What else to check? Isuzu Trooper exhaust noise.
                    I have a 2000 trooper who was running like a champ.  It sounds like a popcorn popping from the exhaust area.  The 02 Sensor was recently changed.  The check engine light came on and it was the EGR valve.  Valve is now changed, codes cleared.  It idles fine but when you put the vehicle in drive, and accelerator, you loose power and the popping noise starts.    No check engine light since the  EGR valve replacement.  What else should I be checking?  It is a great little vehicle up until now.
Answers
Also check all vacuum lines. If one is disconnected, that might cause that problem.
