Ignition Locked Problem
I have a 2002 Focus ZX5. Automatic.
The other night, I pulled into a gas station and pumped gas. When I tried to turn the car back on, the ignition switch was locked as well as the break pedal.
I attempted to shake the wheel, move the shifter, and press down the break. Not the most eloquent solutions, but still had no luck.
I know my key has a transponder in it.
I called some mechanics and they all suggested that I would probably have to take it to a dealer if it is a problem with the transponder.
Any suggestions as to what my problem might be?
Could it be something else?
If it is the transponder do I have to take it to the dealer or is there another option?
Thank you for your help!
