Porcupine damage
My neighbor has a 2001 Tracker that has been attacked twice recently by porcupines. While parked on his driveway overnight, the Tracker had its gas lines (front and rear) chewed up by the porcupine in the neighborhood (this in the rural, mountainous Catskill Mountains in upper NYS). The first time he thought the car not starting was a defect and would be fixed under warranty, not having a clue it was the porcupine. After paying $150 to have it towed to the dealer, the dealer told him it was porcupine damage and therefore not under warranty. So, the whole bill for towing 2 days of a car rental and the repairs came to about $600. The second day after the car was fixed, it happened again, and this time he knew what it was. Question: Is it possible the porcupine is attracted to the specific composition of the rubber hoses on the Tracker. No damage has ocurred to the family's other car, a 1998 Rav4 or to any other nearby neighbors. Anyone have ideas on this or how to repel the porcupine(s) before I am the next target?
You can't stop critters if they are determined, we all know that. Ever try to keep a squirrel off your roof or out of the bird feeder? Good luck.
I suppose there are some strategies that could be tried for fun. Perhaps the Samurai could be fitted with aftermarket skid plates to close off the bottom access to the engine compartment; also, when he parks he could park over a large pan of water or some other liquid that porcupines don't like; or even park over some obstacle that just barely allows the chassis of the car to clear.
You can trap 'em of course but this could go on forever.
Plus he would get some much needed sleep, and maybe avoid blowing a hole in the car when he misses the porcupine with that shotgun. :-)
According to some animal web sites, the porcupines "running" speed is about 1.5 mph so I'm hoping to chase it (if I ever see it near my car) and bash its head in with a brick.
I would not count out other critters craving salt! Where do you live? With a lot of salt licks I may be able to shoot a 13 pt buck.......:)
That's baiting, the game warden might not look on it too friendly.:-)
there are also enough hunters who are close enough to the bait so the critter's drool gets on the front lens of their scope regardless of the law.
oh, should mention that porkies often have some loose quills, and if they get frisky running off and shake their tail, they fly. if you get quilled , ain't a lot of difference in whether you got it through the air or grabbed a chunk of > oops <.
Thanks to all for a light hearted response and some practical tips.
Or maybe the rubber parts on the Tracker are just in a more vulnerable, exposed place, also making them easier for munching?
How big do porcupines get, anyway? Not to get too graphic, but the only time I've seen them was smashed flat, along the railroad tracks out in Washington State. From what little was left, it looked like something I wouldn't have wanted to get into a tangle with if I ran into a live one!
maybe they just like the texture of hoses... the folks had a cat that just adored gnawing on electric cords. had to put sleeves around the cord on everything. bit down hard on the back teeth, maybe as a substitute for flossing, and got buzzed at least once.
By the way-what do you do with a trapped porky-a rather prickley proposition.
The whole neighborhood looks whacky! People have snow fencing wrapped around their cars, some have bolted steel mesh all over the underpinnings to keep the critters from getting fuel lines and brake lines. There is now talk of hiring a critter removal expert. I actually got a trap, batied it with salted apples and anchovies. I figure I can deal with handling anything I catch. I built a wood rectangle or sleeve that I can (gingerly) slide the trap into once the bad boy is in it. Then I can safely handle the trap, handle and take it far a way in my Trooper. Releasing will be tricky, but I put a bracket with release wires, etc. ont the wood sleeve, and I am hopeful it will work. In a calm dress rehearsal everything went fine. Who knows how I'll react when the whole cage is rocking and a hissing screaming porcupine is trying to get at me. We'll see. Someone told me to dump the trap into a pond and wait a few minutes then retrieve trp and dead occupant. Not sure I can handle the idea of that. Anyway, it is one of the strangest situations I have ever been involved in - this whole porcupine eating cars thing.
the thing to do is to take the porky ten miles or so away and release in a likely spot.
yes, this does raise the likely spectre of the porky being in another's territory and getting run out after a fight, but life is hard and then you die sometimes. it's the best shot for the critter, since petting zoos don't have much use for wild porcupines.
You'd think the cat would learn, but it didn't. It finally got to the point that Granddad would end up popping the hood and checking the engine bay before starting the truck! I guess you don't train a cat...they train you!!
As long as you aimed carefully, you were fine. A neighbor of mine liked to sit on his back porch, drink Jack Daniels and shoot groundhogs.
OH, don't shoot the poor thing. It's just being a porcupine and animals can't make choices as readily as people (just not wired for that). I bet there's a nest of 'em around and you all could chip in and hire a Critter Guy to UPS them somewhere else.
On a more serious note, what about a chain link fence that goes into the ground about a foot so they can't tunnel under it?
No, I've never lived in the country.
this topic is rather like the credits for Monty Python and the Holy Grail, except the mooses told me they weren't involved in this post.
Or, how about a dog ?
Or, how about setting out food (bait) containing lots of iron particles, then having strong magnetic fields around your car ?
Or, how about that South African security system that attaches a flamethrower to the underside of the car and scorches whatever's standing nearby ?
Or, how about a JATO rocket ? (since we're venturing into the realm of urban legend anyway...)
-Karl (here in Nevada, no porcupines to worry about... and the coyotes and wild horses don't seem to be able to open my garage door to chew on my brake lines.)
way back when, as a boy scout, a pair of raccoons swiped the bread bag overnight from under our tent and started in on it. shoo'ed them off.. and then decided to leave a final little treat. six fizzies wrapped up in a couple pieces of bread. the coons came back once, bumped and thumped down the trail after getting into my little surprise, and no further issues.
since fizzies are hard to get nowadays, try wrapping your hoses and lines in alka-seltzer. you'll surely be noticed when you splash through puddles
razor wire should also be good, but you will probably find an extra hour or two of labor on your vehicle on every service from an oil change to pounding the dents back out of your doors, hood, and replacing the glass that mysteriously shattered when the service advisor bent over to pick up the clipboard he dropped under the vehicle
