-September 2024 Special Lease Deals-
Honda Pilot Accessories and Modifications
aerostar45
Member Posts: 19
Steve
One thing I like about the site is that they have the installation instructions available as pdf files so that you can decide whether or not installation is something you want to tackle on your own. For things like mudflaps and cargo cover etc... do it youself installation should be very easy. Unforunately the wind deflector requires a special tool.
I have not yet ordered anything from this business but plan to in the near future. I was close to attempting to install the security system on my LX model but decided that it was too complicated for my level of experience. The price was attractive though: $265.00 from collegehills or $418.00 according to the official Pilot website.
Goodluck.
My first choice was the in-dash CD changer, but while it will fit in the space where the plastic pocket is and it will connect to the head unit, apparently there is no plastic bezel available to fill-in the space around the edges of the changer. It seems the in-dash unit is intended only for use with the smaller head unit in the LX.
Consequently, my dealer had to remove the in-dash changer and was reluctant to try the under-seat changer. It seems that there was a lot of confusion regarding whether or not the under-dash changer would work in an EX. The parts department was telling the service manager that it would not fit, but after I showed him the installation instructions (thanks, collegehillshonda.com) he agreed to try it.
The end result is that everything fits and works fine. So if your dealer is telling you that the under-seat changer will not work, insist that they look up the installation instructions before you give up.
Now... who's got the best price on additional CD changer magazines?
You are right, the mud flaps and cargo cover are very easy to DIY. It is funny that there is a labor fee for installing the cargo cover by the dealer.
For the security system, do you think a Lo-jack will be better than the factory solution? Is it worth to install both of them to the vehicle?
Thanks and Good luck for everyone.
Regarding the utility of the Honda alarm vs. a Lojack - I am not familiar enough with either system to have an opinion. The cost of the Honda system is fairly high - $418.00 plus installation fees which will probaly bring the total to at least $525.00. I am tempted to have an alarm installed by the local car stereo shop for $300.00 total cost. However, I am leaning toward the Honda option since any of the local stereo shops have probably never worked on a Pilot before. I don't want my vehicle to be their first experience.
What does the Lojack cost and how does it work? My understanding is that it emits a locating signal to find the vehicle after it has been stolen. Does the system do anything to prevent theft in the first place???
http://www.lojack.com/foryou/lojack.htm
Basically the lo-jack is a system which will help you bring the car back when your car is stolen, not before it is stolen. So, it is totally different from the alarm system.
I read and saw on TV that a lot of alarm system can be easily beaten by a pro car thief. Since Honda is the #1 or #2 target on the thief's radar, I really concern about the credibility of the regular alarm system.
Just my 2cent. Not try to offend anybody.
A number of MDX owners gave up on the OEM air deflector because of installation and fit issues, as well as the fact that it's rather bulbous. The FormFit seems to be a bit simpler and holds the vehicle's contours better.
I check and download the installation instructions of the In-Dash CD changer from www.collegehillshonda.com. It seems to me if you are willing to sacrifice your cassette player on your EX model, it is possible for you to uninstall the cassette player and put in an In-dash CD changer.
The procedure is kind of complicated though. At least you can print these procedure out and hand it to your dealer. See if they can try it for you.
Good luck!
The other and seemingly way more obnoxious add-on was an entry just labeled Simmonize. This "option" listed at $999. Yep, almost a thousand dollars for what? Anyone know what the hell this is all about. Thousand bucks for a wax job. I would feel like I'd be the one getting the wax job. This seems like a big rip-off to me. This was listed on a separate sticker that was slapped on next to the dealer sticker. If Honda puts on some kind of clear-coat finish where does the dealer get off breaking that out and then adding it back on.
This dealer was Herb Chambers in the Boston, MA area.
Anyone with any experience on this?
thanks,
Jeff
I ended up getting the under-seat six disc CD changer. It fits perfectly under the drivers seat in the EX and there is no conflict whatsoever with the motorized seat.
The installed price was $543, and the dealer earned every nickle of the labor charge... they first installed the Honda in-dash model, only to find out that there was no plastic bezel available for the lower dash position. They removed the in-dash unit and installed the under-seat model under the driver's seat (as specified in the instructions).
I'd caution everyone to be careful with an after-market changer. The space under the seat is REALLY tight due to the power-seat mechanism and the way it moves. The Honda unit is held slightly above the floor with a special bracket. Anything much bigger would probably crush the under-floor heater duct when the powered seat is in its lowest position.
You said your dealer tried the lower dash position. Where exactly did your dealer tried? Just under the retractable tray? I notice there is an accessory glove tray which is just under the climate control unit. I am wondering if it is possible to pub the in-dash there by removing that tray. Thanks!
In the EX model, both A and B are used by the larger radio/CD/cassette unit but C is still available if the open storage slot is removed. This is where the dealer attempted to install the six-disc in-dash CD changer. It DID fit there and it was possible to connect it to the main unit, BUT there was no plastic bezel available to fill out the small space that was left all around the changer. Apparently, Honda does not make such a piece.
Luckily for me, the dealer uninstalled the in-dash changer at no charge and installed the under-seat changer instead.
So my question is, any Pilot owner has switch the backup light bulb ? The reason is, it is too dark viewing through the tinted rear glass when you do backup.
I'll be getting my Pilot tomorrow, 22 June.
I did put a set of 50watt halogen Backup lights on my Mountaineer. They're made by Design-Tech International.
I bought them at Auto Palace (a large chain locally). I've had them for four years with no problems.
Are you planning to switch to your Pilot as test out the result ?
If you do, please let me know whether it helps or not. Thanks PChiu
So, the problem is no plastic bezel. Do you think it is possible to use a wood piece instead? Will that affect the front panel appearance? Thanks!
Sorry for digging on this. Just cannot give up the in-dash love that easy.
I don't yet feel I need them for the Pilot.
Over time I may change my mind though.
They really made a difference with the Mountaineer.
I will wait a little longer to see how the backup of Pilot.
Me too, my concern (for my wife) is the backup at night time through the tinted glass.We have the backup sensor, that helps a lot. Thanks PChiu
Do you find it more useful or annoying?
Thanks in Advance, Bill
The option of backup sensor is a must for my wife to make the decision to buy the Pilot among other SUVs.
As my wife is 5'1", even myself, I cannot see things below the rear tailgate glass.
It is very useful and not annoying. As it works only when you put in reverse.
There is just audio warning only, (no backup camera in Canada right now), the beeper is located at the cargo area passenger side. There is also a on/off switch on the D pillar inside the car (the last one close to the tailgate).Incase you tow, hang bicycle or snow stuck there.
It will just beeps, the closer you get to the object the more frequent it beeps till a single long beep tone then you knock down the object.
The dealer says the beep tone is different from the corner sensor than the center sensor.
Have not test that out the different tones yet, as it was activated just a few times.
But I can live with it, as kind of cofirm it isworking, and will not accendiatlly put in reverse.
Thank again,
Bill
It is very useful and helpful to detect little kids. It has been activated once when a kid ran behind the SUV, then it beeped right away, after the kid ran past, it stop beeping.
But it happened so quick, like suddenly you heard 1 to 2 beeps then the kid's gone.
If you want to check the installion before you buy it, this is the link, go to install at the top right corner.
http://www.collegehillshonda.com/parts/extension/pilot/03pilot.htm
If you have a question as to how it mounts, just remove the dashboard trim pieces and you can see how it goes together (just check the in-dash player instructions on the college hills honda web site). If you are a VERY good cabinet maker, perhaps you probably COULD make a bezel out of wood, but I think it might be very difficult.
Good luck!
I bought an aftermarket CD changer from the Fry's electronic for $250. This SCD-A88 model is for most Honda vehicles up to 2002. I was in doubt whether it will work for Pilot. It got a 14-pin cable adaptor and it matches with the Honda's installation instruction. I decided to give it a try. It worked very well !! As sofla mentioned you have to be extra careful with the black extra thin duct under the driver seat. The worst part is to do-your-own-mount and I used some wood to extend the mount and put the bracket that came with on top.
For those who has one, how is the picture quality in both day and night ? When your Pilot is only inches away from the car at the back, does it give you a good angle to see how close you are ?
I saw that Fry's Electronic has a rear view mirror which has a 2 - 3 inches screen on the left side of it. You could hook up 2 devices like a back up camera (similar to Honda's) and also a tiny baby monitor camera to that mirror. You could select which one to show. Good thing is you don't need to have a navigator to show the rear view. Bad thing is it is not cheap !! With the setup that I mentioned it costs around $700 plus installation. But this is an alternative.
Do you know if it will play MP3's?
Too bad it won't play MP3s but it still sounds like a great deal compared to the Honda unit.
Does anyone install a slim All-in-one unit ? What is the brand name and how much it cost ? Or does anyone find a good place inside the vehicle to install the DVD drive ? Any advice ?
CollegeHill Honda Accessory has exactly the same as in Brochure. The service guy gave my wife a run-around about the brochure was incorrect and I don't buy it.
Chris
They are exactly the same as from the brochure and the Honda websit.
yaozhong- my sensor works fine so far, did you park against a wall or next to a column ?
You may want to clean the sensor a bit with cloth ?
What I know is in Canada the snow that block the sensor will trigger the beeps.
I guessed Honda should do something about those dealers as they don't seem to care about the Honda reputation at all.
