Brake lights and Chime on after 87kmph
Hello All,
I have a Buick Rendezvous FWD 2002 CX. It has about 140K on it. The issue I am facing lately is that when I hit 87~90Kmph, the ABS, P, TC(off) and (!) fault in brake system lights are on in the dashboard along with the Chime. It doesn't shut off until I switch off and turn it on again. This has been going on for a month now.. I see many with this issue but none with solution.
I have changed the brake pads, replaced the wiring near the front wheel sensors, and also the my mechanic says the scan codes are not picked up by his scanner.
Any help will be greatly appreciated
Also is this something to be worried about ??
