Transmission cooler, good idea or unnecessary?
Hey guys,
I don't tow anything. The reason why I ask is because the auto transmission in this car is on the way out. I bought the car in Oct 98, the previous owner didn't maintain the tranny in this car. In fact, when I bought it, the tranny fluid was black. I presume the tranny fluid was black from running too hot. I changed it immediately, but I can feel the tranny struggle at times when accelerating. Would a transmission cooler be worth putting in this car? Prolong the life the tranny for another year or two? Considering the age of the car and value, I wouldn't want to put a rebuilt tranny in it. any opinions?
I am not an expert-but if the oil looked as you suggested the trans has one foot in the graveyard.
Check the Mazda 626 discussion group and you will find out that they have weak (Ford) transmissions and are constantly causeing problems. They need overhauls fairly frequently. He considers it good insurance.
Lubegard reduces acids, so it might be a help to stop current damage. see the site at www.lubegard.com
Jim
So if you are towing or driving in very severe heat conditions, and you expect synthetic oil to match the efficiency of a good external cooler, I feel you will be disappointed. But for a little extra security under normal conditions, a synthetic oil might help, sure.
I still say syn oil is a good choice because it gives you at least a hundred degrees of reserve. I can't imagine a transmission so misdesigned that it runs 100 degrees higher than its supposed to. Don't forget it also has a cooler in the radiator and as the transmission heats up-heat rejection improves. Towing may be the exception where a cooler is absolutely required.
Of course transmissions go over their acceptable heat range...that's why they burn up, and that's why you need a cooler for either a) towing, b) severe service, or c) possibly even for "weak" units that are notoriously unreliable. If your trans is overheating badly, no oil is going to save it---at best, it gives you just a few more minutes until the catastrophe happens or until you can react (hopefully in time) and give it a rest or a service. If say a racing engine running syntheetic is pushed to its design limits (over-revving, detonation, etc.), it doesn't matter what kind of oil is in it.
As far as over reving a race engine thats a different story. More than likely its a delivery problem where oil can not physically keep a surface lubricated or the high speeds broke a rod or physically deformed a bearing even though there was lubrication there.
Having said all that-I may investigate a transmission oil cooler myself. Who makes good ones??
Nor, for that matter, can an oil cooler be thought of as a guarantee of long life. It's just another hedge, like synthetics might be, or good driving habits and good service. You add 'em all up and hope for the best, I think.
The extra external air to ATF cooler can lower peak temps by 20-30F thus doubling the time between color changes from bright red to dull red.
After 20,000 miles my ATF looks like brand new [compare color] but it gets changed [full flush Mobile 1] anyway since the goal is maximizing life and $200 every 20,000 miles [annually] is nothing compared to a $3500 unscheduled replacement.
If owners would just change all their fluids annually [plus the regular 3-4k or 90 day oil changes]..brake, coolant, ATF, ps, diff, traction, etc they could easily get 250,000 miles out of most vehical systems!
that "use only Honda ATF. if Honda ATF is not available, other brand of ATF can be used temporarily. It needs to be flush out as soon as possible and replace with Honda ATF". I am planning to use Mobil sync ATF on my Honda, and
is there any truth to the Honda claim? Or it is a another gimmick to sell expansive Honda ATF.
Honda ATF is different. But a transmission specialist or your dealter should have a synthetic available.
I just wanted visitors to avoid a false sense of confidence from synthetic oil alone, as if to say "well, I've got synthetic in there now, so I can forget about good driving habits and maintenance". Bad idea!
Even Mobile 1 with an external cooler starts to change chemical composition around 20,000 miles [the red color starts to get washed out] and the smell changes. Depending upon how long you want the tranny to last thinking about a full flush exchange should begin and in no case should the ATF be allowed to remain for more than two years even if you don't drive much.
The best OEM warranty is only 6 years or 70,000 miles [most are still around 3/36k] the dealer would love to sell you another AT anytime after that. We have been sucessful in extending transmission life to the 175,000 plus range [on cars that normally failed at under 100,000 miles]by almost forcing the customer to do flushes and use premium fluids [we make the same profit on multiple flushes [say 5 plus cooler install] but the customer saves big on the transmission.
Either way we're happy but it's nice to save the customer money.
Post #21 by LB was a good one too. It is important to realise that the so called "cooler" in the bottom of the radiator is really a heater. LB is right; trannys don't like cold fluid. Radiator heat is used to warm up the tranny fluid until the tranny itself gets hot enough to be happy.
The problem is that trannys get too hot and the radiator cannot cool it. That's not what that thing was designed for.
Prolly the best thing to do in the AM is let your car warm up gradually before driving off. That way the tranny has had time to feel good and will operate as best as it can. This is especially important in cold winter climates as cold temps will kill a tranny about as quickly as hot temps.
