2014 BMW 328i xDrive Gran Turismo Long-Term Road Test
It's ridiculously easy to get at the oil filter on our 2014 BMW 328i xDrive Gran Turismo, but will anyone ever notice?
Is it as easy to drain the oil? Does a belly pan need to be removed to access the oil pan drain plug?
Or is there an opening in the belly pan as in the Subaru flat-fours?
http://www.edmunds.com/subaru/impreza/2012/long-term-road-test/2012-subaru-impreza-sport-ridiculously-easy-diy-oil-change.html
Can you even reset the service reminder on the dashboard on your own on a 2014 BMW?
You can reset the service indicator lights manually. you can google "How to reset the 2012-2013 BMW Maintenance light" or go to oilreset.com for instructions on the procedures to this and many other cars.
BMWs are extremely easy to work on. Genuine parts are readily available at fair price and are of exceedingly high quality. These cars are made to last a long time and with utmost attention to detail when it comes to repairability.
banhugh, while some models do require battery registration, this a) does NOT require a $4k computer and b) is optional. This process goes beyond what your normal Japanese car does by programming the smart charging system to significantly extend the life of a battery.
http://www.motor.com/article.asp?article_ID=1479
Twitter: @Edmunds_Test
