2014 Ford Fiesta ST: Dyno Tested
Just how hot is Ford's latest hot hatch? We dyno tested the 2014 Ford Fiesta ST to find out.
From data logging the charge temps off the intercooler they can get high as well which likely affects consistency and power for the Focus. Without being able to run increased boost pressure to compensate for hotter, less dense air (due to the turbo being maxed out) and limited to the ignition timing that can be run at higher compression on pump gas, even with direct injection, there's not much the powertrain controller can do to keep power up when on a dyno that can't produce the same amount of airflow the car will see moving down the road at speed. That is a big fan but nowhere close to being able to replicate real-world airflow over the frontal area.
Been there, done that, won't do it again.
