oil cap residue on 2000 vw golf
any suggestions?
I have a 2000 vw golf and I noticed that after my second oil change there was a creamy thick residue under the oil cap. From previous experience I thought this was cause for concern. I previously owned a Chev Corsica and under the same circumstances I was told I had a head gasket leak. I brought my Golf into the dealership and questioned as to why this residue was present and was informed that it was normal and due to CONDENSATION?? Any thoughts?
Sam
Sam
If it is only condensation then the breather lines should evacuate it quick enough, if it is a water cooled engine check for coolant loss, if it is air cooled make sure the top of the heads is BREATHING/VENTING adequately.
Hope this helps
Rando
Bad engines can have spotless oil caps. Great engines can have dirty oil caps.
You want to look inside your engine, go look inside your engine (remove valve cover or drop the pan).
To say to ingnore what is under the oil fill cap is irresposnible to me as it can be an indicator.
1. It's dirty looking, kinda. So what? Perfectly normal to have some deposit residue in an internal combustion engine. What does that smudge on your fingertip tell you? Nothing at all.
2. There's a little white gooey stuff. So what? This is condensation, and you can waste a lot of time and money pulling a valve cover only to find that this is what an oil cap often does, trap condensation. You need to look IN an engine to see what's going on. No other way.
3. It is clean. So what? You could have a disastrous problem in the engine with a clean oil cap.
Like I said, looking at an oil cap is a totally useless enterprise.
Why "useless"? Because it contains just information to mislead you and not enough to instruct you.
No, WAIT! There is one reason to look at it---to see if it is MISSING!
You want good info? Pull a valve cover, or better yet, get an oil analysis. Then you are working on empirical evidence, not reading tea leaves, so to speak.
