go out
Divorce leaves me with the old clunker and I need to make it safer for full-time use. Every time I drive at night, the headlights shut off every few minutes. It seems to be worse when it's warmer, but either way, they shut off six or eight times before staying on for 10-15 minutes. Then I go throuhg the whole cycle again. I have run the wiring diagrams for a short, disconnected wire, etc. My fuel and temp gauges also are out but have been for some time. Dealership where we bought our new Jeep said the guages were shot. I bought new ones and it did not fix the problem.
Back to the headlights, a friend said he had heard of this once and said he was told it was a "breaker" that shuts off. I have never heard of or found a breaker in any of my old manuals.
Any suggestions or ideas would be much appreciated! Thanks.
One would be the headlight relay (wired between the dash switch and the lights themselves). Another would be the possibility that on and old clunker like this someone has changed the source for the headlight juice...maybe there is an old corroded wire coming off the positive battery post?
But a relay sounds very plausible, since it seems to be heat and time related, exactly like a funky relay would act.
Any ideas on the fuel and temp gauges? They are linked on the old CJs and I assume if a ground wire is bad on one, both would be affected (?). I ran a lead to the battery just to see if I could get them to jump and still no go.
I am going to replace the sending unit on the temp first, if that doesn't work, drop the gas tank next time it is low and check the ground wire. I just can't get a good handle on it while it's in place, no room. I have a little dental mirror and can see that it looks to be connected, but it still might need to be cleaned up and reattached.
Any other grounds I could be missing? I hate wiring!!!!!
I did find out the parking lamps were old, shot and shorted out a bit. I have ordered new ones but after disconnecting, the headlights still do their same old dance.
As far as the gauges go take the temp sensor wire off the sensor, and hook it to a good ground, if the pointer doesn't move it's either the wire or the gauge, if the needle gets buried it is the sender. If I remember correctly the sending unit for the fuel tank on Jeeps are FAMOUS for going out, and the only way to fix it is to get a new sender and drop the tank all the way out. You can test that the same way as the temp sensor.
The gauge problem is unrelated to the headlamp situation. I'm not certain about the '82, but some vehicles have an "instrument power supply" which may be nothing more than a resistor that supplies the proper voltage (~7 V, I believe) to the instruments. Since both gauges are out, check to see if this unit is burned out. It's probably attached to one of the gauges.
If I'm lucky, I'll get a good jolt and it will all become clear to me. Thanks again to all who posted.
I had the same problem on my '83 CJ-7. I traced the problem to the floor mounted dimmer switch. Hard to believe but this switch can cause all sorts of problems with the headlights and dash lights.
I replaced that switch a few years ago because it had become hard to push, and with the floorboard having a little rust here and there, it is possible that I don't have a good ground on it, or the wiring could be cracked or frayed someplace and I know I never really looked for that. I am going to check that out tonight and thanks a lot for your suggestion!
