Problems with rear differential
venkolovech
Member Posts: 1
Hello,my name is Venelin. I am from Bulgaria and I have a problem with AWD system ? When I drive a long way after 30min heard a strange noise in the wheels if pads grind,but when off jack noise stops.Can you tell me where is the problem ? I apologize for my bad English. Greetings from BG !
Best Answers
Mr_Shiftright
Member Posts: 64,481
Hello Venelin! Greetings from California!
Have you tried to check one wheel at a time? Perhaps you have a bad wheel bearing? If you spin each wheel by hand, sometimes you can hear what it wrong. Also move the wheel side-to-side by grabbing it with both hands5 -
Mr_Shiftright
Unfortunately we can't hear the noise. It could be so many things, such as low fluid level in the transmission or transfer case, contaminated fluids, a bad bearing in the torque tube, wheel bearings, or of course internal issues.5
