A Good But Not Great Cruise Control System - 2014 Ram 1500 EcoDiesel Long-Term Road Test
Our Ram doesn't have the most distinct cruise control buttons, but there are easy to use once you get used to where they are.
Back on topic. The on/off button is no big deal and can keep someone from accidentally activating the cruise control. My Acura has an on/off button but once it is turned on it will always be on unless you manually turn it off, even after you turn the car off. The indicator "Cruise Main" will always be on as long as the system is on. When engaged the indicator "Cruise Control" will also be illuminated. Since I also frequently use cruise control a good system is important. I prefer buttons on the steering wheel since they are directly in your line of sight and illuminated at night. But it really annoys me when they are on the left side of the steering wheel, it just doesn't seem right.
Oh and the Ram's cruise is the worse! It does not hold a speed and fluctuates 2-5MPH below when going up small hills before kicking down and catching back up.
