Erratic Transmission Behavior, Help Please. 2012 VW Passat.
One month ago I purchased a used Passat SE 2.5 with 11,186 miles. I generally take the bus to work so it gets driven fifteen miles a day back and forth to the bus station without incident.
However on four occasions in the past month I have driven it to work which 65-75 miles round trip depending on the route.
Three of the four times I have driven the car to work it has started shifting erratically (both up and down shifts )when it traffic and shortly after this starts the Maintenance
Indicator (wrench) comes on in my center display and then shortly after that the check engine light also comes on. Once it gets to this point the transmission behavior is so erratic and down shifts when coming to a stop so violent I think it’s going to give up the ghost on the spot.
The first time this occurred I limped the car back to the Volkswagen dealer and was told they needed to update the ECM software and the problem would be fixed.
The second time I limped the car back and left it with them they claimed a faulty MAP sensor was the cause and reassured me my troubles were over.
This morning on my way to work this started again with the erratic up and down shifting and the Maintenance Indicator (wrench) was on once again when I arrived at work. So tonight I am confident I will be presented with the check engine light and I will once again have to limp it back to the dealer and leave it with them yet again.
I am out of answers and patience at this point, is this a common issue with the Passat?
Here is what is on the paperwork from it's prior trips in over the last 30 days
On 9/5 they stated one DTC stored P0106- map sensor range/performance malfunction and they list that they did a software update oin the ECM
I took it in on 10/7 for the same problem and they state multiple DTC's P0106- map sensor range/performance malfunction and list replacing the MAP sensor and tech cleaned out throttle body housing.
I will list the codes from this visit tonight after I pick it up.
Just had this happen for 20k miles in my 2012 Jetta. They said ECM updates, done. MAP sensor, clean throttle body.... none of these cured it. Last thing done, tighten intake manifold to MFG specs. Voila, issue corrected. Issue from factory.
This should be a MFG recall for the Passat & Jetta. But VW will fight right now to keep any other issues away. Hope this helps. Please tell your dealer.
Long story short, I decided not to replace the sensor after reading online that simply cleaning the sensor will correct the issue. Now it has been 2000 miles + and it has not since re-arose. The problem is, where the sensor is placed, it will eventually get dirty again, and give false readings to give erratic readings to the transmission/engine.
So, end story is you have to be aware of the MAP sensor and keep it clean if you have this issue. PITA..... Car runs excellent otherwise.
Not saying this is a larger issue. Just want to help protect others with this issue.
